Question about Sony Playstation 3 (PS3) Console
PS3 picture ans sound
I plugged my ps3 into my tv and it doesn't show any picture or it doesn't have any sound. the aux cord looks like nothing has happened to it and i tried my xbox just to make sure if it was just my tv that had the problem, but the xbox worked. and i also tried my ps2 aux cord and it didn't work either. so i don't know what happened. please help!
    Problem Solver:
  • 4 Answers
Make shur the cords arnt lose
Posted on Jul 29, 2008
How to connect to tv
There are several ways to connect a game console to a TV. The question is, what system are you trying to connect? Some features may be available for the newer generations, that are not on older models. I'm assuming, since you have posted with a picture of a Sony Playstation 3, (PS3) that is the system you are trying to connect. The easiest way to install is to use the supplied (RCA) connection cords that comes with every PS3 system. One side connects to the corresponding port in the back of the system, and the other end has (3) multicolor plugs. They will match the colors on most TV's. Some of the older TV's do not have the RCA ports and will require an adapter to connect this way. These colors are; YELLOW (video out) RED (audio out right channel) and WHITE (audio out left channel or MONO) The PS3 also has and HDMI port, and is much simpler to connect the TV and game console together. As I stated before, not all TV's are equipped with HDMI. HDMI cables carry both the video and the sound through 1 cable. To install this way, simply turn on your TV to the correct aux port, in this case HDMI, then connect the the HDMI cable from the PS3 to an available port on the TV. After you have connected the cords, turn the system on and it will tell you that it has "Detected an HDMI connection. Would you like to use this connection?" Select yes. The rest is automatic.
Also, if you didn't know and are needing a new rca cord to connect to the TV, search for a cord from one of the older systems in the SONY family and they will save you some cash, as they are all exactly the same. PS1, PS2, and PS3 all use the same connection. I hope this helps. Good luck!
Aug 25, 2015 | Video Game Consoles & Games
Norcent model LT-2725 TV to ps3?
Check the video out settings of PS3.
Jul 27, 2012 | Televison & Video
Toshiba 20WLT not working with PS3
The PS3 has to be configured to put out HDMI or AV(RCA plug)output.The easiest way to switch between is to connect both cords to the same TV,so you can swap to the other ouput and verify it works.(In other words,if you had the PS3 set on HDMI,you have to connect with an HDMI cord unless you change it in the PS3's settings).I think this was an energy saving solution by Sony,bacause I'm sure they could figure out how to make both work at the same.
Mar 13, 2012 | Toshiba Televison & Video
Iam not able to get a picture from my hdmi cable, but can still here sound. tried three different hdmi cables... please can you help...
1. Your Connections Are Faulty
Quite often, the cause of the no picture problem is a simple one - loose cords. Make sure that the cords are plugged in tightly, both on the TV side and the PS3 side. This is especially true with the HDMI cable connection on the PS3. Often, it looks tight, but you still might need to wiggle it a bit more to seat it correctly. Along the same lines, make sure that the cords you are using are new and match the connections properly on both the TV and your console.
2. Wrong Connection Settings
If you are using the HDMI/DVI cables and you don't get any picture, make sure to check your video ouput settings. If your PS3 thinks you are using standard A/V cords to connect to the set, you'll have issues. The opposite is true too - if you are using the A/V cords and your PS3 thinks otherwise, you'll have the same no picture problem. Make sure you settings match the types of cable connectors you are using.
3. Wrong Resolution Setting
This is also an easy mistake to make that can result in no picture showing on your television screen. For example, if you've been using your PS3 with an HDTV and then try to hook it up to a standard definition television set, you'll encounter this issue. The cure is simple; just go into your settings and switch back to standard resolution and then restart your system. The 720p resolution is the default setting and this should work for most standard definition televisions.
Nov 18, 2010 | Sony Playstation 3 (PS3) Console
Reset defalt settings..... and the screen is telling me to plug in controler and then press the ps3 button and nothing happens
unplug the controller and take a pin and press the small button on the back of the controller to reset. i also had this problem with mine.
May 31, 2010 | Sony Playstation 3 (PS3) Console
My PS3 turns on but nothing shows up even when i
All you need to do is turn it off then turn it back on and hold the reset/power button for a few seconds until it beeps then this will automatically setup your PS3 to whatever your TV is setup, I have found this to be an awesome help.
Jan 09, 2010 | Sony Playstation 3 (PS3) Console
No sound on tv or from the actual ps3 unit, no picture.
be sure all cords are plugged in correctly and that the tv itself works if nothing helps and its not any of the cords you may need to get it looked at.
Jul 02, 2009 | Sony Playstation 3 (PS3) Console
MY PS3 BROKE
buy a new aux cord for it or the aux hookup in the tv or the playstation could be bad hope this helps
Nov 19, 2008 | Sony Playstation 3 (PS3) Console
My playstation 3 broke i dont kno whats wrong
if your using the original ps3 cord that came with it (yellow white red) then you will have to use an HDMI cord and when you do use this cord then everything will show up on your tv including sound.
Oct 16, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
99 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
