Question about Intel Motherboard
Ms 7043 mb does not see 500gb sata drive please help
In IDE config there are no choices to select ATA or Sata, how do I update bios
  • nell2336 Jul 30, 2008
    Hi Sorry about the delay in answering> I have Ms7043 mb and yes I have eide ports, I was trying to install a Sata 500gb hd onto my board. It has the hookups for the Sata drive and my power supply (500w) has the connectors for it also,I have Intel 3.2 g cpu. Problem was when I went into Bios to see if drive was recognize, I could not get it to see the drive. I only have the one drive on the machine the hdd is a Samsung 500gb I am running Xp and have 1.25gb ram. I am sure that I have enough power and I have correctly did the manual installation. I just don't know what to do to make my system see harddrive. Oh yeah have tried putting jumpers in various positions to no avail.
  • Styme
    Styme May 11, 2010
    You have EIDE ports on motherboard ?
    What model and make of motherboard ?
  • 84 Answers
Possible the hard drive is not working
Posted on Jul 30, 2008
Blue screen when installing os
If you are trying to install the Windows XP from scratch on the computer, please BE SURE that you put the Hard Drive on "Compatibility" mode in BIOS, which was defaulted to "AHCI" (Compatibility is also known as IDE).
Otherwise, you will experience the "blue screen" issue. To change that setting, you need to do the following:
1. Press F2 when booting up the computer
2. Select 'Config', then 'Serial ATA (SATA)'
3. Change controller option to 'Compatibility' / 'IDE'
Jun 21, 2011 | IBM NetVista PC Desktop
I have a HP Asterope Motherboard The Sata HDD or the Sata CD/DVD cannot in not detected in the BIOS and the computer can not boot-up When I use a IDE drive on the Ide port, It works But I have a...
Reasons a sata device might not be recognized in BIOS:
(1)Serial ATA disabled, enter bios and enable SATA.
(2)Serial ATA cable defective
(3)Serial ATA drive defective
(4)Serial ATA cable defective
(5)Serial ATA device not plugged into power.
(6)Serial ATA power adapter defective.
Feb 26, 2011 | Computers & Internet
Installed to new 500GB SATA drives. The Bios does not list drives and no option for SATA drives. Please help.
try a bios update
your board is old (verry old) for SATA drive 500 GB
for bios update try on this page
http://www.asrock.com/mb/download.asp?Model=K7V88&o=BIOS
Feb 20, 2011 | Asrock K7V88 (K7V88 RAID) Motherboard
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
ASUS K8S-MX Motherboard, but when I connect IDE
How were the partitions created on the SATA? Are they RAID configured from the other system? Does the new motherboard have the same support for your HD as the other system? Check the setup in the BIOS screen on both systems to make them identical as much as you can. According to Tom's Hardware: "In the SATA port configuration place you have up to four "mode" choices: IDE (or PATA) Emulation, native SATA, AHCI, or RAID." Check this section. Circe@pctechsonline.com
Dec 13, 2009 | ASUS K8S-MX Motherboard
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
Can I run Sata and IDe Drives together?
Yes. You have two IDE ATA/133 sockets and two SATA sockets. So you can run a maximum of 4 ATA devices and two SATA devices.
Choose your boot order in BIOS.
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5VDC-X/e2466_p5vdc-x.pdf
Jun 30, 2009 | ASUS P5VDC-X Motherboard
SATA PORT NOT WORKING
The universally accepted HDD is the IDE, why are you trying to make it with a SATA? With a IDE you will avoid all the troubles. Yes! SATArequires a change in the BIOS. We can help you do the change, if you know how to do it. Playing with BIOS can cause the entire MB to burn out and destroy itself.
May 18, 2009 | MSI : MS-7061-020...
SATA hard disk size
Your Motherboard is SATA 1.0 - If you select a newer 2.0 drive you will have to place the 1.5gb jumper on the drive to be visible to the bios and operate at 1.5 instead of 3.0 gbs - http://global.msi.com.tw/index.php?func=searchresult&keywords=ms-7043&table=download
this is the link to the manual and drivers for your mobo
The other option is to purchase an updated SATA 2.0 controller card and then you can support all the new size HD's - here is the link to one such card for $29.99 http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2254079&CatId=1455 - if you are not ready to update the mobo, then this is a great solutions
Dec 19, 2008 | Computers & Internet
Intel Motherboard Logo
493 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
