Question about Hitachi 42V710 42" Rear Projection HDTV
52" hitachi projection tv 98? convergence problem
How can you fix the convergence
  • 1 more comment
  • 86chevy Jul 28, 2008
    how can i fix the convergence on my 52" hitachi tv app 98?
    the picture on my 98? 52" hitachi tv is distorted maybe the convergence
  • bstevens321 Sep 08, 2008
    My TV also has some thing similar happening to it.
    If you turn the TV on it looks like it is on a channel that has no reception. You can hear it fine but there are a ton of lines over it making it have a horrible picture. You cant even see the picture. I can change the channel and hear the diff channels but I cannot hear any thing.
    I know that it is not bc I am out of range since I can hear every thing fine and I have cable.
    Please tell me what you think it is.
    Thank you,
    Novelist:
    Champion:
  • 211 Answers
Tell me more about the convergance problem. Are the colors all seperated? Did this happen all at once??? Give me a call at my shop and I'll talk to you direct on the problem. 307-266-4675 Mon-Fri 9-3 MST.
Ed
Posted on Jul 29, 2008
2 Suggested Answers
atelier mj
  • 70 Answers
SOURCE: 52 Hitachi rear projection T.V. (model #, 53FDX01B)
look for EP98, Q655 and D756.
Posted on Apr 22, 2010
We have an 80's hitachi mts 52" tv/ monitor and it has a 3d effect how do we fix this?
Tv have a problem known as convergence problems,it dead.Tv R,G,B colors lines mis alignment,Colors shadows or 3d pictures effect.The tv convergnce board is dead.The tv convergence board,require replacing 2 STK convergnce ICS and some or all it resistors.To solved tv convergence board,to solved tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Sep 11, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Blue shadow hitachi 52"
No,ur tv have a problems known as a convergence problems,it dead.The tv convergence board must have it 2 STK convergence ICS and some or all it resistors must be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 16, 2010 | Hitachi 43GX01B 43" Rear Projection...
I have a double screen , bended on the sides what is the fix??? red kind of 3 D. It is a Hitachi 52 in projection hdtv model # 53fdx20b. Aprox how much will it cost to fix? Can I fix it myself?
You can fix it yourself but it involves two things--being able to get at the convergence chips and being able to solder etc....
Not a difficult repair and total parts cost should be under 30 dollars.
Let me know if you need help as I am here to help.
I will give help and options if you ask.
IF THIS HELPED YOU rate this solution as I do this here for free.
SD TECH
Jan 30, 2010 | Hitachi 53FDX20B 53" Rear Projection...
3D blurry picture
The convergence ICs and resistors need replacement. The DPTV305-345 convergence repair kit works for most Phillips rear projection Tvs. The kit contains the two ICs 12 resistors and the CD with detailed instructions
http://www.tvrepairworld.com/
Jul 22, 2009 | Hitachi 43UWX10B 43" Rear Projection...
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
Remote for hitachi 52 inch projection tv not working
1st step, replace battery of remote, no result, 2nd step, check / replace Remote Sensor of TV.
Aug 02, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi Projection Color Lines
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
Hitachi Tv
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Nov 22, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
Hitachi 42V710 42" Rear Projection HDTV Logo
164 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
