Question about Refrigerators
I continually have condensation collecting at the top of the fridge. I have tried adjusting the unit so that it "tilts" slightly backwards (per my level) and i have adjusted the interior light so that it no longer stays on when the door is closed. I also put a thin coating of pertoleum on the magnetic strip to insure a tighter seal. running out of ideas. The unit is approx. 5 years old but it has done this off and on for the past several years. please help. thank you.
  • RoxHoff Jul 28, 2008
    Thanks "gwol"
    I will try at tighting up the srews that attach the door to the body and remove a few things from the door. thank you so much for taking your time on this one! by the way..it's a North Star (out of Canada). it's a beautiful unit.....but have had several problems.
    Novelist:
  • 116 Answers
Without having model specifics...
The short and quick answer is that your door is sitting too low. The hinge may have to be removed and straightened. I ran into a similar issue with an Amana bottom freezer where the owner had excessive weight on the door which caused the light to stay on and the door to not seal properly.
The lower hinge had become bent downward causing the problem. The fix was to remove the door and straighten the hinge in a vise. The fix was not permanent since I had to go back less than a year later to fix the same problem, again the door was overloaded.
Posted on Jul 28, 2008
Runs great,but why does it drip water out front,through the goss pad instead of out the drain hole?
check that the drain hole is not blocked
check hat the fridge is adjust to lean slightly backwards so that any condensate runs down the back of the fridge and is collected in the drain tray
Aug 13, 2015 | Refrigerators
Intertherm air conditioner leaking water into floor
Have you got the a/c unit slightly tilted backward so the condensation will drip outside.
May 05, 2012 | Intertherm P3RA-048K Air Conditioner
Water dripping down from back of fridge.top shelf very wet and bottom soaked
hi there......can you check (1) the vent hole at rear of fridge is clear to allow condensed water to flow out...(2) that your thermostat is turned up to 3or 4....(3) check that your fridge is set up properly ..that is it is tilted back slightly...
regards Sir Galahad
Aug 21, 2009 | Refrigerators
Re Frigidaire 104P1A - Neighbor below me is complaining the unit is draining INTO her window (she needs/wants to have it open). I had someone out to adjust the level of the unit, tilting it back slightly,...
You need to vacuum the coils in the back of the fridge and make sure you have a drip pan under you fridge. The fridge will over work itself because of buildup dirt.
Jul 19, 2009 | Heating & Cooling
Leaking/ room temp. air.
I am assuming that this is a window airconditioner. If so make sure that the unit is installed at a slight tilt. You "do not" want it level. Make sure that the unit leans toward the drain. The drain must be at the lowest point. Also make sure that the drain, the drain tube and the condensate collection tray are clean. A slight or moderate buildup of dust, dirt, mold or rust will detour the condensate drainage out the nearest point of least resistance. Always keep the filters, the evaporator coil and the condenser coil as clean as possible. I hope this info helps you.
Good luck.....
May 02, 2009 | Heating & Cooling
Refrigerator Door not staying closed
Try to raise by adjust the 2 front footing slightly higher than the back, this will tilt the unit slightly backwards. That will help the door to close back by itself.
Feb 24, 2009 | LG LRFC25750 Refrigerator French Door
Kenmore fridge with freezer on top/condenser bangs
check rubber mounts on compressor and also make sure fan is clear of anything that could be rubbing it
Dec 17, 2008 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Refrigerator condenser banging
yeah, you must have knocked the compressor when cleaning, sounds like one of internal spring/mounts in the comp' has dislodged.
replace the compressor is the only fix, unless you can somehow get to the lose spring.
Apr 25, 2017 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
if this helps please give me a fix ya
Jul 14, 2008 | Sunbeam Heating & Cooling
Refrigerators Logo
95 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
