Question about GE (PSS26MSRSS) Side by Side Refrigerator
HOTPOINT/GE REFRIGERATOR NOT DEFROSTING
Our Hotpoint/GE side by side refrigeratyor model HSS25IFMDWW Serial Number MD201796 appears to not be defrosting properly. Therefore the coils in the freezer section are frosted over, the ice is not solid and the refrigerator section is not real cold.
Can you help?
PS: I bought the refrigerator about 6 years ago in the middle of a move and lost the manual. Do you the library would have one? Also, I need to locate a wiring diagram....can you help with this too!
  • 1 more comment
  • dawn48 Aug 05, 2008
    Did you fix your problem??? I bought a defrost thermostate for starters. The evp coils is getting hot/red. The only other solution is to replace the electronic piece on the back. It was on the list of possible problems. But the defrost thermostate was only $10 and some change. Update me and let me know what you did.
  • dawn48 Aug 07, 2008
    I'm still having have the same problems after changing out the defrost thermostat. Does anyone have any other solutions? Is there a defrost timer.....
  • jaronson199 Apr 08, 2009
    I have the same problem. I am thinking about changing the defrost heater. Has anyone tried this or know of a good way to test it? I found a defrost heater on ebay for $17 delivered
    Problem Solver:
  • 4 Answers
I have the same problem. A lot of people in forums are telling me it could be the defrost heater. Anyone know how to test it?
Posted on Apr 08, 2009
    I solved my problem, it was a burned up defrost heater
    Champion:
  • 210 Answers
I`m actually working on the same problem. defrost problem and no wiring diagram. I defosted evap. coil to get by weekend and will look at it again monday 8/4/2008. same refrigerator.
Posted on Aug 04, 2008
  • thanks for asking. I went back on tuesday and everything was fine. could have been a loose conector plug. I also found wiring diagram in control console, where the cold-control is. there was no defrost info on diagram.
  • you could ohm out the defrost heater. thats the first thing to check. there is no defrost timer, the main circuit board controls defrost. its in the back.
Freezer not cold /on high it gets cold but wont freeze some items
Posted on Sep 26, 2008
Hotpoint refrigerator not defrosting
Is it not defrosting, or defrosting and re-freezing the meltwater as ice? Check drain clear. Further checks are 1) defrost timer 2) defrost heater 3) defrost klixon
Aug 08, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
Nov 24, 2010 | Hotpoint HSM25GFRSA
Where do I find the model number on my Hotpoint
In the last few years GE has placed the models serial label on the top center, top left or top right of the fresh food section. Older models had it behind the fresh food door at the bottom or behind the grille. Also there were a couple of years they placed it behind or to the side of one of the lower drawers.
Sorry about all the different locations. That's just how they did it.
Thanks.
May 25, 2010 | GE Hotpoint Top-Freezer Refrigerator
GE Model tfx24f defrost not working.
Replace the defrost heater and defrost thermostat located behind the freezer panel inside the freezer compartment.
Jun 12, 2009 | GE PSC23NHN Side by Side Refrigerator
Model HSS25IFMDWW "bottom" Fan is not operating.
you are correct in assuming that it is the evap fan. its purpose is to dissipate heat captured from the freon as it leaves the compressor. it could be that your defrost timer is faulty, but very hard to diagnose online.
Sep 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Defrost not working and freezing up, fridge not cold. GE hotpoint model #HSS25IFMDWW
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 05, 2008 | Hotpoint Refrigerators
HOTPOINT REFRIGERATOR RUNA ALL THE TIME COOLS POORLY
Yep, that is it. The heating element is open and/or the defrost timer is bogus. for parts go here. Search Over 2 1 Million Appliance Parts
Sep 09, 2017 | GE Hotpoint 21.8 Cu. Ft. Top-Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
1,561 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
