Question about HP Office Equipment & Supplies
Unable to insert cartridge - HP Office Equipment & Supplies
  • Anonymous Dec 01, 2008
    how to incert cartridge
I brought the machine back to the shop got asked them to fit the cartridges.
Thanks for your concern.
Liam.
Posted on Jul 29, 2008
Inserting ink cartridges
You need to provide the make and model of the printer.
Nov 24, 2014 | Office Equipment & Supplies
I changed the black and color ink cartridges on my Lexmark 2500 printer but both of the ink lights continue to blink off and on. I'm unable to get the printer to reset by disconnecting the printer and...
Make sure you are inserting the correct versions of cartridges for your model. Try to re-seat the cartridges by removing and re-inserting the cartridges in the carrier. The black cartridge goes in the left carrier while the color goes in the right. Also, make sure you are using genuine Lexmark cartridges.
Jun 27, 2011 | Lexmark X2500 All-In-One Printer
Hi I have Brother dcp 350 printer. I have the error 46 unable to print/clean i cant get the printer back to normal functions. I have change the inks (all) and I am still get the same error message 46....
The messages unable to print, unable to clean, unable 36, error 46 and error 32 are all print head errors.
1. Remove all the ink cartridges from the machine
2. Clean the contacts on the cartridges as well as inside the machine itself with a small amount of warm water or alcohol on a cotton swab until no ink comes off on the swab.
Note: if any of the other cartridges are low, empty, leaking or bulging replace them
3. Then turn off the machine and unplug it for 70 seconds
4. Plug it back it and wait for the insert cartridges message
5. Insert the cartridges and check to see if the problem is still there. If it is it means the print head has failed and in order to fix this the print head inside the printer needs to be replaced. The print head is the part of the printer that puts ink from the cartridges onto the page
Unfortunately this can sometimes cost more to replace then the machine itself.
Apr 18, 2011 | Brother DCP-350C InkJet Printer
Unable to print from lexmark x2690. printer is giving the error E C 1 on display.
EC1 error message indicates that your printer having trouble recognizing one of your cartridges. You could try to re-seat the cartridges in the printer. Remove and reinsert both cartridges. You may also wipe the cartridge nozzles with a damp paper towel to clean it from dirts and clogs. If error continues, check w/c cartridge is causing the error. Insert one cartridge first, then close the cover. If no error appears, then insert the other cartridge. Replace whichever cartridge is causing the error to appear.
Apr 15, 2011 | Lexmark X2690 All-In-One InkJet Printer
10.00.00 supply memory error Unable to read cartridge data
Memory Supply Error 10.00.00 The printer is unable to read or write to the print
cartridge e-label, or the e-label is not on the cartridge.
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on toner cartridge as it is inserted into the printer. 1 - Make sure the toner is firmly seated into the printer. 2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer. 3 - Install another toner cartridge. 3 - Verify that the e-label connector is firmly seated in connector
Contact a local HP Authorized Service Center for further assistance.
Sep 01, 2010 | HP LaserJet 2420 Printer
Unable to install cartridge
Hello my friend, regarding on your problem in installing your cartridge you can see it inside in your printer. Open the printer cover then wait for the cartridge holder to stop swinging and stay in the middle then pull out the two platic attach to the cartridge holder. The plastic u pull out are the ink cartridge and then insert new ink cartridge then insert it again in the cartridge holder the close the printer cover and then you can print and used the printer. Don't forget to turn on first your printer before removing the cartridge.
Jun 16, 2009 | HP DeskJet F4280 All In One Printer InkJet
Have installed new epson black ink cartridge in c1100 printer. unable to press down locking bar on this new cartridge
Try re-inserting it again, L/H side should go in slightly ahead of the R/H. Give it a push & wiggle and it should lock in. An alternative method of fitting the cartridge is to open the top cover & remove the PCU. With the front cover shut you can rotate the cartridge "carousel" until the black is in the 2 O'clock poition when looking from the R/H side of the printer. You can now insert and lock the cartridge into place.
Please take a moment to rate this solution, thanks.
Apr 11, 2009 | Epson Aculaser C1100 Printer
Unable to insert ink cartriges
just open the front door while the printer is on. the carriage will move and stand to the cartridge install position.hold the black cartridge pust it little bit towards down till it leaves the lock and then get it ouside towards ur side.fit the new cartridge in the reverse procedure.
follow the same for colour cartridge.
thanks.
Sep 16, 2008 | Office Equipment & Supplies
Replacing cartridge
Try turning off printer at power point, leave 5 to 10 minutes and turn on again, if still not regognised, try new cartridge and if that works, take the one that didn't work back for exchange.
Jul 02, 2008 | Brother MFC 210C All-In-One InkJet Printer
Cradle jam after inserting ink cartridge, wont align
May-15-2008
in a HP-PSC-1210, replaced empty HP56 black-inkjet cartridge.
Afterward, printer gave error message AND unable to "dismount" the cartridge.
Finally discovered that an HP57 color-inkjet cartridge had accidentally been mounted/installed. A handyman relative was able to dismount the (wrong) cartridge.
Cradle did not actually jam, though printer would not print.
Apr 21, 2008 | HP Office Equipment & Supplies
32 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
