Question about Garmin StreetPilot C330 GPS Receiver
Garmin C330 Disassembly
How did you manage to disassemble the Garmin C330? I want to install an 1/8 in stereo audio out jack and cant seem to get the case apart to see if there is room for one let alone do the install. Any help would be appreciated.
The silver cover on the front just pops off and you will find 4 screws behind it. Undo then and the covers will come appart the battery and antenna are on the back
Posted on Jul 30, 2008
How can I my 2004 Honda Goldwing mic to work with my Garmin Zumo 665 to answer my cellphone? The phone bluetooth connection works fine with the Garmin in my car, but my Honda mic does not work through the...
The microphone input from the Zumo 665 motorcycle mounting cradle is the smaller 2.5mm jack.
Be sure to use this one as some microphone jacks will require a 3.5mm to 2.5mm adapter.
The audio output is the 3.5mm jack.
Be sure not to confuse the two.
It may be necessary to have a custom 5 or 7 pin DIN adapter made to connect between the GW audio system and the Zumo.
It would be best to consult with your local Honda GoldWing dealer for more information on interfacing the GW audio system.
Oct 07, 2011 | Garmin zumo 665 GPS Receiver
C330 garminstreetpilot not working
hey man your prob is so simple just go through this
1.connect your device to computer
2.go to my com
3.right click on your device
4.click format
5. then restart it now its time to update driver
right click on computer then
1. click properties
2.hardware
3.device manager
4.universal serial bus controller(open the + sign)
5.click upper one double click
6 go to driver
7.click on the update driver
8. then choose second one (advanced) then next
9.click don't search
10.then next next if it is over
same process with anotherone then restart your computer a
Nov 18, 2007 | Garmin StreetPilot C330 GPS Receiver
How do I connect my samsung mm-c330 micro hi-fi system to my computer
If you want to amplify the sound you will probably need an adapter. You will use the audio output jack on your computer to an input jack on your receiver. There are usually several different inputs on a receiver but most use RCA phono plugs. The best choice input jack one the receiver is the one that says "AUX". You can buy the adapter cord at any Radio Shack. You will need to be sure to ask for a 1/8 inch stereo phone plug to two RCA phono plugs. This will split the stereo signal into left and right channels for your receiver.
Oct 30, 2010 | Samsung Audio Players & Recorders
How do you install an audio output device?
this depends on what kinda audio output you want to install ..but the general idea is to get the audio signal from the computer from the green out in the back on the sound card (it is a 3.5 jack ) ..and there is the stereo out-put for the computer's sound..It can be amplified in any device that has a stereo input on 3.5 jack ..
if you want something more complicated..the map of the out-put (the scheme) will be shown in the sound manager (of teh driver ) ..when you make the output changes..This is on a color code..and can be 2+1...3+1..4+1..and the surround 5+1..when you choose surround 5+1 from the sound manager ..it is shown all 3 outputs and the role they play ..bass+center ...Front ...and rear ..they are 2by 2 stereo paired on left and right ..
Sep 02, 2010 | HP PAVILION A6230N DESKTOP PC
The internal battery is dead. How do I replace the the old battery with a new one. Please explain how to open the battery compartment and how to install a new lithium-ion battery.
The internal battery, that only Garmin can change. It would cost $125 just to send the unit in if it needed work outside of the warranty period.....hopefully the battery will last about five years.If you get it replaced from Garmin. If still you want to void the warranty and get it opened then there is step by step images shown how to open the unit.But that actually damages the unit. Click this link directly:--- There are total 26 images showing step by step procedure.Click on each image and continue disassembly. http://content.techrepublic.com.com/2346-22_11-178052-6.html?tag=content;leftCol ---------------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Garmin StreetPilot C330 GPS Receiver
PROBLEM
Your PC has an audio output jack it is a 1/8th inch stereo jack. Your TV has a PC audio input connection (usually RCA jacks red and white). You need a cable that can connect the two together. It will look something like this:
I hope this was helpful, best wishes.
Mar 30, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Garmin c 340 froze- what do I do
This solution is for c330 but it should work the same...
It took a nap...
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Jan 21, 2009 | Garmin StreetPilot C330 GPS Receiver
How to update my garmin c330
Either Jack it to a Pc and run the dvd software,
Or copy the files to the Nuvi drive folder, in your My computer,
Go to Menu, maps,map info, tick any boxes that are needed,
You may need your unit I.D. to activate
Menu-tools-system-about,
Serial number is on the sticker,
You can also do all this management too at Garmin.
Go to your account at Garmin.com/managemaps.
Hope this helps
Regards.
Jan 16, 2009 | Garmin StreetPilot C330 GPS Receiver
GARMIN NUVI 350
HI Heather,
Make sure you don't have the sound muted. Have you tried plugging in a set of headphones into the headphone jack? If you can hear sound with the headphones, most likely, the internal speakers have failed. If you still can't hear any sound, the audio output stage on the motherboard has failed. In either case, you will need to send the unit back for repair. Be sure to have your serial number handy. Register it online https://my.garmin.com/mygarmin/marketing/register.htm
if you haven't already done so.
Hours:
Monday - Friday
8 a.m. - 7 p.m.
Central time (closed holidays)
1-800-800-1020 (U.S.)
1-866-429-9296 (Canada) or (913) 397-8200
More Info: If you can hear sound through the speakers and don't want to send the unit back for repair, you can buy a FM transmitter at Best Buy - the kind that will allow you to play a portable CD player through your car stereo. Just plug the transmitter's audio input cable into your GPS headphone jack, power the transmitter with your car lighter jack, set the transmitter frequency to a unsued FM channel and tune your car stereo to tha same channel. You should hear your GPS through your FM stereo.
Good Luck,
- Jim
May 15, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
760 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
