Question about HP Office Equipment & Supplies
Dropped photocard inside of port and cannot retrieve it. seems to have fallen into a lower port.
  • HP Master
  • 691 Answers
Dismantle the cases of the printer to retrieve the card. I could tell you how to do it or or where to get a manual to show you how to do it... but you have not told us any info about your printer... so I can't help further.
Posted on Jul 28, 2008
How do I retrieve the bolt that attaches the main part of the lantern and has fallen inside?
Not sure where it could have fallen into but if you unscrew the top nut you can take off the lens and keep working down taking parts off until you get it all apart. Hope that helps.
Dec 26, 2015 | Coleman Northstar Propane Lantern With...
I dropped a small water pump bolt in the timing
It should be inside the timing cover - most likely on the top of the lower gear teeth.
Oct 13, 2014 | Cars & Trucks
Microwace noise coming from top and flashing
dont use the microwave until you retrieve what dropped inside when you removed the port. The grinding is most likely a foreign object that is hitting the moving parts of the microwave and causing sparking. It can catch fire
Mar 09, 2014 | GE JVM1650 1000 Watts Microwave Oven
Seagate expansion drive 3tb will not power up there may be a disconnected wire any ideas
Sorry for the information request, just noticed that it was dropped.
Chances are the port where the power goes in was damaged, or the controller board. When I break a port, I jiggle the cord in the slot a bit to see if it will suddenly turn on, almost instant proof it's the port. Ports can be easily re-soldered or replaced on the board if the device is out of warranty.
Anything other then the power port will likely require a competent technician.
It's also likely that the drive inside can be removed and placed in a computer to retrieve your data, but this will also void your warranty.
The way I see it, the problem will be how to retrieve your data if you do have a warranty, since Seagate sends you a replacement drive and you send them the damaged one, they usually charge for data recovery.
Feb 27, 2014 | Seagate Computers & Internet
Have a saab 9-3 2.2tid..lowered the drivers side window ,there was a bit of a bang ,can hear the motor but window not moving,,i can lift the glass up an down by hand(off its runner??)..can i do this...
yes, but please consult the workshop as it seems that the link has broken down and the window glass has fallen down inside the door....please get it checked
May 06, 2011 | 2004 Saab 9-3
I lost my photocard for recent pictures taken on my Canon PowerShot SD500. Is it possibe to retrieve any pictures from the camera's internal memory?
If you mean that you lost the memory card and are wondering if the pics are "backed up" on the camera's internal memory, sorry, but that is not the case.
Dec 14, 2010 | Cameras
Plate at back of door hinge on hotpoint aqarius has fallen down
Tilt the washer back, and you will be able to retrieve the back plate from the bottom of the washer.
To refit it, you will have remove the front of the door seal from the cabinet front.
May 25, 2010 | Hotpoint Aquarius WD63 Front Load...
F9 fault. looks like inside drum has fallen away
one of the springs has come off - also ck the lower shock - it may have come apart
Jan 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The hinge of the washing machine has broken - Creda W100FW
The door hinge block has fallen inside the front of the washer.To retieve it, tilt the washer back, and you should find it at the left hand side.
Remove all screws securing 2 parts of door together, prise apart with a screwdriver or similar, and the door will come apart.
You can now access the hinge and all other partsd inside the door.
Trust this helps.
Nov 28, 2009 | Creda W100FW Front Load Washer
It was missed and dropped down.. and it's not being recognised in 'My Computer' but in the task bar it is showing that a new hard ware " A mass storage device is plugged in ' ....
If it shows in Taskbar that it found new hardware then it does detect the PC board of the hard drive but the drive's head mechanics or the actual disk inside have been damaged by the fall and therefore it cannot read off the drive which means your drive has now permanent damage.
Therefore it cannot be detected at bootup...
You may try a DATA RETRIEVAL company to see if they can get your information off the fallen drive.
Jul 03, 2009 | Western Digital (WDXB1200BBRNN) 120 GB...
16 people viewed this question
Ben Johnson
