Question about Panasonic Microwave Ovens
My panansonic microwave NN-T573SBBPQ works for 2-3 seconds then turns itself off! the lights all work, turntable goes around, fan works, time is on.
  • Panasonic Master
  • 9,098 Answers
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Aug 02, 2008
Why does Panasonic nn-sn651 usually work; but sometimes, turntable won't start ?
This is an inverter model so there is no diode or hv capacitor.
You must adt. the door latch switch assembly to make sure that the door hooks make contact with the switches. Common problem is that the assembly is bent and must be perpendicular to the door.If it is bent the switch will not make contact with the door hooks.
Place a dab of lithium grease on the tip of the door hooks to ease closing the door. This is the cause of the bent switch assembly!
Aug 31, 2014 | Panasonic 1.2 Cu. Ft. Mid-Size Microwave -...
The turntable keeps rotating when the door is opened - Panasonic NN-T994SF
You probably have a shorted main relay on your control board, which I can repair. Details here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 25, 2017 | Panasonic NN-T994SF Microwave Oven
Panasonic microwave NN-S666BA
No! the main fuse is okay because you would not have any power. I would check all door switches because they control light, fan, and turntable. If you are handy with a meter, set to ohms, disconnect one wire on side of switch, use meter to test, readings should show open/short when pressing the button and releasing it, replace wire to switch and repeat, if you hit one with the same readings pressed in or out, change the switch.
Mar 06, 2012 | Panasonic NN-S666BA Microwave Oven
My Panasonic Microwave NN-T573SBBPQ cuts out after 3 seconds. what can I do? Or am I better of replacing it?
This sounds like a magnetron problem, if it gets to hot, there is a special thermal fuse that will open up if it senses abnormal temperature rise from the magnetron and after a cool down period it will reset itself. In rare cases I have known the thermal fuse to become defective and cut out prematurely. My feeling is replace the oven! because by the time you get a appliance repairman in for a sevice call and parts you probably could have bought a new microwave oven.
Jan 19, 2011 | Panasonic NN-T990SA Microwave Oven
Turntable doesn't rotate
Your turntable motor need replacement. tip upside down with dish removed and gain access to turntable motor from underneath.(remove power plug before you start working on the m/wave.) 2 screws hold the small t/table motor in place.Unscrew both and pull motor upwards. Quote the info on the motor for a replacement. I find cooking isnt effected in any wayexcept if you want to bake things like cakes. It then requires the t/table motor.
May 21, 2010 | Panasonic NN-T993SF Microwave Oven
Panasonic dimension4 microwave
check the damper motor is opening and closeing
Jan 17, 2010 | Panasonic NN-T888S Convection/Microwave...
Panasonic Microwave NN-S935BF turntable and light do not work. Microwave still works. Bulb and turntable motor okay. No power to light or turntable. Any ideas?
Your description seems to be confusing turntable and light do not work
Bulb and motor OK
Which is it?
They could be separate incidents. The drive motor could be fused and the globe just blew its life away..
Aug 15, 2009 | Microwave Ovens
Turntable wont stop turning, even when not in use
The turntable is a seperate intenty from the microwave itself, I would presume that the switch that turns off the turntable when the door is opened needs replacement.
Feb 28, 2009 | Panasonic NN-H965 Microwave Oven
NN-A574SBBPQ - Microwave fans & turntable not working
2 fuses in a panasonic does not sound enough.
have you checked the main incoming power protection fuse normally 10amp or higher.
most panasonics have approx 4 fuses so keep on looking
Feb 10, 2009 | Panasonic NN-S961 Microwave Oven
Microwave Ovens Logo
284 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
