Question about SATO Office Equipment & Supplies
Sato CX 400 EX1. Printer forward 1/2 inch too much tag stock per printing job. Tag stock does not retract when printing job is initialized.
SOURCE: error 1
I tried all three suggestions. Finally in despiration I took the plastic cap from a pen and forced the roller (feeds paper) to move, put the paper back in and closed the cover. When I tried to print it worked just fine.
Posted on Aug 25, 2007
jaylex
  • 417 Answers
SOURCE: printer error
Hi there guys reinstall the driver using PCL 5e as the program you are using may not understand the PCL 6 newer driver. Try this
Hope it helps
Thanks J
Posted on Jan 19, 2008
  • 19 Answers
SOURCE: dymo lextra tag xr
I was able to find the following error codes, however I realize they are for the Lextra tag QX50. I was unable to find codes for the Xr, so I e-mailed Dymo and will post a comment on this as soon as they get back to me.
For now, here are the QX50 codes, just in case they help:
LetraTag QX50 Error Codes trnsp.gif Question An error is dispalyed on screen when I attempt to print a label with my LetraTag QX50. How can I resolve this?
trnsp.gif Answer Error
Solution
Error 1
(Tape jammed or low battery)
  • Replace the cassette
  • Replace batteries
Error 2
(Big Font cannot be selected with characters in memory)
  • Select another font size
  • Select Big Font before entering text
Error 3
(Big Font cannot be selected with: box, underline, 2 line, or lower case)
  • Select another style format
Error 4
(Memory buffer is full)
  • Delete some of the entered text
Error 5
(Text is bigger than defined length)
  • Specify a longer tape length
Error 6
(2 line cannot be selected with the format)
Posted on May 19, 2008
Daxtor2007
  • 85 Answers
SOURCE: Zebra TLP 2742 printer only prints out left side of the tag ???
Ok
First Properly connect all cables to new PC.
download new latest printer driver form given link blow
http://ftp.nicelabel.com/software/drivers/zebra.exe
download and install the new driver and try to print.....
if any problem persist please tell me ..what the OS you use in ur new Business pc.
well dear you POST ur this Question on "YahooAnswer" and "http://boston.craigslist.org" that great
may be it is helpfull to you.
happy to help u..
Posted on Nov 21, 2008
  • 899 Answers
SOURCE: TLP 2742 printer only prints out left side of the tag??
either your ink level is low or empty , or you might be having a problem with the wire strip that goes to the printer head, or even a faulty ink cartridge ( you can only get so many prints on each ink cartridge) how lomg have you been printing on the cartridge? have you tried to clean the cartridge?
electech
Bar code printed on sato m5900 Rve printer will not scan. Same bar code printed on HP laser WILL scan. Font used is ID Automation 39 - prints at 6 pitch
Are you printing in thermal transfer mode or on thermal direct stock? Sounds like your image is not black enough for your scanner. Things to check: adjust printhead temperature, change ribbon stock, change thermal-direct stock, adjust scanner's sensitivity.
Jul 18, 2011 | SATO M5900RVE Printer
Zm 400 printing issues
check under the printer driver to make sure the right media is set
Mar 31, 2009 | Zebra Z4M Printer
Part of the tag does NOT print out.
DID YOU CLEAN THE PRINT HEAD AND BRY IT GOOD, CHECK THE SOFTWARE.
MAKE SURE THE MATTERAIL IS THE SAME FOR EACH TAG, DIFFERANT TYPE OF MATERAIL WILL GIVE DIFFERENT TYPE OF PRINT AND THE FINAL PRODUCE WILL BE TOTALY DIFFERENT.
SEE IF THE PRINT HEADS HAVE THE SAME CLEAR-INES, SEE IF THE HEADS HAVE APART THAT CAN MAKE THE PRINT A BETTER PICTURE OR BETTER QUILITY OF PRINT.
SEE IT THE PRINT HEAD HAS ANY TYPE OF HEAD ADJUSTMENT, REQUEST A SERVICE MANUAL FOR THIS TYPE OF ADJUSTMENT AND YOU WILL NEED SOME FILLER GIUDGES TO MAKE THAT SDJUSTMENT THE SAME ONES YOU USED TO FIX THE OLD CAR WITH THE FLAT SILER ONES
ROD GANDY
Feb 17, 2009 | Zebra Printer 140-751-00000
electech
Nov 21, 2008 | Office Equipment & Supplies
Sato 8485se problem whit the papaer ajustment
1-go to the menu
2-media settings
3-Label Lenght ( adjust lenght here) back out and save settings
Aug 26, 2008 | SATO GT408E Thermal Label Printer
Pagesetup Sato CX400 - 2,5x11cm(Hight,width)
Install the software label gallary which has come with Printer CD, design the label over there. It will work
May 08, 2008 | SATO CX400 Thermal Label Printer
Print jam on the thermal TEC B-572 TXP -3.5
The purpose of the knob if to change the position of the sensor. If you look at the sensor when turning the knob you'll find out that it moves forward (towards you) or backwards (away from you) This should allow you to place the sensor at the correct position. Further more, there are two holes on the plastic flag. the hole nearer to you is the transmissive sensor and the other is for reflective. Try to place the sensor at the correct position.
Mar 25, 2008 | Toshiba TEC B-572 Printer
471 people viewed this question
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Howard
Howard
WTF Chuck.....
WTF Chuck.....
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
