Denon avr-1708...How do I reset the unit to factory settings? And I also have a powered subwoofer and even though the AV is turned off, there is still a hum on the subwoofer. The manual stated that the unit will go into standby if their is no signal for 10 minutes. It will go into standby with the audio cables unplugged.
  • Anonymous Mar 31, 2009
    how do you perform a reset on the Denon 1708?
    where is the button?
    how can i reset a Denon 1708? my sound is notcoming thru and the souranding system dose not works. any one know? D.A Wayne NJ
  • 3 Answers
SOURCE: on standby
Mine does the same thing..........
If anybody knows the problem ........please e-mail me.
StageRulz@Yahoo.com
Posted on Nov 13, 2007
zaids
  • 456 Answers
SOURCE: Denon AVR-487 SYS-57HT SPEAKER SYSTEM
check that wire and fuse again and try to reset and try
Posted on Dec 11, 2007
SOURCE: How do you reboot the Denon AVR-2807 to factory settings
To reboot, turn receiver off by the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory. Enjoy this info is straight from Denon's Tech support. I had to do this on mine
  • 6 Answers
SOURCE: Denon AVR-1508
sounds like overload protection
turn the volume all the way down, then turn it on
if that doesn't do it you may have a short in one of the speaker lines - try disconnecting them one at a time
Posted on Jan 13, 2008
  • 3422 Answers
SOURCE: Denon AV Surround Receiver AVR-486 w/DSW-76 Subwoofer
HI,
Disconnect all of your speakers(subwoofers)then turn the receiver on. If it still does it, then bring it into service. If not, that you have a short somewhere probably the main board and there are no home remedies for this.
Goodluck..
Posted on Aug 03, 2008
What will factory reset avr 1709 fix
It will not fix any problems with it, It just sets it back to the way it was before you set it up.
Dec 04, 2012 | Denon AVR-1708 Receiver
Our denon 1708 only play on stereo mode,no sound when it select on 7 channel.. crackling on dolby. what is the problem on that receiver? please help
The surround sound outputs outputs ic's in the remainder of the system have opened, or there is a short in the speaker wiring, check to make sure that is not the case, if okay! you will need a repairman to assess the situation.
Mar 31, 2012 | Denon AVR-1708 Receiver
Denon avr-1708 receiver heats up and shuts off when volume turned up passed 0.0db or +0.5db. i am running 6-8" sonance 6oh speakers and have a fan blowing across the top of the receiver. it only...
Are you trying to kill it? A device has only so many emergency shut-offs it can withstand.
How are the spaces around the top, underside and back for ventilation?
0 dB isn't normally 'normal' volume.
I wonder if the fan is a self-defeating work-around because the noise might make you want to crank it up so higher so you can hear it.
Apple TV? Is it a dynamically-compressed audio signal? That would raise the average volume.
Feb 21, 2011 | Denon AVR-1708 Receiver
My Denon AVR 1708 display shows "h/p only", which
Hi
H/P means Headphone .. if you plugged a Headphone or if the plug switch internally switched to H/P you have to check it out .
you might have broken the plug inside or some parts are left in there.
Regards
Nov 02, 2017 | Denon AVR-1708 Receiver
I have a Denon 1708 receiver. When I push the "on" button, either on the unit itself or using the remote, the light flashes green for a few seconds, then flashes red. When it turns red, all of the info...
Your result indicates the unit is not passing its power up self test. The first thing to try would be to remove all connections to the unit and try to power up. If it still mis-behaves, the unit has an internal problem best left to pros unless you're pretty good digging through circuitry. If it comes up stable, then reconnect things one at a time until the issue occurs again. Detach the offending connection and look for issues in the cables or the connected unit.
Oct 23, 2010 | Denon AVR-1708 Receiver
I have a denon avr 2802. the remote powers the
Try doing a factory reset by turning off main power switch.hold down speaker a and b buttons while turning on main power switch ,display will flash 3 time s then release buttons,this then returns unit to factory default settings.
Apr 13, 2010 | Denon AVR-2802
Denon avr -1709 how do i get it reset to factory specs
SWITCH OFF THE UNIT..PUSH AND HOLD DOWN BOTH SPEAKER A AND SPEAKER B BUTTON WHILE HOLDING DOWN BUTTONS TURN ON MAIN POWER THE DISPLAY WILL FLASH WAIT FOR 3 FLASHES THEN RELEASE. THIS WILL RETURN EVERYTHING BACK TO RFACTORY DEFAULT
Mar 21, 2010 | Denon AVR-1708 Receiver
No signal coming from sub woofer out
set the front speaker to small or if still set in large,set the subwoofer setting to lfe+main.
Feb 18, 2010 | Denon AVR-1708 Receiver
How to hook up a Wii to a Denon AVR 1708
If you are video switching through the Denon, you may need to make sure the inputs (analog, composite) are the same as the outputs. For example, you might have component out to the monitor, but composite in from the Wii. I don't believe the 1708 can do the upconversion. Try hooking up a yellow RCA cable from video out to the TV.
Dec 28, 2009 | Denon AVR-1708 Receiver
How to connect xbox360 to denon avr 1708 by hdmi cable
if you have an usb cord hook that up the your xbox then the avr 1708
Dec 20, 2009 | Denon AVR-1708 Receiver
1,153 people viewed this question
 Grubhead
Grubhead
