SOURCE: bissell proheat self propelled series
I'm having the same issue and it was the pump. The metal drive gear sheared off of the plastic pump shaft. I JB Welded it back together, now I just need a schematic to reassemble the cleaner.
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
SOURCE: bissell proheat 7 will not spray water or cleaner
Thanks to many others who have posted on similar problems -- water
and/or solution sprays through the handheld tools, but not through the
main machine.
As others have suggested, I removed the water
reservoir, which exposes the 2 main water sprays mounted above the
rollers. Using, pliers, I carefully slid the clips back. Gently but
firmly removed the two red nozzles.
Elsewhere I have read
suggestions to just do one nozzle at a time. However, I found out that
if you remove both red nozzles, you can then blow through one side and
it will come out the other. In my case, that dislodged a nice
collection of crystal-like chunks (guessing it may be crystallized
residue from the cleaning solution).
There was also a bit of
blockage in one of the red nozzles, which I cleaned out. Make sure you
can blow through both of them with little resistance.
Reassemble:
Push red nozzles back into hoses. Using pliers, reposition sprung clip
back over the red nozzle. Snap nozzles back into place. Refill tanks
and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
