Freezers Logo
Posted on Feb 26, 2011
Our freezer is not de-frosting, there is a build up of ice
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Feb 27, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
284
Points
7
Sometimes ice will build up because of hummity. dont know where your at but best thing would be to get everything out and turn off . and defrost manually we used to do this on old friges with a hairdryer. it takes a while. when you start it back up make sure the seal seals good and if ice builds up again the your going to get to call repair man. Hvac and all compressors go through defrost mode. You may have so much ice it wont defrost, also a full freezer works more effecient than empty.
We have a Crosley WCF20/F upright frost free freezer. We get ice buildup on the bottom Shelf and can't pull the basket out. Is there a drain plug or something else? The freezer freezes all food
A frost free fridge or freezer has a heating panel that is switched on for a short time at the end of each cooling cycle to melt any frost that has formed over the evaporator.
The resulting water droplets are channeled through a drain to be collected in a tray mounted on the motor where the heat from the motor will evaporate it.
The drain of your freezer is probably blocked and has caused an ice build up. You will probably have to at least partially thaw and de-ice in order to find the drain and clear it. This is especially difficult as cold plastic is very brittle and easily broken. Great care is needed when clearing the drain as it is possible to dislodge the drain tube and if unnoticed it will saturate the insulation and render the freezer inefficient at best...
Error code 24 e. Freezer defrost error. Now what do I do? Help Please!
You have a problem in the de-frost system. Could be a timer, very common, heat element, very common. Look on line or your owner manual and see what that code is telling you. The average person can not make this repair. Hope it is under warranty.
5helpful
2answers
Icing up
I've just had a similar problem. I fixed it by removing the large panel on the back of the inside of the freezer. I found a large build up of ice at the bottom of the freezer which seems to have developed because the drain hole at the bottom of the freezer was blocked. I defrosted the ice, cleared the drain and now the freezer is working fine.
Freezer builds up frost and ice too quickly.
Either the door gasket is not sealing well or the unit is low in refrigerant.
Sep 24, 2009 • Freezers
1helpful
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Kenmore freezer upright frost build up on door
first just take it out and clean that one carefully .And then set correctly and observe it,s working condition.then also it's not working means show it to ur near by worker those who repairs it
FREEZER TOO WARM
Hi, Are you seeing ice or frost? Is frost building up on the freezer back wall? I can help you, just need to be clear.
Thanks
Vic
May 24, 2009 • Freezers
4helpful
2answers
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 • Freezers
2answers
Frost in Chest freezer
Not much you can do except ensure you have a tight seal and not to open it more than you have to.
1helpful
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
