Question about Norelco Health & Beauty
Norelco 9160 XL
So, im shaving just like any other day and when i go to turn off the sahver it wont turn off. It keep running until the battery runs out and then when i try to plug it in to chareg nothing happens. any thoughts>
  • billyb02 Aug 13, 2008
    My 9160XL will not turn off. The only way it stops running is when the battery runs down. It's 9 months old and I can't use it anymore.
  • Anonymous Mar 14, 2014
    wont stay turned on stops immedietly wont turn on norelco xl
Two rotors are broken
Posted on Aug 09, 2008
Model 7810xl charged wont run?
Model 7810XL is several years old. If it will not run, the problem is likely the battery is dead. If you need a replacement battery for this model, they can be found at shaveroutlet.com
Shaver Battery Pack for most Norelco More
Jul 23, 2014 | Health & Beauty
Norelco 8140xl new blades doesnt shave
Did you use part HQ9 for your replacements? Norelco makes many different replacement heads and only one type is correct. The correct type for model 8140XL can be found at shaveroutlet.com below
http://shaveroutlet.com/norelco-philips-hq9-replacement-heads-p-252.html
Feb 02, 2014 | Norelco 8140XL Electric Shaver
I installed 3 new heads but the shaver just is not shaving off my 5 day old beard... It's battery seems fine as the motor seems to be running at normal speed. Confused Carl
Your Norelco shaver is not designed for cutting 5 days of growth. Your shaver is designed for cutting one, maybe two days of growth only. Use the trimmer on the back to cut the whiskers to a shorter stubble. Then the hairs will more effectively poke through the holes and slots in the combs allowing the blades to shave them as designed.
May 08, 2011 | Norelco SmartTouch 9160XL Electric Shaver
I m loking for phlips shave battery # 6885
norelco replacement battery NiCd two batteries pack for electric shaver philips norelco 6885xl replacement parts.
Dec 26, 2010 | Norelco Quadra 6885 XL Electric Shaver
Where to buy replacement shaving head unit for norelco 5801xl?
www.shopping.com
www.bizrate.com
www.drugstore.com/...norelco_reflex.../replacement_heads_model_hq5.htm
Jul 09, 2010 | Norelco Reflex 5801 XL Electric Shaver
Battery replacement
mcdevito75 here, Not so easy to replace the batteries as 1 Norelco system has batteries soldered to a circuit board, and you wold also need a set of torx screwdrivers available at any auto parts store to remove the old batteries, lift the sahver head to view thes escrews pr check online at Norelco.com Battery replacement, you may have to replace the shaver.
Jun 19, 2010 | Norelco Quadra Action 7864XL Electric...
Red light at bottom flashes even when razor ids fully charged. What can causrethis?
When the battery is almost empty (when there are only 5 or fewer shaving minutes left), the battery symbol lights up red.
Make sure that the battery does not have a memory effect. What I suggest is taking the shaving head unit off and running the shaver till empty, then recharging. Check if the red light is still flashing.
There's also a head indicator at the bottom of some shavers.
To remind you to replace the shaving unit, the shaving unit symbol flashes (all types) and you hear a beep when you switch off the shaver (RQ1090 only). This happens at the end of 7 successive shaves to remind you to replace the shaving unit.
Without knowing what model you have it's difficult to diagnose further.
May 23, 2010 | Norelco Arcitec Electric Shaver -...
Shaver was running slow and then died. Replaced
Your original symptoms sure sound like dying batteries. Brushes can wear out. Check if it runs better if you change the orientation of the shaver. Does holding it upside down make it work better or worse? If the speed changes, its probably the brushes. You can buy new brushes, but the Norelco repair place will probably give you a hard time since they want to repair it for you so you have to insist. I have made brushes for the shaver by filing down brushes from some other motor, but this is messy and doesn't always work.
Jan 23, 2010 | Norelco Reflex 5821 XL Electric Shaver
Health & Beauty Logo
153 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
