Question about OKI C5150n Led Printer
Toner problems The message says Check Toner Cartridge and then 541: M Toner Sensor Error. What does this mean because the printer won't print no matter what we do to it. We get this same message every time.
  • Anonymous Apr 02, 2009
    540: Y toner sensor error. Will not print. Just got new toner cartridge and now it will not print.
  • Anonymous Mar 25, 2014
    error message 541:M toner sensor error. this has been checked and it's not the sensors.
I've had this problem several time. Usually I fix it with a q-tip!
Open the top of the printer and locate the correct toner cartridge. Pull the (blue) lever on the right side of the cartridge toward you to disengage it from the drum. Gently life the toner cartridge out of the printer.
On the right end (the end with the blue lever) there's a small slot. You should see some white plastic in there. Use the qtip to clean off any dirt or toner.
Now replace your toner cartridge and slide the blue lever back to the original position. Close the top.
This USUALLY fixes the problem. (I must stress "usually" because I'm having the problem right now and this procedure won't fix it, but I've fixed it with this method a dozen times before.)
Posted on Oct 24, 2008
Hello - my Lexmark E120 will print a test page, but won't print anything that I send to it. I just get an error message. There is a green light next to the 'lightbulb' on the printer. The...
The light next to the lightbulb on the printer Toner low/replace PC kit. The printer is ready to receive and process data. In addition, the toner in the toner cartridge is getting low.
Solution:
? Press continue button to clear message and continue processing job.
? Remove the toner cartridge. Gently shake the toner cartridge from side to side and front to back several times to redistribute the toner, and reinsert it. Repeat this procedure multiple times. If the print remains faded, replace the toner cartridge.
For further assistance, please contact Lexmark Technical Support
Sep 12, 2011 | Lexmark E120n Laser Printer
CLX 2160 Message: Deve Home Sensor Error. What can i do to correct it.
There could be two problems
A minor error occurs and the machine is waiting an error to be cleared. Check the display message, and solve the problem referring to Understanding display messages, see page 11.3.The toner cartridge is low. Order a new toner cartridge; see Ordering supplies on page 12.1. You can temporarily improve print quality by redistributing the toner. See page 10.4.
For referring this page numbers, please download the manual from this link.
http://downloadcenter.samsung.com/content/UM/200812/20081215154056890/Guide_EN.pdf
The error message, which you have told me, not in the error message list. I think there is an internal failure for the printer. It is always recommend servicing your printer with authorized service centers. If the error message is not in the error list, owner cannot repair but, technician can repair the printer. I hope this information is useful for you. Thank you.
Apr 19, 2011 | Samsung CLX-2160N All-In-One Printer
THE 942.02 Service Yellow TMC Sens message is in the screen. What does it mean. It will not let me print
Error indicates a problem with the Cyan toner cartridge/developer. Try the following steps:
Power off the printer/MFP and open the toner access door. Reseat all of the toner cartridges. Power on the printer/MFP again and print a test page. Did the error message return? Power off the printer/MFP and remove the developer unit for the color specified in the error message, and then reseat it. Try printing another test page, verify if you're still getting the same error. It is possible that specified color's toner cartridge and developer unit are defective. If you have a replacement toner cartridge and developer, install them as a test and print a trial page.
For further assistance, please contact Lexmark Technical Support Center.
Jan 27, 2011 | Lexmark C540N PROD SPECS TBD Printer
I have toner sensor error , the screen reads check toner cartridge 541:MToner Sensor Error
In most cases you need to use a can of air and blow out all around your toner and drum area. Then used it inside the printer to clean out the toner inside of the machine. If this doesnt work take out all 4 anc clean everything very well.
Jan 21, 2010 | OKI C5500n Printer
541: M toner sensor error - this is the message I'm getting. I've replace the toner that does not work. How do I fix the toner sensor?
As the toner cartridge sits in the drum unit, the toner sensor outputs signal to drum unit which in turn conveys it to the printer via electrical contacts.
Try cleaning the contacts that are located on both sides of the corresponding drum unit, and also the contacts protruding from the sides of the drum socket inside the printer. Also reseat the toner in the drum.
If this doesn't solve the problem, try swapping two drum units - if the error now moves to the other color, than there's something wrong with the toner cartridge or the drum, and you have to find out if it's a contact problem between the toner and the drum, or perhaps the toner cartridge is defective - happened to me once.
If the error doesn't move to the other color, it means that something's wrong with the printer contacts - either they are dirty or dead, because of static electricity or something, and the printer needs servicing.
Jul 31, 2009 | OKI C5500n Printer
54.15 error code
Error Code 54.XX
Control Panel Message: Printer Error
Description:
15 Yellow CPR sensor
Recommended Action: Turn the printer off and then on, and then check the following itmes
Check the connections. Replace the color-registration detection assembly.
Description: Printing cannot continue. There is a sensor malfunction.
XX Description
15 - Yellow toner remaining sensor (J1014 toner level sensor)
Jun 24, 2009 | HP LaserJet 4700 Printer
My Oki C3200 has the following error message 541:m Toner Sensor Error
There are several reasons for this message... we will start with the easiest to solve. Here is a link:
http://www.katun.com/downloads/oki-c5100tnrcartiis.pdf
Jun 03, 2009 | OKI C3200n Led Printer
Error code 54.18
The error code 54.18 means that there was an error with black toner cartridge toner level sensor. Try taking the cartridge out and shake it a little to loosen up the toner inside, make sure all of the cartridge metal electrical contacts are clean and try it again. If it still has a problem you should try a new black toner cartridge. If that doesn't change things then you may need to replace the DC controller.
Sep 09, 2008 | HP LaserJet 3600dn Printer
OKI C5150n Led Printer Logo
402 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
