Question about Kitchen Ranges
Accel Cleaning Setting
I need to know what the Accel Clean setting means on my pre-1980 Jenn Air Model 88370 range. It came with the house and I have no manual to look things up. I am wondering if I have a self-cleaning oven or a continuous clean oven.
It's 'sort of' self cleaning. I just got done figuring it out. If your clock still works, you're supposed to set it for one hour of cooking. Turn the Selector to Accel Clean and the thermostat to 550. The oven fan should come on and the elements should heat. The door doesn't have a lock, which must explain why it only 'cleans' at 550°F.
Posted on Oct 18, 2008
  • Oliver Street Oct 03, 2010
    I've owned one for 30 years and the preceeding solution - set to Accel Clean, 550F an hour or so - is correct but incomplete. The oven lining ceramic is a catatytic ceraminc cleaning type, meaning that it will cause material in direct contact with it to oxidize at lower temperatures. The key to using this oven feature correctly is to remember that it only acts on what is actually directly touching the ceramic.. Remove the bulk of material from any spill as promptly as is practical and the oven lining will go to work on the rest as you cook if you bake hot enough, or use Accelerated Cleaning if needed. NB: The chrome racks don't have any special catalytic properties - you have to remove the racks to clean them. The wall part of the rack slides up then you can take it out. There should be an extra sheet of lining in the bottom of the oven that is also coated and is also removable which is helpful for cleaning up spills.
    To avoid damaging the ceramic lining of the oven the orginal instructions were quite clear; DON'T USE OVEN CLEANER. DON'T USE STEEL WOOL, BRILLO, OR ANY OTHER ABRASIVE STRATCHING OR SCRAPING TOOL.
Cleaning a self cleaning oven
I couldn't find any information on that specific model number, but here is a link to a generic Jenn-Air Electric Range - Use and Care Guide which seems to be model non-specific. The instructions for performing a self-cleaning (as well as other tasks) might be the same for yours.
http://www.jennair.com/assets/product/8113P619-60.PDF
Jan 05, 2008 | Ovens
Installing Jenn-Air 88370
Jenn-Air.com/ Support online can help you
Apr 22, 2009 | Kitchen Ranges
I don't know how to set my self cleaning oven to clean.
There's no such setting because there's no build-up of cooking residue - hence self-cleaning. You will need to clean the trays though because it's impossible to make them self-cleaning.
Nov 22, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn air 88370
I have a similar Jenn Air oven approximate date 1982. It has a catalytic liner (colored a kind of dark charcoal  with paler flecks), so it is a continuous clean oven during normal cooking.  However, it also has the Accel Clean setting on the control knob. This increases the oven temperature to maximum and also runs the convection fan to burn off cooking residues. This allows the catalytic lining work at high efficiency, and burn off stubborn residues that are not removed at normal cooking temperature. The oven may emit smoke through the top door vents as the food residues burn off, so watch that you do not set off your smoke detector. I switch on the cooker hood fan and also put a fan in the kitchen window (blowing air out of the kitchen), to avoid setting off my kitchen smoke detector if I use Accel Clean.
Jul 28, 2008 | Kitchen Ranges
Jenn-air gas electric grill range
any power to unit at all?? clear, start, clean ,button?? what happens when you push them??? clock on?what happens when you try to set to clean again??? it should activate hte door lock latch at which point cancel and it should reset itself. with any luck! what happened thankgiving how was it fixed
Mar 14, 2008 | Kitchen Ranges
Jenn-air oven model #88370
its just not that often the probe fails without setting a code
Feb 16, 2008 | Jenn-Air JJW8530C Expressions Collection...
Problem with Jenn Air Gas Range???
are you talking about the burners or the oven reply with model num and dont rate me till we are finished
Jan 02, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Kitchen Ranges Logo
506 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
