Question about Pentax Optio T10 Digital Camera
Memory card I recently bought the Pentax Optio T10 digital camera and I'm trying to get/use the correct memory card. Can't seem to find online which card(s) work with this camera. I have a Patriot 4GB SD card and it doesn't work, I get a "Card Error" message on my screen. Does this card fit this camera? If not what cards will? Thanks! Charles
  • AU2SI Jan 06, 2009
    . Can't seem to find online which card(s) work with this camera. I have a Sandisk Ulta II 4GB SDHC card and it doesn't work, I get a "Card Error" message on my screen. Does this card fit this camera? If not what cards will?
    Thanks!
    Ed
  • 423 Answers
Hi and welcome to FixYa.
Your camera will not work with an SDHC card. It must be an SD card.
Don't forget to format the card in the camera after you install it. Elsewise it won't work properly.
Thanks for coming to FixYa, and feel free to rate my solution.
Rob
Posted on Feb 25, 2009
You have the right SD version of the memory card. Perhaps you need tor ty a different brand of memeory.
My Pentax Optio WP beeps 3 times, goes dim and turns off. The battery is charged up fully. Any suggestions?
Hi Jesslionbery,
Please try removing the memory card that has been installed in it , if any.
When you remove the memory card make sure it starts.
If the above trick does not work , try using NIMH battery instead of the ones that you have in and check if it works.
Also if you update the firmware of the camera , it may solve your problem, please find this link for more information , as the crashing problem has been resolved for many because of a firmware update.
http://www.pentaximaging.com/customer_care/show_firmware?firmId=6442215.
Hope this helps ..:)
Jun 28, 2011 | Pentax Optio T20, T10, A20, A10, W20, W10,...
Pentax Optio T10,comes up with Card Locked, when turned on
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 23, 2011 | Pentax Optio T10 Digital Camera
When I put my 2gb Sandisk memory card in my pentax optio 33lf, it turns on, the lens goes out, it takes a photo and freezes. What is the problem? If I take the memory card out, it works fine?
My 33LF won't work with even a 1gb Memory Card. It freezez up as you describe.So far it seems happy enough with 512mb cards. A camera shop operator told me that the capacity of the card exceeds the capacity of the camera and it seems he was right.
Jan 08, 2011 | Pentax Optio 33LF Digital Camera
Just bought a used Pentax Optio 750Z online. Am trying to use 2GB San Disk Memory Card. Camera will not accept it. Monitor reads.."Memory Card Error". Is 2GB too much capacity? Is camera...
Is it a SDHC card? SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
You could try formatting the card. There is a function in the camera menus to do this. If it won't format then it may simply be too high capacity. It is often difficult to find out the maximum capacity a camera will use, as today's memory cards are much larger that those available when the manuals for even recent cameras were written.
Nov 07, 2010 | SanDisk Cameras
Memory Card Error on 4 Gb CF cards (80x) for Pentax Optio 430
The maximum supported memory for Pentax Optio 430 is 256mb and for Pentax Optio 430 RS is 512mb.
Check this site for more information.
Optio 430
http://www.upgradecomputermemory.com/ram.cfm//memory/P/Pentax/Pentax-Optio-430/
Optio 430 RS
http://www.upgradecomputermemory.com/ram.cfm/memory/P/Pentax/Pentax-Optio-430RS/
Jun 10, 2009 | Pentax Optio 430RS Digital Camera
USB cable problem when transferring
could be a bent pin maybe?
I would just go out and buy a card reader so that you can read the memory card without the cord. and then you wont have to worry about it.
the card reader cost about 20 a new cord would be more.
Hope that helps,
Caleb
Jun 26, 2008 | Pentax Optio T10 Digital Camera
Memory card not working
Not saying it is, but are you absolutely sure its not the camera software itself. Does it have any warranty? Is the card a new card and have you made sure that the TAB on left of SD card is not allowing READ ONLY. The tab flips up allowing the card to be formatted bit like the old floppy disks.
Apr 26, 2008 | Pentax Optio T10 Digital Camera
Pentax Optio T10 turning off immediately
My optio t10 did basically the same thing...turned on, lens goes out, then automatically shut off. I took the advice of a solution listed here for another problem...hit the camera. For whatever reason it worked.
Apr 08, 2007 | Pentax Optio T10 Digital Camera
Pentax Optio T10 Digital Camera Logo
184 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
