Internet connection I currently have DSL Internet with a Motorola 2210 modem connected to a Cisco Pix 501 firewall, 14 users on a Lan with a Windows Server 2003. I have been have problems with this Internet connection from the beginning of the installation 4 weeks ago. It appears that the PIX may be the problem with dropped connections. How can I get Internet service to my 14 users on the Lan without using the Pix Firewall. my server IP configuration is IP:192.168.1.10, Subnet mask:255.255.255.0, gateway: 192.168.1.2 and all of the users have static IPs between:192.168.1.50 and 192.168.1.99 What can I do?
  • 26 Answers
Lean and let your private technician do so about it. But, problem still occur do this, visit thier isp guide... visit thier site www.dsl-isp-guide.com...
Contact your internet service provider, they most about this, call their hotline and ask for assistance and they will give instructions how you can solve it, if still you can make what they instruct u online, if they won't offer to send you a technician ask them to send you and make a report of it.
Hope it will solve then..
Posted on Aug 01, 2008
EdiMax Br-6482nS doesnt give internet
A router is only used to connect devices together in a LAN (local area network). In order to get out to the internet you also will need a modem (cable or dsl depending on your service) You will also need to pay for service through an ISP (Internet Service Provider)
May 02, 2013 | Edimax Computers & Internet
Cannot connect to the internet
Check you DSL or cable modem to make sure it is connected tot he internet. If it is then you need to point your Linksys router to the DSL/Cable modem's IP address as the defualt gateway.
Feb 10, 2013 | Cisco Linksys E1200 Wireless-N Router
How do I connect it to a motorola 2210 modem
This FAQ is for configuring a BellSouth supplied Motorola/Netopia 2210-02-1006 with a generic third-party router that isn't specifically covered in the existing FAQs. If you have a router that is covered in the FAQs, I suggest you use that FAQ. This initial setup is all that is needed to configure and connect your generic router based network for FastAccess DSL. Any additional setup for features like DHCP IP ranges, port triggering, etc is out of the scope of this FAQ.
This FAQ has 4 Major sections:
Section 1 - Overview
Section 2 - Motorola/Netopia 2210 modem configuration
Section 3 - Third party router configuration information
Section 4 - Connections and power up
•The best configuration for networking a router with the Motorola 2210 is to set the 2210 to "Bridged Ethernet" mode and allow the third-party router to do the routing and DHCP functions. The 2210 is also a router with full DHCP functions and may not function correctly when connected directly to another router. Not changing the modem to Bridged Ethernet will result in double NAT'ing, increased latency, possible IP conflicts, or possibly a network that doesn't work at all.
Before proceeding both the 2210 modem and third-party router must be reset to default. Despite what the help desk tech tells you, resetting the modem does not put it into Bridged Mode.
• The BellSouth Installation CD and Connection Manager are not required to use this configuration.
• The third-party Installation Wizard CD should not be used in this configuration.
• Since BellSouth assigns static IPs via your username the configurations shown are applicable to both dynamic and single static IP customers.
• You must connect the 2210 directly to the computer's NIC to make the necessary changes before you connect the router, because you will probably be unable to access the modem interface after you connect the router. The reason is that the modem interface is 192.168.1.254 which is a local IP. By default, most routers do not have the capability to route a local IP out of their WAN port (where the 2210 is connected). Additionally, they may be on completely different subnets. After you have made the changes to the 2210 you can then connect the router and configure it for use with FastAccess. There are several alternatives around this problem. One method involves extra equipment (second NIC and a hub) and major configuration changes. The second method requires you to utilize the router as a simple switch and use the 2210's PPPoE and DHCP functions. Click here for more information.
•If you encounter any problems simply reset the 2210, connect it directly to your NIC, restart your computer, log into the interface, and start over again.
Section 2 ? Motorola 2210 Configuration
bred.gifStep 1
Verify that NIC cards (wireless or wired) are set to "Obtain IP Address Automatically". Completely power down the 2210 and the computer(s). Power up the modem and press the reset button on the back of the modem. After the modem has fully initialized connect the 2210 to the NIC and then power up the computer.
bred.gifStep 2
Open a browser session and enter "192.168.1.254" in the address field to access the 2210 GUI interface.
bred.gifStep 3
Enter your BellSouth Username followed by "@bellsouth.net" in the User ID field. Enter your BellSouth Password in the Password field. Re-enter your BellSouth Password in the Confirm Password field. Click on Next. Update the Auto Calender Update Configuration as desired and click Next. The modem will try to initiate a session and then return to the main menu.
bred.gifStep 4
Click on Broadband DSL Line from the top menu. Click on Configure Connection from the right menu. Select "Bridged Ethernet" from the Protocol pull down. Click on Save and restart the connection at the bottom. This will automatically restart the modem and the interface will return after the changes are saved. Note: functions like NAT, DHCP, IP Passthrough, and username and password will be disabled or irrelevant and can not be selected. After the modem has restarted, power down both the computer and the modem then physically disconnect the 2210.
Section 3 - Third-Party Router Information
bred.gifStep 5
After the PC is powered down connect one of the router LAN ports to the computer NIC and power up the third-party router and then the computer.
bred.gifStep 6
Open a browser session to access the router interface as per the router's user guide. Even though the interface will vary from router to router you must use the following configurations as a basic rule:
- Select Obtain an IP address automatically. Important Note: Use Obtain an IP address automatically even if you ordered a static IP.
- Select PPPoE connectivity. Do not select any other choice, even if you have a static IP.
- Enter your BellSouth Username followed by "@bellsouth.net"
- Enter your BellSouth Password
- Select "Keep Alive" or "Always On" (if available)
- Set "Maximum Idle Time" to "0" which is similar to "keep alive" and "always on" (if available)
- Select a redial or reconnect period of "180 Seconds" (if available)
- Enter "1492" in the MTU Field (if available)
- Save your settings (which will probably restart your router)
Section 4 - Connections and Power Up
bred.gifStep 7
Power everything down and physically connect the 2210, wired or wireless router, and any computer(s).
Pictures by Andy Houtz
bred.gifStep 8
Power up the network equipment in this order:
1) Motorola 2210 Modem (wait for DSL synch)
2) Third-party Router
3) Computer(s)
Open a browser session and go surfing!
bred.gifImportant Additional Information
•The 2210 has an "Internet" light that is green whenever there is an active PPPoE session initiated by the Motorola. Since you are using the Netgear to establish the PPPoE session the light will stay off. This is normal.
•You should check your tweak settings to optimize your new network. Reminder: If you are required to change your MTU, make sure that it is identical on all equipment (PCs and routers) in the network.
bred.gifCool Stuff
An online, html-based menu simulator program is available here. The simulator recreates the Motorola 2210 user interface and provides the ability to navigate menus; just like the real modem interface. It is for simulation purposes only and will not make any changes to your actual modem.
Jun 09, 2010 | NetGear WGR614 Wireless Router
I have a cisco linksys wrt54g2 v1 that I have hooked up to my verizon dsl modem. My computer says I am connected but it wont let me get on the internet. If I plug the ethernet cable from the modem to my...
Connect the cable from the LAN port on the DSL modem to any of the 4- LAN ports on the Linksys Swicth (not the port Labelled Internet), then from any of the remaining 4 ports then connect your computer. Also try using a cross-over cable to modem from the DSL LAN port to the Linksys.
Oct 24, 2009 | Linksys Wireless-G WRT54G Router
Connectin a linksys Befsr41 wired router to a Motorola 2210 modem
do one thing change the ip address of the LAN in the 192.168.2.1 in the router then you get it after that configuration you done right ok
Apr 14, 2009 | Linksys EtherFast Cable/DSL Router
SIte to site vpn/remote desktop
Open up the vpn client any any of the working machine, and then
click on
file>>save Prfoile>>give a name
Take a copy of that and paste it in your machine.
On your machine install the vpn client (Straight Forward Installation). Then
Click on Import Profile , Identify the location where you have pasted the profile (Which is copied from other machine).
You are done with that.
Mar 13, 2009 | Cisco PIX 501 Firewall
Vonage Phone Adapter and Motorola DSL Modem and Linksys NUltra
Your connection should be from DSL modem > internet port of Linksys router > Vonage phone adapter to port 1 of the router.
Nov 01, 2008 | Linksys WRT160N Wireless Router
How do I set up a VPN connection with PIX 501?
No worries. Just give it a try then let us know should you get any problems or follow-up questions.
Oct 15, 2008 | Cisco PIX 501 Firewall
DMZ HOST IN FVS 124-G
The Netgear FVS124-G is a superb combo VPN firewall DSL/Cable small business router. Loads of features and Dual Wan to boot. I highly recommend it's use in small businesses But... Keeping the necessary firewall, you are missing another component in a properly segmented network, a VLAN switch. It is highly customizable and gives you the configurability and speed you are asking for. Look at it's features here: ftp://downloads.netgear.com/files/FSxxxT_GSxxxT_smartswitch_UserManual.pdf The normal network security plan is: Internet -->Firewall-->Router (or Firewall/Router)-->VLan Switch-->Individual computers or VLan subnets. Using these two components together makes a more configurable and MUCH easier to setup network than using, say, one Sonicwall, or one CISCO PIX-501-BUN-K9 (which doesn't do VLan and you have to know Pix commands) You get FREE pre-sales and FREE post-sales support from Netgear, so call them on what makes sense for your situation. Sales Support (408) 907-8000 OR Email at: sales@netgear.com ZT3000 "Beta tester of "0"s and "1's"
Aug 03, 2007 | NetGear ProSafe FVS124G (FVS124GNA)...
Computers & Internet Logo
147 people viewed this question
David Payne
David Payne
