Message on LaCie Hard drive says Hard Drive is full, but I cannot clear
I have three items backed up on the LaCie D2 hard drive, with a total of about 15 Gb. But I keep getting the message that the hard drive is full. When I attempt to trash the last back up of my computer, there are about 20 000 items (!- I must have copied all what was in my Trash onto the Hard Drive). During the emptying Trach routine, I get a message saying unable to remove FMStrs.dis. Neither my Finder nor my Spotlight is able to find this file on my computer.
Clearly I have done something very stupid here. Can you get me out this trash I have buried myself in?
Thanks!
Martin Dives
  • unwiseone Jul 30, 2008
    More clarification. I have an Apple Mac OS10.4 so no C Drive. I have no idea what a FAT is. How to format the Lacie?
  • 1,031 Answers
Check the disk space on your drive to confirm the available space ,use disk manager to remove some files or delete some unwanted big files if uve done that restart the system for it to take effect .then check if more space is freed.give me feed back
Posted on Aug 11, 2008
  • 84 Answers
Mac don't normally need to be redone . Move the infromation off the drive as soon as possible , bad sectors on drive will cause drive to odd things , such as unable to delete files .
Posted on Jul 30, 2008
  • 19,396 Answers
Ensure that your system drive C: is not full, or you get similar troubles. When the external hard drive start giving this kind of troubles usually it is becouse of a bad FAT, the only solution is formatting the hard drive. Store your 15 GB elsewhere and format it.
Posted on Jul 29, 2008
Lacie d2 Quadra Ejects Itself
I've had issues with the lacie mini power supply before. I can cause some wierd issues. Unfortunately, it isn't the cheapest thing to replace but that's probably the best place to look first.
Oct 16, 2012 | LaCie 1TB D2 Quadra eSATA/USB 2.0/FireWire...
My Lacie Hard Drive only shows 9.99 mb capacity. and its a 2TB LaCie d2 Quadra v2.1 7200RPM U. It was just repaired by Lacie. Where's all the storage?
Please explain what you mean? When you plug in the drive it recognizes the drive but the size is showing to be extremely small?
Please let me know so I can help further.
Thanks!
EJ
Aug 05, 2011 | LaCie 2TB d2 Quadra Hard Disk v21
I had 4 LaCie 2TB Big Disk Quadra, Item 301343U. They are connected to a Nitro 8-PORT FIREWIRE 800/1394B PROFESSIONAL (N8PFW8HR) hub. The hub is connected to a LaCie Firewire 800 PCI card. I am running...
Let's not take this as a solution so much as an intuition. I believe you may have run up against a limit of physical disk space that XP can administrate.
DO me a favor and don't give my rating a thrashing if I'm wrong.
Best Regards,
Marcus
Sep 23, 2010 | LaCie Big Disk Extreme with Triple...
Lacie D2 HD is unaccessible
Try this URL :- it's on the microsoft support site and appears to deal with your issue
http://support.microsoft.com/kb/330174
Jul 21, 2010 | LaCie d2 Extreme (300793U) 500 GB Hard...
Lacie hard drive won't turn on
My 1TB Lacie suddenly won't power up (no sound, no blue light). It turned out that I might have worn out the on/off switch over the seldom-use 4 years of usage. I push and flip the switch multiple times, and the Lacie came back to live and mount normally. I will just leave it at the On setting and simply pull the power cord when i want to switch it off.
Obviously, Lacie failed to do QA on the on/off switch because my 4 years usage did not totalled to more than 10 on/off per month.
Mar 09, 2009 | LaCie (301074) 80 GB Hard Drive
Problem with LaCie 500 GB d2 Quandraq
Contact Lacie support for a new power supply. I had the same problem, contacted Lacie support, they sent me a new power supply with power cord and all is well now.
Sep 22, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie Big Disk
Fixya is unable to suggest parts sources.
Dec 17, 2017 | LaCie 301294U 1TB Big Disk Extreme + with...
External hard drive
500Gb Lacie D2 Quadra with the same problem of flashing led and not mounting on the desktop (Mac G4 Mirror), traced to the power supply (57w) going down on power, both 12v and 5v supplies are available but the main power to run the drive drops to below an adequate output, hence the clicking and whirring evident from the drive with simultaneous flashing led.
Testing with another Lacie power supply (250Gb D2) this time a 34w unit got the drive up and running, however, and this is the reason for this post, this lower power PSU failed a week later whilst waiting for a warranty replacement from Lacie (5 weeks and still waiting for the new PSU from them. they have no stock)
Message for all Lacie D2 users, check the power supplies first, test with another Lacie PSU, do not run the drive on a lower rating (34w) PSU it will fry it and leave you with another failed power supply.
If you are in a tight spot use the temporary power supply to move your data to another drive and get the correct 57w power supply before running the drive again.
Don't do as I did assume any Lacie power supply will run any Lacie hard drive, they won't, fortunately I had a second back up, but am 2 drives down and no new PSU's available to buy anywhere.
Try and purchase another spare 57w power supply, something all D2 users should do for long term security, as these do not seem to be very reliable and getting warranty support from Lacie on these is currently impossible.
The lack of 57w power supplies from Lacie and its distributors across the world is surely a warning to be noted!!!!!!
Buyers beware!
Aug 08, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie d2 external drive
I support the comments of (fire sine) I have the d2 120gb Lacie and it was down for two years.  I took it to my apple guys and they said that I needed to go to a data recovery service which would cost a gang of money.  Come to find out, when I decided to update my internal hard drive on my Mac Pro, I had to buy a SATA, IDE, USB 2.0 adapter to back up the internal and transfer to the new internal. Long story short, something said, Hey try and open the Lacie and bypass the board in the enclosure and connect directly to the Western Digital drive inside.  AND WHALA! I got my info, so all I need is a new enclosure.
Sep 24, 2007 | LaCie d2 (300769) 200 GB Hard Drive
Computers & Internet Logo
386 people viewed this question
David Payne
David Payne
