Question about Quasar SP-2725 27" TV
External Speaker Hookup?
My owner's manual has disappeared and I'd like to connect this TV to a pair of decent external speakers. Is this possible and if so, how do I go about it?
  • battis Jul 28, 2008
    Ummm...what's RCA cable???
    Ok, thanks. I'm on it.
  • 6,487 Answers
Yes you can buy a RCA cable provided that your external speaker can be connected by RCA, But if you have a Amplifier that will be easy to setup.
Hope that helps.........
Posted on Jul 28, 2008
  • Quasar Master
  • 19,396 Answers
Yes buy RCA cables and connect to round audio out plugs on tv
HOW TO ADD EXTERNAL SPEAKER ON A UNIDEN 525?
Hi!
From your owner's manual (page 12) use the blue(-) and the brown (+) wires from your GPS/External speaker connector cable to your external speaker. I've included the owners manual link to your radio.
Regards,
-Steve
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/UM525om.pdf
May 14, 2014 | Uniden Boating
My tv volume is on 100, however, you still can't hear it
first is turn it down to a lower level:
look to see if sound with a DVD connected to a rear input.
look in menu to see if speakers are switched to OFF.
look also if set has external speaker hookup set not set to external.
failing you have a audio circuit problem in the TV.
Nov 06, 2012 | Magnavox 26" LCD TV with Built-in DVD...
CANT FIND A EXTERNAL SPEAKER SET
before attempting that:
Look in set menu to see if speakers are switched ON or OFF.
Check on SET and a Box if used that sound is not turned off or low.
If set has hookup for external speakers is external or internal selected.
Does the set have sound when a DVD etc. is connected via one of the rear sets of audio/video input jacks?
SD TECH
Apr 24, 2012 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Can i cannoct external speakers to my Logik L22DVDB11
THANK YOU EVERYONE!! THE SPEAKERS ARE ****! they fell from just a tiny height aswell#!!! ive just added on external speakers to it using a aux cable sound quality is much better too!!!
Jan 19, 2012 | Televison & Video
Terrible sound, sounds like speaker blown. Got it 2 days ago.
If this is a "new to you" TV, keep reading. If it is a brand new TV, I'd be on the phone to the store to have a replacement ready for delivery / pick up. You do not want to be repairing a TV that is 2 days old.
The first thing to do is determine if the distortion is coming from the speaker or if it is on the signal going into the speaker. Do both speakers sound distorted or only one?
You didn't include the model number of your TV, so I can't speak to specifics. Look for a terminal on the rear of the set identified as "speaker" or "external speaker". If provided, there will be one set of terminals marked for the left and one for the right external speaker.
Connect a speaker directly to the terminals marked for either the left or right speaker (connect to the one that sounds distorted if only one of the built in speakers works correctly - other wise pick either speaker terminal pair.). Speakers that have RCA plugs on them, have built in amplifiers, require batteries or or to be plugged in to an outlet should not be connected here.
Alternatively, you could connect a pair of stereo headphones or earplugs if your TV offers a jack for them. It would have a headphone icon or say "phones" above the jack if one is provided.
Once connected, turn the TV on, lower the volume and set the TV to enable the external speakers / disable the internal speakers. This may be done via menu item selection or a small switch near the speaker terminals. Slowly increase the volume to listen to the quality or clarity of the sound coming from the speakers you connected. If they sound distorted, the problem lies with the audio amplifier in the TV. If they sound OK, then there is a problem with the speakers in the TV.
If you can't return the TV, you may have to see about using the left and right audio line out or HDMI jacks to send the audio to an external amplifier and speakers to hear the program.
I hope this was helpful and good luck! Please rate my reply. Thank you.
Apr 06, 2011 | Sanyo 42 in. LCD TV
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
External speaker hook-up possibility
Yes, its absolutely possible. You can connect external speakers from analog output of TV. Even you can use AV receivers available in the market which can be used to amplify OR process the tv sound with latest digital processing techniques, it would be very much pleasant than the sound from tv.
--Sandy
May 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
External speakers
Unfortunately no. The Panasonic PT-60LCX64 TV does not have any jacks, plugs or external connection point to attach he wires of external speakers.
Alternately however, it is possible to install 2 pairs of speaker terminals on the backboard and wire them in parallel to the internal speakers.
Hope this be of help/information. Good luck and kind regards.
Feb 05, 2008 | Panasonic PT-60LCX64 Television
Magnavox projection tv hookup to external speakers
The external (audio out) connectors are intended for use with an external amp, not direct speaker connection.
Sep 02, 2017 | Televison & Video
Quasar SP-2725 27" TV Logo
665 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
