Question about Magellan Maestro 4040 GPS Receiver
Need the power connector fixed!
How to get auth. number?
question: How do I get a return auth. number?
I have tried all afternoon to clear this problem and all i get is a run around.
Can someone hept me?
  • melisamc Aug 26, 2008
    the power connector seems to be broke. is there a retailer that repairs these or is shipping it out the only way.
  • Dorothy Fremder
    Dorothy Fremder May 11, 2010
    Greetings larsarge,
    Are you attempting to return the unit to Garmin or to a retailer?
    Some additional information might allow us to make an informed recommendation.
    Awaiting clarification,
    Dorothy
    Go Ahead. Use Us.
    Problem Solver:
  • 4 Answers
I got that code directly from Magellan when I cracked my screen. Call them. I had to set up a ticket with them. It did not cost anything to set up the ticket, but of course I had to pay for a new screen, which was around $85. This included shipping back to me.
Posted on Jul 30, 2008
GIVE THE MASSAGE ERROR E000000 XEROX CANON IMAGERUNNER 2520 MACHINE
Go through the following to clear the error: CLEAR > ENGIN > ERRCLR; and then turn OFF and then ON the power.
If this does not fix it check connection of the Connectors (Thermistor Connector and AC Connector).
If this does not fix it replace the Fixing Main Thermistor (Film Unit).
If this does not fix it replace the Fixing Assembly.
If this does not fix it replace the DC Controller PCB
Best regards,
Marius
P.S. if you are not in US the part number for EU region is FM4-8445-000
Dec 01, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
Ok for the thnth time here goes. the power connector is broken so that the battery cannot be charged. All I would like is to hane it fixed or replaced. I have the necessary sales slip. but at this...
For returns contact vendor customer service number, this is technical support.
Tell me vendor website address to find out contact.
Jul 28, 2008 | GPS
My canon imagerunner 2520 shows code e000002
Try to go through the following to clear the error:CLEAR >ENGIN > ERRCLR;turn OFF and then ON the power.
Check connection of the Connectors (Thermistor Connector and AC Connector).
Replace the Fixing Main Thermistor (Film Unit).
Replace the Fixing Assembly.
Replace the DC Controller PCB (PCB4).
May 08, 2015 | Canon Office Equipment & Supplies
Frigidaire gallery french door frig power failure generator kicks in and frig stays on Sabbath mode if I am away will my food spoil in this mode when power returns will frig return to normal operation
Good Afternoon Diane,
I understand you want to make sure that if you are away, and your Frigidaire refrigerator is in Sabbath mode, and there is a power failure, will your food spoil or will your appliance return to normal operation. Typically, your refrigerator should return to normal operation, in Sabbath mode. I kindly ask that you provide me with the model number of your refrigerator. Typically, this number is located inside on the left or right hand walls. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire Refrigerators
Need to change wifi passphrase to all numbers or all letters smart tv doesn't recognize letters and numbers
you can auth your tv to use wi-fi without password via mac from wify setup when detected.
disable passphrase from router and connect tv, auth tv and pus back passphrase and it should work, if not, change security type of router to another, WPA/WPA2 where it would let you enter any password you like.
Feb 26, 2014 | Computers & Internet
I need to connect to kiosk to auth orize my device
most devices has help number or instruction on how to work device.
Sep 01, 2013 | SanDisk Sansa E280 MP3 Player
I need speed controller for 2000E Freud router ?
Good afternoon John,
My name is Larry Boccioletti I am a factory auth service station for
Freud tools in Ontairo Canada.If the part is still available at the factory warehouse near me we can have it shipped as soon as you like.Let me know how I can help.
larry_boccioletti@yahoo.ca Halton Maintenance Centre 905 876 9981
Jun 28, 2012 | Freud FT2000E 3 Router
My TFT LCD Monitor, serial #MT-NI-DYLM2286 produces a light pink backround, but prints clear. Is there some way to return the monitor to a clear white backround?
rjmusvi, Sometimes the VGA connector at the rear of the PC needs to have it RESEATED 4-8 times to see if it returns the screen to NORMAL colors being displayed on the LCD panel!!! Do this with the POWER OFF to both PC and LCD monitor!!! Also check to see if any of the pins in the monitor to pc plug are bent or pushed down into the connector body. 12fixlouie on fixya
Dec 03, 2009 | Soyo Computers & Internet
IR 2000
Fuser error probally needs fuser replaced and the reset as below
try this
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
or this is explaination of the error and required fix from service manual.
E0000000
The reading of the main thermistor does not reach 30°C 1 sec after the main
power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
Main cause The fixing film unit is faulty. The main thermistor has an open circuit. The
fixing heater has an open circuit. The main power supply PCB is faulty. The
DC controller PCB is faulty.
Caution To reset the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action
1. Connector
Is the connector of the fixing assembly connected?
a. main power supply PCB (J8) <-> relay connector <-> heater
b. DC controller PCB (J320) <-> relay connector <-> thermistor
NO: Connect the connector.
2. Fixing film unit (thermistor)
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of
the connectosr (4-pin) of the thermistor for electrical continuity. Is it ¥W
(open)?
YES: The heater has an open circuit, or the thermal switch is open. Replace the fixing film unit.
4. Main power supply PCB, DC controller PCB
Press the Start key. Is the drive voltage of the heater supplied by the connector J8 of the main power supply PCB?
Main heater: between J8-1 (FSR1) and J8-5 (FSR COM)
Sub heater: between J8-3 (FSR2) and J8-5 (FSR COM)
YES: The heater drive power supply is faulty. Replace the main power
supply PCB.
NO: The thermistor control mechanism is faulty. Replace the DC controller
PCB.
Nov 18, 2007 | Office Equipment & Supplies
Magellan Maestro 4040 GPS Receiver Logo
42 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
