Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
Coolant Where do I find the coolant for the tv? What kind of store?
    Novelist:
    Champion:
  • 203 Answers
The coolant is clear ethylene glycol and can be purchased at any electronic parts store or online. Look up "projection tube coolant". Usually you can get by with only changing the liquid in the blue and green tubes, and be prepared for a messy job. You'll need a small bucket to drain the tubes into and make sure to pour a straight stream to avoid liquid getting into lenses. Just take your time and this repair is very simple to accomplish. Also, I use a marker all the way down the side of the tube and on mounting frame to assure that I don't get it turned around when reinstalling. Make sure you clean inside of coolant chamber thoroughly. Good luck, Russmann.
Posted on Jul 29, 2008
No owners manual What type of coolant is used for a 1998 intrepid 3.2 Thanks for your time
you could put in the kind that is compatible with all coolant types. all parts stores carry this type of coolant.
Aug 03, 2011 | 1998 Dodge Intrepid
What kind of coolant?
If it still has the Gm red coolant use the red coolant GM brand otherwise go to wal mart get genaric 50/50 coolant
Jan 23, 2011 | 1998 Pontiac Grand Prix
Will it hurt if i put the wrong fluid in my chevy malibu 2005 classic? Will a flush help keep from damaging it. What kind of fluid does it use?
on most gm prducts they take dex-cool anti freeze coolant. they say do not mix differant coolants together!! in the owners manual or a tag underhood will tell you what kind to use. if not then call any auto parts store and they should know. just do a good flush of coolant system and refill with proper coolant. have a good day !!
Dec 19, 2010 | 2005 Chevrolet Malibu
We have a Phillips rear projection tv, about 9 years old. The color has been getting progressively worse over time. Dark scenes are almost impossible to see. It almost seems that only blue and red are...
Tv have halo pictures and dulls colors?Yes,the tv have bad Coolant chemicals on those colors guns R,G,B CRTS tv Tubes.Must replaced those CRTS Coolant chemicals on those CRTS tv tubes.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a Coolant kit to replaced those CRTS tv Tubes coolant chemicals.
Nov 13, 2010 | Philips 55PW9363 55" Rear Projection...
What kind of special coolant is needed for a 2002
Its an extended life coolant. Adding regular coolant to the extended life coolant will ruin the extended life characteristics of the extended life coolant. Any good parts store will have coolant compatible with your vehicle.
When your cooling system is ready to be serviced (flushed) most shops will convert it to regular green coolant. Although the green coolant will not last as long as the extended life coolant it is much cheaper even with the more frequent service intervals.
Oct 03, 2010 | Chrysler Voyager Cars & Trucks
I NOTICED AN ANTIFREEZE LEAK THIS AM IN MY 2002 CHRYSTLER VOYAGER. SHOULD I TRY A STOP LEAK PRODUCT FIRST AND IF SO, WHAT KIND? ALSO, WHAT KIND OF ANTIFREEZE SHOULD I USE IF I NEED TO ADD SOME. IT DOES...
I would not use stop leak, I would try and locate the leak as it may just be from a hose which is an easy fix. If you can't locate it I would consider purchasing the UV dye for your coolant system then using a black light and you will be able to easily find the leak. As far as coolant if you go to your local auto parts store they have coolant that is made to be added to any kind of coolant and will be safe for your vehicle. Just make sure to note if it is pre mixed or not, if it is not you should be diluting it with 1 part coolant 1 part water.
Thanks,
Lee
Sep 27, 2010 | 2002 Chrysler Voyager
Almost 10 yrs old, kind of like a slight fog over the picture. what do i need to do?
Ur tv need coolant replacement.Tries websites Tv repair World.com,Tvrepairkits.com MCMElectronics.com to buy this coolant replacement.
Mar 10, 2010 | Philips 50P8341 50" Rear Projection...
What kind of coolant does a 1994 940 use?
on most cars if you dont know want kind of coolant to can buy a 50-50 mix
Jul 08, 2009 | 1994 Volvo 940
Convergence bowed
Hi
the coming out is glycol oil (coolant). If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages.
Looks like a picture tube problem.
Try to reduce the contrast, maybe it will be better.
Look into the three tubes while the TV is running, and observe the
picture quality of the three. If the red and green are crisper and clearer, and the blue's all hazy from bacteria growing in the coolant, then the fluid needs to be replaced. The CRTs of the colors that seem hazy need to be removed from the light box to be
serviced. The coolant needs to be drained, the CRT assemblies
disassembled and totally scrubbed clean and refilled, then reinstalled and converged. If the coolant is
clear, it can be a weak CRT.
Also the convergence STK ships might need to be replaced, and the soldering checked.
Good luck
Jul 08, 2009 | Samsung PCJ612R 61" Rear Projection...
WHAT KIND OF COOLANT SHOULD WE PUT IN A 2004 VW BEETLE. THE COOLANT IN IT NOW IS PINK. DOES IT MATTER?
yes it does because you should not mix the two even though there is coolant on the market says mix with any color but I am old school I plan on getting the pink out of my car and flushing the system to change to the green coolant
Jan 01, 2009 | 2004 Volkswagen Beetle
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
91 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
