Question about Kitchen Ranges
We have a belling montecarlo 3000 oven in our caravan. When lit there is only a small flame even at thew highest setting which means the oven never gets very hot. Any ideas?
aborcass
  • 2651 Answers
SOURCE: Gas Oven, lights and terrable smell, and flame shoot out
yea sounds like you have a stive set for natural gas hooked up to propane gasm you need to convert that thing instructions are simple to follow in installation manual, or if you paid someone for installation id get them back
Posted on Feb 28, 2008
bigg t
  • 640 Answers
SOURCE: Oven pilot light will not stay lit
The thermocouple is bad this is the probe that sits next to the pilot,the pilot flame heats the thermocouple and then it sends a micro voltage to the valve to keep it lit.Goto hobartcorp.com and find your model then the part number.
Posted on Sep 04, 2008
  • 125 Answers
SOURCE: bakers pride pizza oven not lighting
Hello. Usually this problem is related to the pilot being dirty, and not heating the bulb for the safety device properly/hot enough to fully open the valve. If you have a general purpose mini torch you can heat the metal bulb near the pilot with it, if this is the problem, the safety will open, and the main burner will come on. CAREFUL, you are not on/around the main burner, as it will allow gas to come on to the main burner, and if your pilot is not working properly, might not light the gas. Get the pilot cleaned and adjusted.
or... :) I know... your safety has failed, allowing gas to the pilot, but internally is not opening, this requires replacement. Last though, it could be your thermostat, its last in line, and would require replacement. The safety, and the thermostat are mechanical valves, open or closed depending on its function.
If you have a more current type, they will have a combination valve, and thermopile/thermocouple that are electromechanical, your thermostat at this point can be either mechanical, or electromechanical. This system has a few more possible causes for your symptom.
You can tell which you have by how you light the pilot, have a red button on the front of the unit, by the on/off valve? this is the first type.
Have to open a small door to access a knob, turn it to pilot, and hold in? this is the latter type.
ask if you need more help.
Hope that helps, and thank you.
Posted on Feb 22, 2009
Bati99
  • 88 Answers
SOURCE: Water not hot enough coming from my power shower
The Redring Superflow 3000 was not produced after 2001. You can try calling the showerdoc 0131-538-4343 or going to showerdoc.co.uk
Posted on Apr 17, 2009
SOURCE: Oven Burners not lighting completely
It's the igniters. They increase in resistance as the elements age and decreases the current required to heat the spring element in the gas valve.
Replace both igniters.
Posted on Nov 29, 2009
What can I do about the hobs overheating - when on, they are only on the highest heat and can't be turned down.
THE only solution is to replace the regulators that control the hotplates.
Could prove to be expensive.
Mar 01, 2015 | Belling Ovens
Can't light oven in Wedgewood caravan oven
Do you have manual for proper lighting procedure? Do top burners have good flame?
Feb 27, 2013 | Atwood Mobile Products Atwood Wedgewood...
Oven wont stay lit
If you are talking about the little flame that is supposed to be burning at all times then you need to go to a hardware store and purchase a thermocouple. It is a small copper tube that sense's the flame. When working it will constantly burn a pilot flame so that when you turn on the oven it will ignite the gas in the burner. Once the burner is lit it will stay lit until the oven reaches the desired temperature. Replace the THERMOCOUPLE.
Sep 09, 2011 | Belling Solitaire G755 Gas Kitchen Range
I have a garland oven model st286 it wont light even though there is gas getting to it and the spark is working. It lights if you light it manually
Instructions
  1. Access the burners inside your oven by removing the access panel in the front of the oven or by opening the broiling drawer, depending on your particular model.
  2. Determine if the pilot itself is lit, since some ovens have a small flame on the pilot at all times that then grows and extends to the burner when the oven is turned on. The lack of a pilot flame indicates the oven thermostat is malfunctioning or there is a problem with the gas hose. Check the pilot itself to see if it is clogged with debris or grease that could be preventing the flame from staying lit.
  3. Determine if the pilot flame will grow if it is lit by turning on the thermostat. If the pilot flame doesn't extend, the thermostat itself likely needs replacement. If the flame is extending but the gas valve is not opening, the safety valve could be dirty or defective. The flame should be blue in color. A yellow flame indicates the pilot is dirty and is not burning hot enough to get the main burner to ignite.
  4. Light the burner on the top of the oven with a match if the igniter doesn't appear to be effective. If it lights manually but will not light automatically, the igniter is likely faulty. Do not do this if there is a heavy smell of gas in the kitchen, since there could be a risk of a fire. In that circumstance, turn the oven off, ventilate the room and call a technician.
  5. Listen for any sounds of gas hissing or a clicking sound indicating the oven is trying to turn on. If there is no response from the oven at all, the gas may not be functioning properly and will need to be examined by a technician for safety purposes
Jan 26, 2011 | Ovens
My hobart hgc-5 convection oven heats intermittenly. Heat goes on then off. I replaced the thermostat, ignition wire and ignition board. Still only heating intermittenly. What do I do?
I would replace the flame sense or clean it and make sure it is in the flame it will glow red you can see this if you remove the front and cover it is tough but can be done.also check to make sure it is not in a drafty location the air movement could blow the flame around and not hit the flame sense.it is just a metal rod with ceramic insulator.the flame is actually conductive.it will carry a small current.That is how the ign. module knows the flame is lit and dont just let gas pour in without being lit.
Oct 03, 2010 | Hobart HGC502 Stainless Steel Gas Double...
Pilot light is lit both on oven and stove top... previous user says to turn on gas and lite "sensor" or "2nd pilot" it stays lit as long as oven knob is on but oven burner does not light. "sensor" goes out...
On standing pilot ovens the maker uses a safety device to kill the gas in case the pilot blows out. As long as the pilot is lit the gas safety magnet hold the gas flap open inside the safety valve.To save energy the pilot has 2 flames. The standby pilot keeps the cooper/nickel probe/sensor warm so the oven will light faster, the 2nd pilot is much larger, only appears when the oven control is turned on and this is what opens that valve. So when you turn the oven knob on the gas leaves the control and goes downtown to burner land. If that pilot is lit and that slow opening flap inside that valve is open, then the gas will enter the burner tube and ignite when it hits the pilot. Pretty slick ain't it? So what can go wrong? With age the flap inside the safety valve will wear out, get weak, work a little, then take forever to light and eventually just goes bye bye. When you get ready to replace the valve it ain't gonna be adjusted exactamundo, you gotta tweak it. To do so after bubble testing for leaks and lighting the pilot you turn it on and observe the flames. It needs to be not more than half way up the flame spreader. If it is to small of a flame it will take forever to bake even a pie shell, if it is too much their could be burned bottom and in some cases fire hazards. OOPs.
Apr 06, 2010 | Magic Chef 9122 Gas Single Oven
It won't heat up... even though there is a flame
Check The Power Source
If the gas oven won't turn on, the first thing to do is check the power source. Most modern gas ovens are electrically powered. Check to make sure the oven is plugged in and the breaker isn't tripped.
Check the Heat Source
When a gas oven won't heat, the pilot light can also be set too low; if the pilot is lit but the oven isn't catching, adjust the flame.
Newer gas ovens use electric ignitors that produce sparks. If the oven doesn't heat, the ignitor could be broken.
Feb 05, 2010 | Ovens
I have a wall oven. The burner is lit but the
It means the the thermal bulb is bad or not lined up in the oven or it's not in the flame so it won't ignite untill you hit it, use a pair of plyers to move it directly intothe flame, if it still does not work relpace the themal gas bulb controller.
Aug 26, 2009 | Ovens
Oven won't stay lit
gas oven ignites and lights then flame goes out
Jun 17, 2009 | Belling Solitaire G755 Gas Kitchen Range
Oven heat
The problem with you oven is the FFD (flame faliure device ) also known as FSD (flame safety device) The way is works is that when an oven is ignited first time the heat from the low level flame heats phail at the end of the calliary tube which in turn increases the pressure within this tube forcing open the FSD valve to open allowing full gas through. when this fails it restricts the amount of gas flowing through it leaving the oven with a small flame. these are easily repalaced but the law says it must be done by a corgi registered engineer for gas safetey reasons...But 110 % that is your fault. HTH
Dec 04, 2007 | Frigidaire FGF316 Gas Kitchen Range
Kitchen Ranges Logo
46 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
