Question about Terminator Aquastar 125FX Tankless Water Heater: FX Hood Horizontal Vent
The unit continually gets at E2 error code. I have replaced the sensor twice and it still occurs. Can you give me a solution or point me to a repair person somewhere near Zip 64856?
  • 1 more comment
  • bgrubbs Oct 03, 2008
    I have the same issue with my Aquastart 250sx. Ihave been told to change the sensor, make the vent shorter and install a larger gas line. All three of those is from a differant Bosch tech. I will not be trying the larger gas line, but I wil shorten the vent to see if that helps. I'm gald that I did not change the sensor, since it did not work for you.
  • Anonymous Oct 16, 2008
    We have the same problem. We replaced the entire control unit which solved the problem for one year. We have replaced the sensors twice, shortened the pipe and installed a larger gas line. The whole control unit is very costly and since it has already been replaced once...I doubt we will spend the $300+ to replace it again.
  • Tim Hamlin May 11, 2010
    Your in a area were bosch doesnt show any trained techs. Maybe I can help you. What state are you in? and what model do you have?
  • 25 Answers
If this is a outdoor unit, and the temp gets below 36F this will always happen, unfortunatley. check the connection of the E2 temp sensor. Maybe its broke inside.
Posted on Jan 19, 2009
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
I have a ge air conditioner model AHM24DPH1 WITH an error E2 / E1. What do I do to possibly fix.how do I reset maybe
E1 is humidity sensor error unplug unit and then plug it back in.
E2 is Temperature sensor error unplug unit and then plug it back in this will clear codes. if codes come back on then you will need to replace sensors.
Jun 24, 2014 | Heating & Cooling
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
I had the E2 F3 code while I was baking something. Is it safe to eat the food that was in the oven at the time the error occurred?
F3
- E2 Oven temperature is too high (Cook
mode)
Replace
Oven temperature sensor (RTD)
Note: Applies to all
F3-E... codes.
Dec 21, 2010 | Whirlpool GR460 Electric Kitchen Range
E2 Code on Treadmill after starting
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
Jun 26, 2010 | York Barbell Home Use Fold-Up Treadmill
Error code "E2" of Gorenje K357
E2 - reporting a problem with the sensor of the evaporator in the refrigerator / in isolation 10_9_2011_3_02_24_pm.jpg
Jun 03, 2010 | Gorenje K357 / 2 Bottom Freezer...
My Heat will not work on my upstairs unit. I am getting an E2 error code on my carrier thermostat. what does that mean?
the e2 code on a carrier comfort zone thermostat is indicitive of the external safety sensors which are located on your units ductwork in the attic. the e2 code are the hpt/ and lat sensor codes. the hpt is the heat pump temperature sensor and the lat is the leaving air temperature sensor. you can pull off the cover of the panel and behind it will actually give you all the fault codes associated with you carrier tsat.each sensor has a certain ohm rating and if its out of the range it will fail. now as to the reasons for failure, the indoor coil could be dirty, filters dirty, refrigerant charge incorrect.
Dec 03, 2008 | Carrier Heating & Cooling
Error code E2 (with a picture of a wrench)
E2 means a problem with the fill. The wrench means to contact Hobart for service
Feb 27, 2008 | Hobart 29 in. AM15-1 Free-Standing...
Terminator Aquastar 125FX Tankless Water Heater: FX Hood Horizontal Vent Logo
110 people viewed this question
Top Terminator Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Terminator Kitchen Range Expert? Answer questions, earn points and help others
