Question about Dell Inspiron 8200 Latitude C840 Laptop Keyboard03J247 CD-ROM Drive
Dell inspiron 8200
Laptop was diagnose as having a problem with the mother board and I replaced it and it is still not coming on when you power it up. I remains on for 5 seconds then shut down.
Please send email response to lynn_193@yahoo.com as the other email that i listed is not working
  • Dell Master
  • 998 Answers
Is this the same problem you were having before you replaced the motherbrd? If so then the motherbrd is not the issue. If the symptom changed, you may have a DOA motherbrd or you missed something when you re-assembled it. Did you migrate the CPU from the old motherbrd and secure it in the ZIF socket securely? Reseat the memory modules one at a time to determine if one is defective. Dis-connect the LCD video cable from the motherbrd. Remove video card if it has one. Dis-connect the Palmrest, (Touchpad) cable from motherbrd. Remove the Hard disk drive. Remove the battery and just use the AC adaptor.Try to isolate the problem.
Posted on Oct 16, 2008
Dell Inspiron 6000 won't charge
Since you have already replaced the battery and the laptop works with the AC charger, then probably the charge circuit in the system board (mother board) is bad. I have rarely seen an AC charger that will power the laptop but not charge the battery. 99% of the time, if it is not the battery, it is the system board.
May 05, 2010 | Dell Inspiron 6000 Notebook
My Dell Inspiron 8200 will not power
remove the battery and try again with ac adapter
Mar 19, 2010 | Dell Inspiron 8200 Latitude C840 Laptop...
No power leds. My Ac adapter is new with the right voltage coming out. I have to keep on unplugging the power cord then the green light comes on my Dell Inspiron 1300....I took the Laptop apart and solder...
You will probably find, that the power Jack on the Mother Board has fractured the solder joint, this is a common problem. You may have to get it to a shop.
Mar 08, 2010 | Dell Inspiron 1300 Notebook
DELL 1501 INSPIRON THAT SHUT DOWN AND WANT POWER UP
Short or broken lil jack on the mother board. Needs a professional to look at it.
Oct 11, 2009 | Dell Inspiron 1501 Notebook
My dell 8200 inspiron laptop right speaker its not working
My guess is the speakers or connectors have gone bad. I have seen this in a lot of different laptops.
If you are handy, you can disasemble the laptop, find the speakers, and get a part number off of them. Dell is pretty good about labeling the part numbers. Then do a search on Google and Ebay for the speakers, I am sure you can find some cheap used ones that work.
Here is a manual for disassembly of your laptop, and shows where all the parts go. You will need Adobe reader to read this.
http://www.elhvb.com/mobokive/edwin/laptops/Dell/INSPIRON/8200/8200.PDF
Apr 14, 2009 | Dell Inspiron 8200 Notebook
Dell laptop 8200 usb failed to work
go to dell web site and download the chipset update.
chance are the connection on the motherboard is bad or the chipset software is out of date.
if the software for the chipset can't fix the problem. the next alternative is to replace the mother board.
Mar 18, 2009 | Dell Inspiron 8200 ATI 64MB Video Card -...
Problem with my Dell Inspiron 8200 Notebook system speaker - no driver was installed... Thus, there is no sound coming from my system speaker at all - I have to use headpone all the time. Dell's driver...
I was just on Dells web site and they do have the sound driver for your laptop on there. I could send you the driver if you want or you could go there yourself and download it. I just typed in dell.com, click on support, click on drivers and then click on laptops, inspiron, then 8200 and it brings up all of the drivers for your laptop including the sound driver. Let me know if you have any trouble with it.
Jan 27, 2009 | Dell Inspiron 8200 Notebook
Dropped laptop
Press and hold the <Fn> key while powering the system on. This will run the Dell Diagnostics. Another more intense diagnostic program is located on a Dell CD that you should have received with your laptop. Look for one that has “Diagnostics and utilities” listed under the “Contents”. You will have to boot from that CD disk. To do this, power on your laptop and tap the <F12> key to bring you to the “One time boot menu”. Insert the CD and then select CD/DVD drive and hit <Enter> key. Select the “Run the 32 Bit Dell Diagnostics”.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 31, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell Lattitude C840 Laptop
The 3 LED's (Num Lock, Caps Lock, Scroll Lock) are used by Dell to diagnose no-post issues such as yours. The only error code close to yours is [Num Lock ON, Caps Lock FLASHING, Scroll Lock ON]. This indicates a a memory error. Try reseating the memory modules. If you have 2 memory modules, insert one at a time to determine the faulty module.
Sep 21, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Computer not staying on
what model computer is it? Some dell laptops will shut down with problems with palmrest (upper part that includes touchpad)
Jul 28, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Computers & Internet Logo
80 people viewed this question
Alun Cox
