Question about GPS
Ok for the thnth time here goes. the power connector is broken so that the battery cannot be charged. All I would like is to hane it fixed or replaced. I have the necessary sales slip. but at this point, I don't care what it cost to fix. please send an return auth. number.
  • larsarge Jul 29, 2008
    Thanks I still need permission to send the unit somewhere. so far noone has helped in this regard.
  • 689 Answers
Is power connector broken at the charger side or the device itself? If you are able to tell the model we can check for you possible options, There are also universal chargers that you can take the battery out and put it into charger.
Good Luck
Posted on Jul 28, 2008
    Sergeant:
    Champion:
  • 347 Answers
Hello larsage,
What is the brand and model of your GPS?
Have you tried to contact the brand of your GPS?
    Genius:
  • 3,422 Answers
HI,
Please give the model number of your GPS device.
  • 19,396 Answers
For returns contact vendor customer service number, this is technical support.
Tell me vendor website address to find out contact.
Whats broken in charging connector?
Normally when you have a broken charging connector on a laptop. It boils down to either a bad power supply. Or a broken port on the laptop itself. If you have a voltmetor you can test the power supply. If it is dead replaced it. If it is on the laptop itselp very very few people will take the time to fix it. time for a new laptop. Good luck.
Aug 20, 2014 | Acer Computers & Internet
OW TO GET MY ACET ASPRE ONE IT STOP BLACK SCHREEN NO POWER
Step by step troubleshooting.
Verify power outlet is good
Verify power adapter is good
verify connection to computer is good
fully charge battery
test
=======do this
Check power source, plug known good light into AC receptical.
If AC cord has connector to power block verify it is properly seated.
plug adapter into AC outlet
Verify Power is present at power connector with another similar computer or voltmeter. (12V to 20V)
When plugged into computer, charge (not power) indicator MUST light either red, amber, or green. If not, connector on computer may be broken.
leave overnight or until charge light is green
turn on normally.
most likely causes:
- loose connector
- broken wire from power adapter
- broken power plug on computer.
- anything else is probably beyond ur capabilities to fix.
Aug 10, 2014 | Acer Aspire One PC Notebook
My advent battery would not charge so i bought a new one and it still wont charge having to run my laptop from the mains
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Mar 12, 2011 | Advent Netbook
Battery won't charge
Check for a DC connector problem:
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it's still under warranty, it would be fixed at no charge to you.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Feb 12, 2011 | Dell Inspiron 1501 Notebook
I goofed. I have a Toshiba Satellite A105-S206, and I will make this as brief as I can. I have had a string of super cheap power supplies that I have been using. The most recent one stopped...
Feb 06, 2011 | Toshiba Computers & Internet
Computer is not charging the battery.
Your DC connector is probably loose from the system board:
Jan 05, 2011 | ASUS F8Sn-C1 PC Notebook
I have a compaq nc6000 which wont boot up it trys to fire up then it goes off i have got to run but then it went back to this not booting up
Check and see if your DC connector is loose:
Jan 02, 2011 | Compaq Presario Notebook
Got the scooter for xmas last year -- has been used approximately 5 times. SHows battery is fully charged. Will not go. Need help.
hello,,i'm not overly familiar with these but,,here goes,,,,if it is reading fully charged,,but it will not go,,,,if you have an electrical tester,,,plug the red probe into the red wire connector on the battery,,,,and the black one to the black connector on battery,,,,,just to be sure charge gauge is reading correctly,,,,,,if it is indeed fully charged,,,,now go to where you engage the power,,,,whether it be a pedal,,or a trigger on the handle bar,,,,,you will have to check all connections to be sure one has not come off,,,,or got to lose to make a connection,,,,if all looks ok there,,,,check the wires that go to the motor ,,, from the battery,,,,make sure all is secure,,,,, if it has gotten wet,,,check for any corrosion on all your electricals,,,,,,and clean ,,,,,when your doing all this,,,,,also check for a broken wire,,,,,or stripped wire,,,, hopefully these steps will put you in the right direction and back to riding,,,,, JOEL
Aug 22, 2010 | Razor E100 Electric Scooter
My laptop is a Sony Vaio PCG-6Q2M with Power and Battery Problems
fix first the power adapter/ it not charging some problem of your power adpater,, check the charger if it is working properly or not, then follow by dc connector should know that your dc connector has no deffect// if its okay check the motherbaord of your pc maybe som chips need to replace or damage...ic capacitor fause..ech..
Sep 10, 2009 | Sony VAIO PCG-K23 Notebook
My T42 suddenly wont recharge the battery or wrk off mainsadapter
If the Laptop wont work off the power adepter, it also will not charge. The adepter could be bad (even if showing a power light) or the connector on the laptop could be broken. The best test is to take the battery out, attach the power adepter and try to start the computer if it starts, your battery is at fault. If nothing, suspect eh charger first. Be sure the pin on the Laptop power connector isn't bent or broken.
Jan 04, 2009 | IBM ThinkPad T42 Notebook
GPS Logo
52 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
