Question about Whirlpool LER5636P Electric Dryer
The Dryer wont start.
I have an electric dryer that all of a sudden lost power. It will not come on nor will it make any ticking noise if the timer is set. The breaker was not tripped. It will not do anything.
  • jcurl42 Aug 25, 2008
    Some times the dryer works and sometimes it won't start. When I rotate the drum backwards it works again so I know it's not the power source. Any suggestions?
  • watsonclan Sep 06, 2008
    my LER5636P lost power and will not come up. The lamp in the tub works
    and it appear the timer works. Just can't start the dryer
CHECK THERMAL FUSE CUTS POWER TO DRYER
Posted on Aug 20, 2008
  • 30 Answers
Often the main wiring connection from the house at the dryer burns, and the connection breaks. Verify the connection at the back of dryer, and if visually you can't she the brake then check for voltage (240). If there is not enough voltage at the terminal block-replace the terminal block and the cable.
Posted on Aug 11, 2008
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
Dryer makes a ticking sound when the door is closed but wont start. If I put the dial on off, then the ticking goes away....help
the ticking noise is the timer, you dryer is not starting:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Feb 25, 2011 | Maytag PYE2300AY Electric Dryer
Kenmore dryer makes the ticking noise but when we push the button to start the dryer it wont start. What should we look at?
Please check your Thermo fuse
and ticking noise should not be there unless the dryer is on which means that your timer is acting up
Oct 30, 2010 | Dryers
Dryer stoped working mid cycle like it lost power and wont restart. Check breaker and electric allready.
maybe your timer motor, Tim:
Oct 25, 2010 | Maytag HYE3658AY Electric Dryer
Dryer stopped all of a sudden. Gets power because i can here the timer ticking but the light and roller does not turn on
Possibly lost one of the the three power wires. The heater uses the 220v but the lights and motor use 110v from one side and the timer from the other. should be a schematic on the back of the dryer.
Oct 03, 2009 | Maytag Dryers
Kenmore 90 series won't start timer ticks
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Crosley Dryer won't start
https://www.partselect.com/Models/CDE22B6V/Manufacturer/1/
This could be one of several things. There is a switch connected to the belt on the drum and if the belt slips of breaks the dryer wont start. There is also a possibility the timer is worn out
Oct 22, 2017 | Dryers
Electric dryer wont heat or turn off
there could be a temperature switch that tripps off. look at the diagram and trace also the power to the timer motor. it seems that you lost your power to your timer motor that is why the timer stays @ what ever setting you set it.
Feb 11, 2008 | Kenmore 63942 Dryer
Whirlpool LER5636P Electric Dryer Logo
121 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
