Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Unable to get faxes to print to legal size
I have my L7780 set for legal size paper but all my faxes continue to go to the letter size tray.
Any suggestions.
    Novelist:
  • 106 Answers
here are the steps that i want you to follow inorder to use the tray for legal size.
1. On your printer itself, Press the SETUP BUTTON.
2. Scroll Down, and look for the option "Preferences", then press okay.
3. Scroll down again, then look for Tray Lock, and press okay.
4. Under Tray Lock, you will have an options there;
- Tray 1
- Tray 2.
5. If you are using the legal size paper for tray 2, then choose Tray 2 and press okay button to apply. And if you are using the Tray 1 for the legal size, you can go ahead and choose Tray 1 and press okay to apply. And this should work.
If in case you still have issues setting it up, please inform me.
thank you so much.
adonscott
Posted on Jul 29, 2008
Canon IR1022if copier can't print in Legal size(8.5inx13in) using bypass or even paper cassettee
Did you trying hitting an Ok button, green button, etc to confirm legal size paper, maybe it wants you to confirm paper size. Also legal is 8.5x14, did you select legal or enter the size as a custom page?
May 22, 2014 | Canon IR1022IF 220-240 VOLT, 50/60HZ
Everytime I receive a fax, the first page prints out then I get a "Check paper size" error
Sounds like you have the paper size in the tray set incorrectly. For example, it may be set to legal, but you have letter size in the tray. This would cause that message to display. Check your setup options for the paper setting.
Jul 14, 2009 | Brother IntelliFAX 4100 Laser Fax
I have a T620 that won't print from the trays because it continues to show ''Load MP tray'' on the display. When I drop down the tray and load the multi-purpose feeder, it will print what's in the queue....
Turns out that the paper tray was damaged - the tray was unable to determine the correct paper size, despite fooling with the green paper stop. I had to compare it with a known-good tray to see the problem.
Apr 28, 2009 | Lexmark Optra T620 Laser Printer
I need my HP Officejet Pro L7780 all in one to pull either legal size or standard size paper, it will only pull standard size, I have two paper trays
In your print queue under device settings, you have to tell the computer that your using legal paper and in which tray.
You can permently set it like this....
Start > Control Panels > Printer and Faxes >
Right Click on the Printer Icon > Properties > Device Settings
and choose the Tray and assign the Paper Size.
If the tray is not selectable, look in the same area for Installable Options and set the tray as installed.
Within a program you can do it on the fly one time like this...
File > Print > Properties > Advanced > Paper Size
But, the paper must be in a default tray for this mode.
This info may vary for different printers and applications.
Nov 19, 2008 | HP Office Equipment & Supplies
Loading legal-size paper
:) it should load in the same tray as the letter size, you may need to adjust the tray adjustments to accomidate it, the paper setting are located in the print settings are you click print.
Oct 13, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Jan 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Canon LaserClass 7000 - Receiving problem
Make sure the rear guide is pushed up tight against the paper.
Remove all legal size paper and make a copy.
Dec 13, 2007 | Canon LaserClass 7000 Plain Paper Fax
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
96 people viewed this question
Seeker5211
Seeker5211
