Question about Epson Stylus CX6000 All-In-One InkJet Printer
EPSON STYLUS CX6600
HI,
PRINTER HAS JUST START FLASHING THIS WARNING : PRINTER ERROR SEE YOUR DOCUMENTATION AND CALL SERVICES.
RED '!' IS ALSO ON .. LOOKED THROUGH THE BOOK THAT CAME WITH THE PRINTER, I HAVE NOT GOT ANY IDEA!
  • micknmare Aug 01, 2008
    I just had this problem. It occured after I changed ink cartridges.(Epson)
    I removed the cartridges and cleaned the chips on the cartridge and the ones in the printer. It took a few times of doing this and the printer started working again. Hope this helps!
    micknmare
Printer won't print
Posted on Aug 22, 2008
Get error message "Printer error: see your documentation and call service if necessary."
I found this on another website and it worked for me. It apparently resets the printer. Hope it works for you:
1.) power on (error message)
2.) press the "Stop (triangle)" and the "Colour copy" button and hold them
3.) press the power button to power off, still hold 2.)
4.) press the power button to power on, still holding 2.)
5.) the LEDs start to flash, then they stop to flash and the red exclamation mark starts to flash. Now release 2.)
6.) the LED should say: "Init EEprom"
7.) now press and hold the power button until the printer powers off and powers on again.
May 26, 2010 | Epson Stylus CX6600 All-In-One InkJet...
Bypass out of ink error on Epson CX6600
You can't bypass it. It need in in all cartridges, even though you are just printing black n white.
Weird eh?
Good Luck :0)
Nov 06, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Printer error
follow the link for downloads, faqs,troubleshooting, documents and manuals.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=41664
Mark
Apr 10, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Service required error
Ok.. aside from the fact that you've posted under the R300 Epson model thread you're still in luck.
The CX6600 has been documented (by me admittedly) with a complete guide to fitting an external tank and resetting the waste ink counter in the printer.
http://www.octoink.co.uk/store/pages/Epson-CX6600.html
Just to note: This is a commercial site but the information provided is generic and will help you fix the problem.
Feb 15, 2009 | Epson Stylus Photo R300 InkJet Printer
Red light
Your printer appears to have hit he "ink overflow protection counter" meaning that it thinks the waste ink pads in the base are full.
If the printer is in warranty, get Epson out to it. If not you can sort the error yourself using the rescue kit for the CX6600 available here: http://www.tradebit.com/filedetail.php/2379162-stylus-cx6600-rescue-kit-zip
Oct 13, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Hi Cath.
Not sure why you would need the R260 service utility when your printer is the CX6600 but I'll answer both questions and hopefully you'll get everything you need.
The CX6600 problem is a relatively easy fix thanks to an article I wrote after fixing up one of these for my wife a few years ago. It includes information on resetting the protection (waste-ink) counter as well as redirecting the waste ink flow so that should cover that side of things.
Right... as to the R260.. You can reset the waste ink counter on that printer using the IPR_A10 utility from Epson.. Information about the utility and links for download are provided on wasteink.co.uk
Hope that solves the issues you're having...
Martin
Apr 15, 2008 | Epson Stylus Multifunction Inkjet Printer/...
plz go to printer setting & clean durme
Mar 03, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Error message
OK guys quite a simple one....
with the printer on press & hold both the small red button ( far right ) and the green, colour copy button. Whilst still holding press the power button wait till the unit powers off. Press the power button again, shortly after the unit powers on, the lights flash, let go of the two buttons your holding. The screen shoul dnow say "Init EEPROM" if it doesn't repeat procedure till it does. Now press the green colour copy button once, screen should now say "Push power sw" Press and hold the power button, the unit will power off and on again, now release the power button and your printer should be working again. Now you should change your waste pads......
Dec 05, 2007 | Epson Stylus CX6600 All-In-One InkJet...
My Epson Styluss CX6600 won't charge
This may be very simple. Turn the unit off and lift up the top. On the forward side of the unit you will find a little 'slider switch'. This is the scanner unlock - toggle the switch back and forth several times and leave in the unlock position. Turn on the printer and all will be well.
Aug 26, 2007 | Epson Stylus CX6600 All-In-One InkJet...
EPSON STYLUS CX6600 - PRINTER ERROR SEE YOUR DOCUMENTATION AND CALL SERVICES
Could be the waste ink tank is full. Take a look in at www.fixyourownprinter.com. Aslso a useful download is the SSC Epson utility that carries out many 'managment' functioms and has its own forum also www.ssclg.com And last but not least - Epson customer support
Aug 06, 2007 | Epson Stylus CX6000 All-In-One InkJet...
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
130 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
