Question about GE Washing Machines
My washer is overflowing. I see what the problem is just need to know how to clean out the reservoir on the side of the tub. It looks like it is full of sediment and sometimes plugs the tube to the load size switch.
    Problem Solver:
  • 14 Answers
Washer magic is a great product and you will need to do it a couple of times.
Posted on Jul 28, 2008
Maytag washer overflows
Remove and clean the water level tube that connects to the tub at one end and to the water level switch at the other end. Probably it is full of gunk.
May 28, 2017 | Maytag Washing Machines
Hotpoint washing machine model vbxr1090b2ww leaking from bottom of unit
Here are some solutions.
Hope this helps you...Jim...Please leave a comment...Thanks!
LEAKS ALL THE TIME Is your GE washer leaking all the time, even when not in use? If so the problem is the fill hoses or the valve. Look behind the washer to see if water is coming from the hoses. If not, take the cover off to the control panel. Once off, you should see if the water valve and if there is leakage - it needs replacing (if it is leaking). This is the most popular water valve for GE top-loading washers made after 1995 and the part number is WH13X86 Order Here. show?id=6bjnatppuce&bids=92089.1&type=10. Note that some models have a water valve with more than two coils. In this case, you will need to order the valve by model number at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 Buy Fill Hoses Here. show?id=6bjnatppuce&bids=92089.1&type=10
LEAKS DURING FILL CYCLE Is your GE washer leaking during the fill cycle? If so the problem may be in the valve. Follow instructions above, only this time start the fill cycle before looking at the valve.
If your washer overflows with water during fill cycle your problem is the water level control or the water valve. If you must cut the water off from the house plumbing to stop the water then there is no need for testing, just replace the water valve. First, you need to turn on the washer. The washer should start to fill with water, now cut the washer off and on repeatedly (note to yourself whether the water turned off every time). If it does cut off every time you cut the washer off, then it's most likely in the water level control. If it keeps running after you cut the washer off then, the water valve is bad and needs replacing. (Note that the valve can stick intermittently so it still may be bad if it passed the test) Water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
If the water valve doesn't stick in the first test then you need to check the water level control. First, remove the front of washer (insert butter knife between the top and the front pushing on the clips) then look on the side of the tub and you should see a tube attached to a box. Remove the tube (make sure all the water is out of the tub) look in the tube to see if is stopped up. Often it will stop up near the end. If it is, you can clean it out with a toothpick. Once it's clean, reinstall it and your washer is fixed. If the tube is not stopped up reinstall the tube. Now set the water level control on the lowest setting and start filling the washer with water. If the water stops when the tub is approximately half full (this varies with every model) turn it up to the next level (you may have to reset it). Repeat until the tub is full. If at any the water level gets above the last row of holes in the tub, unplug the washer. If the water stops running when you unplug the washer, replace the water level control. If the water doesn't stop, turn the water off at the wall then replace water valve. Water level contorls and water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 . LEAKS DURING WASH Is your GE washer leaking during wash? If so the problem is the tub seal (seals around the transmission where it goes through the tub), drain hoses (including the tub to pump hose) or the pump. First take the front off the washer (insert butter knife between the top and the front, pushing on the clips) then start the fill cycle. Now start watching until you see a leak. If the leak is coming from the tub seal, the transmission needs to be replaced (note that changing the transmission is expensive and takes special tools, so you may consider replacing the washer). If the leak is coming from the drain hose or the pump you need to replace it. If you don't see it leak at all, your soap may be the problem. To check this fill the washer with water and the amount of soap you normally would use. Then start the washer and watch the tube coming from the left back of the tub (the overflow pipe). If soapsuds come out of the overflow pipe then try cutting down on your soap or switch to another brand. This may fix your problem. These parts can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
LEAKS DURING PUMP OUT Is your GE washer leaking during pump out? If so the first thing you should look at is the drainpipe (to your house plumbing). Fill the washer with water, and then turn it to spin and start it. Now while it's pumping, look at your drainpipe if water backs out (it may not back unless you have soap in the tub), then the problem is in your plumbing. If it doesn't, follow the same steps as above in "leaks during wash." Only this time watch for leaks during pump out as well.
Feb 13, 2011 | Hotpoint VBXR1090B Top Load Washer
Washer is filling too much and water is coming out overflow
you need to clean the pressure swith hose on the lft side of tub small rubber hose stop use in liqid soap
Jan 30, 2010 | GE Washing Machines
Frigidaire GLWS1339EC Washer Overflowing
Do not blow to the switch. Blow from the switch to the tub. The blockage is soap scum in the air bell on the side of the tub. You may have to run a small wire into the tub area where the air hose attaches on the side of the tub.
Dec 05, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
My GE Washer overflows about every 3rd or 4th load. I have read a fixya recommendation and took the front off the washer (been trying to figure that one out for years, thanks!) and find that the small...
I have the same problem. I turn on the water until it is past the small resivour, turn off the water, take off the clear tube, and then put a bendy straw over the hose entry. I then blow until the air bubbles up in the tub. This cleans it out for a while but it reoccurs Repair main taught me this trick but is not a perminant fix. Seems like a bad design that you can not clean this out somehow. Thinking I will just buy something other than a GE to replace.
Nov 27, 2009 | GE Profile WPRE6100G Top Load Washer
My GE washer (modelWBB4500E1WW) overflows about every 3rd or 4th load. It appears to overfill like it doesn't know the level of water. Even when set to small load it can overflow.
Remove the front panel by using a putty knife to depress the retaining clips at the seam where it meets the washer top. (one on each side) Take the thin hose off the lower left side of the outer tub and clean it out. A short cut would be to cut off an inch and a half of it, but that's a one time fix, then the hose starts getting too short. To help prevent re-occourance, run a small hot load with a couple cups of bleach (no clothes) every few months. Make sure to rinse the tub on the largest level to prevent bleach damage to your next wash load.
Oct 18, 2009 | GE Profile WPRE6100G Top Load Washer
I have a kenmore model 110 and it is overfilling the water doesn't stop and it overflows, flooding my basement.
Pull the top of your washer off, look on the tub and you will see a round plastic reservoir. You will see a plastic tube come out and to to the control panel. Make sure that hose is attached at the tub and the pressure sensor.
Sep 13, 2009 | Washing Machines
Washer water doesn't stop running and over flows. Waeher works 2 out of five times then overflows again. Kenmore 70 series
It's probably your overflow valve that's causing the problem. Sometimes it can get suds in it causing it to not register and overflow the water. What you can do is take the overflow hose off from the side of the tub and blow into it a few times to force any suds out. Next, after you reconnect it, run a load with no clothes and about a cup of white vinegar through it. Put the vinegar in the soap dispenser, the tub, the bleach area, and fabric softener area and run it on hot water and heavy load. This will clean out all of the hoses and any suds that are caught beneath the tub in the reservoir. After this it should work just great. If you are using powder soap, STOP, use liquid. Powder will cause a lot more suds and it doesn't dissolve well unless it's being used with hot water. If you have any other questions let me know, also let me know if this was helpful to you. Good luck and have a great rest of the weekend.
Jan 25, 2009 | Washing Machines
Another flood. GE washer
The water sound is normal. There is a solution in the top of inner tub for balance. Is it overflowing...as in not stopping the fill cycle? If so check to make sure small hose is still attached to outer tu at bottom left front. This dome that it connects to can become filled with scum and causes the unit to not know that it's full. This causes flooding. You can try removing hose and cleaning out with thin wire. Sometime only fix is to replace outer tub. Again, this is only if overflowing!!
Another possibility is a bad break allowing outer tub to spin in agitation. This throws water up over sides of tub. Monitor unit when agitating to see if outer tub picks up speed and starts to spin. It is normal for it to index.
Nov 08, 2007 | GE WDSR2080D Top Load Washer
Maytog top load
Fabric softener is mostly a liquid wax. It is common for dispensers to have problems if the you use liquid fabric softener a lot. The softener becomes a sticky solid and can gunk up everything over time. I believe the type of dispenser on your washer simply flushes water into the reservoir at a prescribed time and then dispenses into the wash tub. If this reservoir becomes clogged somewhere it may actually be filling up and overflowing into another reservoir in the dispenser and getting dispensed that way. I would try cleaning the dispenser thoroughly, first. Since it IS dispensing (but at the wring time) I don't think you have a control problem. Try cleaning and let me know if this helps. PS Sorry to ignore your request for online assistance. I was already in the middle of typing a solution for you. I hope this was the help you needed.
Jul 30, 2007 | Maytag LAT3600A Top Load Washer
Washing Machines Logo
74 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
