Question about Lexmark C752FN Printer
Lexmark x5320
How can I fax more than 1 page at a time. I lost the manual during a move.
    Problem Solver:
  • 19 Answers
When you load the document feeder, simply place all of the sheets, up to I believe 25 sheets at a time in the document feeder. The doc feeder, if working correctly will load them one at a time and then exit them to the receiving shelf or tray on your printer.
If you do not have a document feeder, or must use the manual scan function for some reason, there is also a FAX multiple pages function from the sub menu.
ZBob
Posted on Jul 28, 2008
Lost CD for install and use the FAX on Lexmark X75.
you can contact Lexmark support http://support.lexmark.com and they can help you get your fax up and running.
Nov 03, 2009 | Lexmark X75 All-In-One InkJet Printer
Carrier Jam(lexmark x5320)
In this case unplug the power supply from the Printer........... 1. Open the Printer Cover.......... 2. Remove both the Catridges from the Printer............ 3. Move the Catridge Carrier which holds the catridge from right to left and from left to right for about 10 times............ 4. Try to make a copy without the catridges........If this works and it gives a Blank Page out............ 5. Insert both the catridges turn the printer off and turn it on again........... 6. Now it should work fine........ Good Luck......
Jan 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
Fax machine
Somehow the fax go set from Auto Answer to Manual.
Setting Auto Answer to on
1 From the desktop, double-click the Productivity Studio icon.
2 From the Welcome Screen, click Fax History and Settings.
3 From the “I Want To” menu, click Adjust speed dial list and other fax settings.
4 Click the Ringing and Answering tab.
5 From the Auto Answer drop-down list, select On.
6 Click OK to save the setting.
The Auto Answer light on the control panel comes on. When the number of rings you set is detected, the printer automatically receives the incoming fax.
Sep 27, 2008 | Lexmark P4350 All-In-One InkJet Printer
I do not have a disk to setup the lexmark printer X5320
You can go to the link below put in the necessary information then on the next page you need to enter your model number X5320 it will ask you to put in the kind of WIndows or Mac that you have then give you the contests of the disk to download
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Please message if you have more questiosn
Sep 06, 2008 | Lexmark Office Equipment & Supplies
LEXMARK X7170
Hi - You can view the manual from the link underlined in blue below:
Lexmark X7170
Changing information that appears on your fax cover page
  1. Click Start onestep.gif Programs onestep.gif Lexmark 7100 Series onestep.gif Lexmark Fax Solutions.
  2. Click View Cover Pages.
  3. Click Change your personal information that appears on this page.
  4. Make any changes.
  5. Click OK.
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 21, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Newly installed won't stop jamming paper
Paper Jams in the Printer ID:412
Turn the printer off and open the access cover.
Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Watch the paper as it feeds through and try to determine where the jam is occurring.
Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
Turn the printer off.
Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
If this didn't work please replace the printer by the company..
Apr 08, 2008 | Lexmark X5470 All-In-One InkJet Printer
Installing my printer
little shana:
the closest match for "lexmark 5300" is the lexmark X5320. Here are the drivers for that model:
Please let me know how you make out.
thanks.
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:24:0:0
Jan 31, 2008 | Office Equipment & Supplies
Lexmark C752FN Printer Logo
74 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
