Question about HP Office Equipment & Supplies
Dropped photo card in the wrong port and it seems to have fallen inside where it cannot be reached.
  • 7 more comments
  • jimphly Jul 28, 2008
    this is model 2610xi
    Need to extract a photocard from hp2610xi as it has fallen inside of the case.
    Yes this is a SD card that was inserted in the wrong slot.
    the printer is working I just want to extract the photocard.
    I have tried everything I can think of to shake the card loose but it wont budge. look like the only solution is to remove the cover and I can't see how this is done.
    How is the case removed?
    Tried using tools to remove the card but it has dropped down inside where it can not be reached. Need to know how to remove the cover.
    Need to have instructions on how to remove the cover to retrieve the photocard in a hp2610xi. Thanks
    Sergeant:
    Champion:
  • 256 Answers
Insert the adapter of your SD Card you will find easy to remove it...
Posted on Jul 28, 2008
    Genius:
  • 1,056 Answers
I'll take a different approach to this.
How important are the photos that were on that card?
If they are not that important, I would leave the card where it is, memory cards are fairly inexpensive to replace.
If it is something you must have, the link that was posted above does have the information for disassembling the printer.
The next choice after that would be to take it to a shop to have them disassemble and reassemble the unit. Be aware that the shop cost could be the same as replacing the printer.
The way products like this are made, you very well may have to spend an hour or 2 taking it apart and reassembling it.
I have taken many printers apart, and for the most part, it is a lot of nut and bolt work (take the screws out, and take the many layers apart)
  • HP Master
  • 19,396 Answers
Go to a repair shop, if you do it yourself you risk to waste the camera.
    Genius:
  • 1,269 Answers
Use a tape, maybe scotch tape or electrical tape to pull the card out. Maybe you can use forceps to pull the card out. At least I was able to do it when I had the same problem.
  • 2,071 Answers
Yes you must open it,so you can take it out the card .
  • LORETO LACARON
    LORETO LACARON Jul 28, 2008
    Try this one get a little thin steck or a toothpick,at the end of the toothpick put a glue(epoxy glue) and insert it,to the wrong slot where the SD card and if you feel that the card stick on it pull it slowly until it come outside.
  • LORETO LACARON
    LORETO LACARON Aug 12, 2008
    did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further
    Sergeant:
    Champion:
  • 347 Answers
Hello Jimphly,
First try some easy solution.
Have you tried to turn upside down or side ways the printer?
That way if the card is not stuck it will come outside by the force of gravity.
Good luck and let me know if that didnt help,
Dahaka
  • Santiago Vallejo
    Santiago Vallejo Jul 28, 2008
    Hello Jimphily,
    Go to this website and you will find a forum where they explain how to open up the printer.
    http://www.fixyourownprinter.com/forums/...
    Good luck, and anything else you need let me know,
    Dahaka
  • Santiago Vallejo
    jimphly, check out the forum i posted.
    You will find there how to open it.
  • HP Master
  • 6,487 Answers
Can you please explain your problem further...
  • Mark Gil
    Mark Gil Jul 28, 2008
    Is the printer still working or you just want to get the card that has been drop?
  • Mark Gil
    You need to dismantle the printer for you to get the card inside it if you have the user manual I believe you will find the stpes to open it up....
    Master:
  • 555 Answers
What type of card did you try to insert? SD card?
  • HP Master
  • 691 Answers
Have a look at the solutions posted for the three other posts with the exact same issue.
  • Inky Fingers
    Inky Fingers Jul 28, 2008
    Have you tried placing a vacuum cleaner nozzle over the opening where the card has fallen into. Empty the machine BEFORE you try this, and if you have some available, place a ladies tights over the nozzle to catch the card before it goes into the vacuum bad. If not, use a new bag and let the card go into it.
Belling 351 MK2AN Oven Door bracket back plate fallen inside!!
The only to do it, is to remove the side panel , and depending on the model number, you may have to remove the top also to gain access to the fixing screws.
Please rate my solution.
Thanks.
Nov 07, 2009 | Belling Ovens
My camera is saying that the ''internal memory is full'' -- it's a new card and only has 7-8 pictures on it! what's wrong?
Sounds like you have very large format photos on the memory card and it has reached the capacity of the card. Try setting the camera to a lower resolution if you need more photos in storage or get a larger capacity card. I use an 8GM card and have room for hundreds of photos at typical resolution.
Sep 14, 2009 | Cameras
My Konica Minolta Dimage z5 won't play back photos
What size memory card are you using? I have had this problem trying to use a a 4gb card, which apparently is not compatible with the Z5. Using a 2gb card seems to alleviate the problem.
Jan 03, 2009 | Konica Minolta DiMAGE Z5 Digital Camera
Card reader-wont work! help :(
Remove the camera batteries Put the card back in the photo printer and take all your pics off ,then reformat it and put it back in the camera with the Batteries .
Dec 26, 2008 | Olympus Stylus 790SW Digital Camera
Dropped photocard inside of port and cannot retrieve it. seems to have fallen into a lower port.
Dismantle the cases of the printer to retrieve the card. I could tell you how to do it or or where to get a manual to show you how to do it... but you have not told us any info about your printer... so I can't help further.
Jul 28, 2008 | HP Office Equipment & Supplies
Not able to shoot photos
OK, I have this camera and it started doing this to me about a week ago.  I assumed it had reached the end of it's life after many, many excellent photos.  As a last resort when the lens popped out after first switch on (when it's doing the clicking business) I grabbed the lens and wiggled it gently back and forth (as if zooming a conventional SLR).  It appears to have been fixed, remarkably!  I switched off and switched it back on and all seems OK.  (I'm not holding my breath and will probably keep looking for a new one but for the moment it's sorted out.)
Mar 17, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Downloading from pc to digital photo frame
Solution:
1. I don't think the USB Cable was given to Download Photos from the computer - I think it was given to upload photos to the Computer.
2. The manufacturer has either gave you the wrong cable for a different type of Operating system or you are trying to put it in the wrong port.
Suggestion:
1. Call a Technical Support Line (Probably found on back of instruction booklet.)
or
2. Send the Product back to the company.
Dec 18, 2007 | Cameras
OLYMPUS FE-240 digital camara can't use port to unload photos
You better take a closer look. I know my friend Dave always looks in the wrong place. Here is a link to you manual
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1284
Radio Shack has cables of all sorts if you've lost on but it sounds like you just need a map and some magnification.
Paulpsps@aol.com
Nov 07, 2007 | Olympus FE-240 Digital Camera
Photo preview problem
do you think you broke the switch when it landed mysinse wont come out on my camera so i finally took it apart you know what i found a small watch battery on the circut board maby yours got docked when it fell i wonder how many people have dead batteries and cant figure out what is wrong with their cameras
Apr 23, 2007 | Fuji FinePix E500 Digital Camera
Seeker5211
Seeker5211
