Question about Ventamatic Direct Drive Whole House Fan With Univer
Whole house fan does not draw air
Everything seems to work, fan moves hi and lo, but it does not have any draw of air. I can stand right underneath it on hi and it won't even move a piece of paper on my hand. I had a whole house fan in my last house and it really caused the air to move in the house. What should I do?
  • 75 Answers
Capacitor is worned out so pl change the condensor and u ll find the difference out lot of air moving around u
Posted on Jul 31, 2008
Furnace transformer/fan-relay wiring to fan-motor
All you need is 2 fan speeds, 1 for cool and 1 for heat. Leave the low speed disconnected. Normally we have high speed for cooling, and med. or low for heat. So either speed connected to the heating circuit is fine.
Apr 12, 2017 | Heating & Cooling
Hi my Therma-Stor is not working, the motor makes a humming noise but does not move. Do you no what could be wrong with it? Thanks
Check that the fan blade is not binding on the inner surface of the fan housing preventing rotation. If the blade is free to turn, then it is likely a motor or motor-capacitor issue. Call Therma-Stor service for help diagnosing this problem and for service parts 1-800-533-7533.
Aug 25, 2011 | Therma-Stor Phoenix Axial Air Mover Stand...
The outside unit of a whole house air conditioner
replace start run capacitor of motor fan
Aug 17, 2009 | Heating & Cooling
Whole house Fan Stops running after 10 minutes
Tightened the belt, lubed the fan and it seemed to work intermitantly.... Still ahving ussues..
aaaarg!
Jun 20, 2009 | Ventamatic Direct Drive Whole House Fan...
Continuous squeeky noise from underneath the burners.
Permanently? A fan will come on when using fan forced, another fan will come on(approx 5-10 minutes) later, which is the cooling fan,and can run for up to an hour after turning off. Turn off oven at mains to determine if it is electrical related fault.
May 23, 2009 | Smeg 24 in. DWF614SS Stainless Steel...
'88 Camry AC buttons not working
fan speed controler could be bad, fan motor rellay could be bad.
Apr 14, 2009 | 1988 Cadillac Sedan DeVille
HE220A1019 Whole House Humidifier
Is the unit on the return side or the supply side of your system ?
Is the system upflow or downflow?
You are right in your assumption about the air needing to be drawn through the Humidifier, now before changing the direction of the motor, we need to look at if the unit should be moved to the other duct, its alot less complicated, now when the fan comes on from the furnace, you have no trouble heating the house right ? if that is the case then moving the humidifier to the other duct would be your best bet, if your heating for some reason is only comming out of the return then yes you will need to change direction on the fan, but I would bet that moving it would do the trick for ya, I have only run into a couple of fans that actually were running the wrong way, thats why I asked, well anyways, you will need some tin, zip screws, tin snips, maybe a little more wire, let me know what ya find, I really appriciate your question back to me, anymore question please ask ! thanks again.
mr.grzz
Jan 25, 2009 | Dryers
Lack of humidity
Try the following test, ( I will resume this is a flow through humidifier)
Spray water directly oin the filter make sure it is saturated. Some water should leak from the bottom. After 10 min measure the Humidity to see if this helped. If there is a higher level of humidity the pbm is that not enough water is saturating the filter. Check the level of the filter & water feed nozzle.
Option 2 is to connect the water feed tube to a Hot water source.
Hope this helps.
Dec 28, 2007 | Honeywell HE220A1019 Whole House...
Ventamatic Direct Drive Whole House Fan With Univer Logo
243 people viewed this question
Top Ventamatic Dryers Experts
Are you a Ventamatic Dryer Expert? Answer questions, earn points and help others
