Question about E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz / 512MB DDR / 160GB HDD / DVDRW DL / nVIDIA GeForce 6100 I... (RBC6423) PC Desktop
Power cutting out from tower. EMACHINES 550
When running, power cuts out via tower at any time. Sometimes it runs for 1 hr or more,but USUALLY cuts out after a few minutes. Not sure how long I can type here before it spits at me and shuts down. This has been going on past several months. I click on green start button and hope it decides to work for me. What can I do? Thank you. la
  • 1 more comment
  • bookreader Jul 28, 2008
    No-one ever suggested that cleaning may help problem. I will go to Walmart and purchase air? I hope this is right.
    Thank you for your help. la
  • bookreader Jul 29, 2008
    Same as first recommendation. Thanks.
  • Anonymous Nov 22, 2008
    turn on the power nothin happens light is on at the start button
  • 152 Answers
There maybe to much dust build up on your cpu cooler that causes it to shut down to protect itself it needs clean about every 2 months or less to make it run smoothly.That is one solution the other solution is that your power supply needs to be clean also or replaced.Buy a can of air from your local computer store or walmart etc......
Posted on Jul 28, 2008
The Engine runs well but at times it throtlles as if it the engine is cutting off, but it just continues on....
look for worn / broken wires in the harness to the cam / crank sensors as they may be loosing signal to the ECM which cuts off power
run the fault codes to check for reports
May 07, 2016 | 2004 Suzuki Swift 1.5
Error code 212
212 Comms Error between Outdoor Unit and HR Box No3. 1. Defective connection in HR unit power supply and transmission connection 2. Wrong setting of the HR unit Rotary switch and Dip switch 3. Defective HR unit PCB
Feb 14, 2015 | Heating & Cooling
I use this Alba television in my bedroom and usually watch it for a little while before I go to sleep. Due to the fact that it cannot be turned off completely (always on standby unless the plug is pulled...
If the tv is not a plasma unit which are expensive to run I would not be bothered completely turning off the power. I have a power supply readout connected in the mains power and Like you I believed the hype about switching every thing off but I learnt that the cost is virtually nill. to run. For a example I have 2 moniters + 1 computer+1 printer +1 tube type TV+ clocks( all on standby) + night light and the cost is .001 cents /kilowatt hour.. IT climbs to .002 cents when the 2 fridges cut in then drops back when they cut out.. Another point is when you continually switch electronic units on and off they will suffer more failure than leaving them on stand by
Aug 02, 2013 | Televison & Video
Isuzu Bighorn engine intermittent loss of power and cutting out while moving, white smoke
-Mostly burning water. Water is enter into the cylinder.
Good luck
Oct 25, 2017 | Isuzu Trooper Cars & Trucks
My tower fan(not a lasko) but very similar cuts off when i put it to rotate.
Sounds like a short in the wire. Return it before it burns your house down.
Oct 10, 2012 | Lasko 2554 Tower Fan
My connext 4600 Turbo quiets receiving and getting out. Power is on, radio is lit up, might stay on for 30 min.- 1 hr. Squelch comes back on and starts getting out for up to 2 hrs. once power is cut off...
Well it does sound like a bad solder joint around your crystal,crystal is what gives you your freq.or channels.All I can do to help you without it being on my bench is to tell you to take the screws out the top of the radio,run the radio and when it quits lightly push on the top of the radio and see if that helps,if so it is a bad joint just find a cb shop that will take the time to find it.These are great radio well worth fixing.
Jun 04, 2011 | Connex 4600 Base CB Radio
2003 taurus recently had rough idle and then cut out expecially after 3-4 short trips in a row and then would not start until it had set for 45 min to 1 hr. Now turns over but won't start. P0191...
then it cuts when hot ?
when cold start is it take some time to run from clod ? if yes then injectors nozzles if not then it is the (coil) well cut off when engine is hot
May 31, 2011 | Ford Taurus Cars & Trucks
Hi, 1997 monte carlo that idles, but cuts out when put in gear, or at times while driving. 3.1 engine. 184,000 mi.
I don't have an answer for you, but I do have a similar or maybe even the same issue with mine. It usually starts up fine, and idles and runs fine when first started, however a few blocks or a few miles down the road it starts to cut out on me, sometimes dying completely... throwing it into neutral and pumping the gas usually will keep it running. This has gone on for a couple of months. When it does die, It normally will restart after sitting for a few minutes. Then a couple of weeks ago it died on me (normally this happens when slowing down and coming to a stop,) and would not restart even after a 1/2 hr, I had to have it towed. I periodically attempted to start it for over a week, it would turn over, but nothing more...then someone suggested that I disconnect the auto start box...It started right up. However, it still continues to cut out when slowing or stopping unless thrown into neutral and pumping the gas. It seems to run better on the open highway, than it does in town with all the slower speed and stop n go. I bought this car used about 6 mos. ago, and considering it's age and the 135K miles on it, I don't want to put any more money into it. I just read there is a recall on this vehicle for the fuel pump and additionally the fuel assembly, I'm not sure if this would be the answer to the whole problem or not.
Dec 30, 2010 | 1997 Chevrolet Monte Carlo
How longshould battery run
my grandkids usually get about 1 hr of full run time, but they never really run it constant for 1 hr. they usually run about 10 to 15 minutes then go play on something else.
May 20, 2010 | Peg Perego John Deere Gator HPX Ride on...
Cuts in and out
I suspect a bad compressor run capacitor. Take the unit to a service facility & have the capacitor & overload protector replaced. The overload will be weakened by the repeated cycling.
Jul 14, 2007 | Danby DPAC8020 Air Conditioner
E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz / 512MB DDR / 160GB HDD / DVDRW DL / nVIDIA GeForce 6100 I... (RBC6423) PC Desktop Logo
85 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
