When going to print to a laserjet 4000pclx printer I get an error code 7900FE. What is it and how do I fix. it.
  • 67 Answers
If you have cleared the print queue so there are no outstanding 'faulty' files; it's worth knowing that the 79.00 error can also be caused by poorly fitting or incompatible memory cards.
To clear the printer queue on PC
click on start
click on run
type: services.msc
scroll down to print spooler
right click on this service then press restart
exit out and try again other wise continue below..
Can you make sure they are firmly mounted?
Remove all communication cables so that only the power cable is connected.
Remove the Jetdirect card, if installed.
Remove any other accessories, such as the envelope feeder.
Hold down the green "GO" button.
Turn the printer on.
When the words "Cold Reset" appear in the display, release the green "GO" button.
When "Offline" appears in the display, press the green "GO" button. "Ready" should appear in the display.
NOTE: If the words "Cold Reset" do not appear in the display, hold the "GO" button down until you hear the motors rotate. The words "Restoring Factory Settings" will appear in the display if the "Cold Reset" was performed successfully.
Turn the printer off once the printer displays the “Ready” message.
Reinstall each of the above-mentioned components, one at a time, turning the printer on and off again each time a component is installed.
Continue installing and power-cycling until all accessories are installed and the printer is at a “Ready” state.
If it is determined that one of the components is responsible for the 79.00FE error, refer to next.
If the printer will not return to a “Ready” state after removing all of the components and performing the cold reset, try a different power source by moving the printer to a different location and plugging the power cord directly into the wall.
If the printer continues to display the 79.00FE error, upgrade the firmware. A firmware DIMM can be obtained from the HP Parts Store at . Version 6.36 Firmware DIMM is Part Number C4251-67905; however, part numbers are subject to change without notice.
If the printer still continues to display the error, contact HP for further assistance.
Posted on Jul 28, 2008
49.4C06 SERVICE ERROR For HP LaserJet 3800dn..Anyone had this code??
You need to update the firmware on the printer. This error indicates that the printer has received a print command it does not understand. Go to and search for updates for your printer.
Jun 27, 2016 | HP LaserJet 3800dn Printer
There is an error code on my HP LaserJet P3015 which reads 49.4C02 ERROR
HP LJ P3015 with 49.4c02 error - tried lots of things in the end went into printer driver right clicked and then clicked troubleshoot - windows came up with a fix dont know if it is permanent - troubleshooter said a print job was deleted from the print queue. Presume the printer tries to print the problem job in the queue each time it is switched on.
Oct 10, 2013 | HP Laserjet P3015X Printer
How to clear error code 49.4c18 on HP laserjet 4250
any 49.xxxx codes are related to firmware crash.
the probable cause is a corrupt file in the print queue. remove the printer from the network then after network is disconnected - cycle the power on the machine ( switch off then wait 10 seconds switch back on)
the 49 error will probably clear . if so Clear All print jobs in Print queue on the computerr workstation. then reconnect printer and away you go!
if however the error remains then you will need to Upgrade the firmware or replace the firmare chip/formatter ( unlikely I've only ever replaced one out of thousands of calls for this fault)
Nov 04, 2012 | HP LaserJet 4250n Printer
Hp laserjet 4200n has an error code of 49.4c06 service error what do i do to fix this?
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Dec 08, 2010 | HP LaserJet 4200n Printer
Hp laserjet 3055 has code 52 scanner error and wont print or copy
PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
Jan 15, 2010 | HP LaserJet 3055 All-In-One Printer
Error 49A What does this mean?
Hi! I will be glad to assist you. If this is your issue, here are the steps you need to do:
HP LaserJet P3005 Printer Series - Service Error 49.0E00 when Printing PDF Files from Mac 10.5
A Service Error 49.0E00 message appears while printing PDF files from Mac 10.5 with the EconoMode setting enabled from the printer control panel and using the printing presets with the EconoMode setting disabled.
Recommended action:
Disable the EconoMode setting from the printer control panel (the default setting is OFF ).
Select printing presets with the EconoMode setting disabled.
Try performing a test print from PDF files in the computer to check for the results.
NOTE: If it is required to use a printing preset with the EconoMode feature turned off, ensure that EconoMode is set to OFF from the printer control panel also.
or you can go to this link:
Oct 05, 2009 | HP LaserJet 3055 All-In-One Printer
Printer error code 5952 - ?
From the service manual:
An error occurred with the magenta printcartridge drive motor during startup or rotation.
To fix:
1. Check that connectors J5003 on the magenta print-cartridge drive motor and J207 on the DC controller are seated correctly. If they are then:
2. Replace the magenta print-cartridge drive motor. If that doesn't work then:
3. Replace the DC controller.
Jul 08, 2009 | HP LaserJet 3600n Printer
Printing Problem
Dec 20, 2008 | HP LaserJet 4250n Printer
Printing problem "PCL XL error"
Dear Sir
My printer is laserjet 1320
PCL XL error
Subsystem: KERNEL
Error: Illegal Tag
Operator: 0x1b
Position: 6
Pls. This problem solution give me.
May 29, 2008 | HP LaserJet 1320n Printer
PCL XL ERROR subsystem: Kernel Error: Illegal Tag Operator :0 x 1b Position: 6
Apr 12, 2008 | HP LaserJet 3030 All-In-One Printer
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
