Question about Teac Audio Players & Recorders
What oil do I use to lubricate part that requires oil ?
  • 682 Answers
Use any good brand lubricant contact cleaner from radio shack near you.
Posted on Jul 28, 2008
How do you lubricate the machine?
Your manual should have directions on how to oil and lubricate your machine. If you do not have a manual a make and model number is needed to help you further.
Jul 09, 2017 | Sewing Machines
I have a Ryobi 4-cycle S430 weedeater. Do you use regular gas? If so,what type of oil do you use?
A 4-cycle engine requires regular gasoline whereas a 2-cycle engine requires oil to be mixed with the gas.
A 4-cycle engine requires regular gas in the gas tank and engine oil in another tank. Your owners manual will tell you what grade of oil to pour into the oil tank compartment of the weed-eater.
A 2-cycle engine requires regular gas plus a certain amount of 2-in-1 oil mixed with it. The oil that is mixed into the gas container and shaken together to "mix" the gas and oil before pouring into the gas/oil tank helps to lubricate the moving parts of the engine like the piston movement between the piston and the pistons' wall known as the cylinder wall. Also the oil aids in the creation of a tight seal which causes compression to occur that is responsible for optimum operation of the engine itself. It also provides lubrication to the piston rings and reduces friction as the piston rings push against the cylinder wall.
4-cycle engine oil can be purchased at any oil store like Canadian Tire/Sears/Napa Auto Parts. Just ask for oil for your weed-eater and let them know that your engine requires 4-cycle engine oil. I am sure the service clerk will point you in the right direction.
I hope this helps!Have a great day!
Apr 01, 2017 | Ryobi Garden
Gearbox - digging chain - best lubricant?
no lubricant
grease /oil holds grit in place and acts as a grinding paste on the moving shafts and parts
the bearings will be sealed but if you have to add oil to the box then the recommended oil is required
May 11, 2016 | Garden
Lubricating oil for kenwood a701a
They are lubricated with food grade grease, not oil. Any oil dripping out is coming out of the grease as the grease gets older and starts separating liquids from solids.
Oct 05, 2014 | Kenwood Chef Major A701 Food Mixer
Not sure where to oil my sewing machine
Each machine has different lubrication requirements look to your user manual for lubrication points and how often to lubricate.
Apr 21, 2014 | Sewing Machines
Do they use oil
Bostitch was purchased by Dewalt. Manual can be found here:
Here is what manual says about lubrication:
Frequent, but not excessive, lubrication is required for best performance. Use BOSTITCH Air Tool Lubricant, Mobil
Velocite #10, or equivalent. Do not use detergent oil or additives as these lubricants will cause accelerated wear to
the seals and bumpers in the tool, resulting in poor tool performance and frequent tool maintenance. Only a few drops
of oil at a time is necessary. Too much oil will only collect inside the tool and will be noticeable in the exhaust cycle.
Oct 09, 2012 | Stanley Bostitch MIIIFN Flooring Nailers
How many quarts of oil is require on a 2003 electra glide for a oil change
Hi Anonymous, oil capacities on touring models:
1. Engine oil 4 qts. with filter Hd Multi Grade 20w50.
2. Transmission oil 20-24 oz HD Transmission Lubricant.
3. Primary oil 32 oz. HD Primary Chaincase Lubricant.
Good luck and have nice day.
Jun 23, 2012 | 2001 Harley Davidson FLHT Electra Glide...
How many quarts of oil does a 2001 harley electra glide standard require for an oil and filter change?
Jan 25, 2012 | 2001 Harley Davidson FLHT Electra Glide...
What is the capacity of the transfer case and exactly what fluid do i use
GM Full-Size Trucks 1980-1987 Repair Guide
The type of lubricant used in the transfer case varies with model year and type of transfer case. Refer to the list below for the type that applies to your truck.
Conventional transfer cases require SAE 80W or SAE 80W-90 GL-5 gear lubricant.
Full time systems use SAE 10W-30 or 10W-40 engine oil.
Conventional transfer cases require DEXRON®II transmission fluid.
All transfer cases require DEXRON®II transmission fluid.
All transfer cases except the K30/35 series require DEXRON®II transmission fluid.
For fluid recommendations for the K30/35 transfer cases refer to the owner's manual.
Fig. Model 208 Transfer Case
Check the four wheel drive transfer case lubricant level every 4 months or 6,000 miles.
  1. With the truck parked on a level surface and the parking brake firmly applied, remove the filler plug from the rear of the transfer case (behind the transmission). Be careful not to take out the drain plug at the bottom.
  2. If lubricant trickles out, there is enough. If not, carefully insert a finger and check that the level is up to the edge of the hole, EXCEPT in full time four wheel drive cases should be 1 /2 in. below the hole.
Lubricant may be added, if necessary, with a funnel and tube, or a squeeze bulb.
Part Time Systems
No intervals are specified for changing transfer case lubricant, but it is a good idea for trucks that are worked hard or driven in deep water.
  1. With the transfer case warmed up, park on a level surface and apply the parking brake.
  2. Slide a pan of a least 6 pts. capacity under the case drain plug.
  3. Remove the filler plug from the rear of the transfer case (behind the transmission). Remove the drain plug from the bottom.
  4. Wipe the area clean and replace the drain plug.
  5. Add lubricant with a suction gun or squeeze bulb. Conventional transfer cases require SAE 80W-90 GL-5 Gear Lubricant.
  6. When the lubricant level is up to the bottom of the filler hole, replace the plug.
Full Time Four Wheel Drive
The full time system requires oil changes at regular intervals, according to the amount and type of work done by the unit. Trucks used for normal on-off road work should have the transfer case oil changed at 24,000 mile intervals. When used for heavy duty work, trailer towing, snowplowing, and the like, the interval should be halved to 12,000 miles. If the truck is exposed to extremely dusty or muddy conditions, the oil should be changed at 1,000 mile intervals.
The transfer case oil must be hot before changing. Drive the truck until the engine has reached normal operating temperature, and park on a level surface.
  1. Slide a pan of at least 8 pts. capacity under the case drain plug.
  2. Remove the filler plug.
  3. Remove the lowest bolt from the front output shaft rear bearing retainer cover, and allow the lubricant to drain. Be careful; the oil will be hot. There may be a drain plug. If so, remove that instead.
  4. Remove the six bolts on the left (driver's) side of the case which secure to P.T.O. (power take-off) cover. Remove this cover and allow the lubricant to drain out.
  5. Remove the speedometer driven gear from the upper left rear corner of the case.
  6. Use a suction gun to remove as much lubricant as possible from the case cover location and the speedometer gear location.
  7. Install the speedometer driven gear, the P.T.O. cover, and the lowest bolt or drain plug.
  8. Add approximately seven pints of oil through the filler plug opening. The proper oil to use is 10W-30 or 10W-40 engine oil.
  9. Check the fluid level and add sufficient oil to raise the level to 1 /2 in. below the filler plug opening. Replace the plug, and wipe the surfaces of the case and skid plate to remove any excess oil. Drive the truck and check for leaks.
I really hope help ypou woth this (remember rated this help) Good luck.
Oct 16, 2009 | 1983 Chevrolet Silverado
My KitchenAid mixer makes a sound like it needs oil or lubrication. Please advise.
Kitchenaid mixers are overpacked with oil to last the lifetime of the mixer, and do not require lubrication unless you have lost in excess of .25 cups of oil.
Please post any tell-tale signs that are indicating to you that a replenishment of oil is needed.
Jul 04, 2009 | Food Mixers
47 people viewed this question
Top Teac Audio Players & Recorders Experts
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
