Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Seeing double turned my TV on the other day and there was a double image on the screen so i set the convergence as best I could. Still seeing double
  • JVC Master
  • 8,617 Answers
Need to replace the convergence ICs and possibly the convergence resitors . You need STK392-110 ICs you can get the ICs and the convergence resiistor kit for your model at the following link with free instalation instructions
http://servicemanuals.vstore.ca/
Posted on Jul 28, 2008
I have double image I am looking at array but not
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 05, 2009 | Hitachi 50DX20B 50" Rear Projection...
Seeing double
You need to replace the convergence board in your tv .
Also you have mentioned it is 5 years old so its time to replace it .
But it will not be cost effective one .
SAM ANDERSON
Sep 21, 2008 | JVC AV-48WP74 48" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
*Screen Looks 3-D
*Colors wont align
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Double Image Red and Green
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 08, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Double picture on left side with red projector on Hitachi 55UX58B
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Oct 20, 2008 | Hitachi 55UX58B 55" Rear Projection...
DOUBLE IMAGES
there is a problem with tthe convergence section this is something a tech can do
Sep 23, 2008 | Toshiba TZ50V51 50" Rear Projection...
Distortion and double imaging
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Sep 07, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Double image.
First when replacing the small sig. board a full convergence must be done,the other trouble is most likely the front panel buttons,this is a repair a service center must do,sorry best i can do from here
Mar 10, 2008 | RCA Scenium HD65W20 65" Rear Projection...
Double image, blue and yellow images
convergence ic are going or have loose connection in the convergence amp ic area.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 15, 2008 | Hitachi 43FDX01B TV
DOUBLE IMAGES
How do we adjust convergence? I went to the service menu and all I see is alot of settings none of which help me out.
Can anyone explain this in further detail?
TIA
Aug 26, 2007 | Sony KP-53HS30 53" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
67 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
