Hello The One For All 4 Device Universal Remote Control is preprogrammed at the factory to operate an RCA TV, a Toshiba DVD player, aMotorola cable box, and an RCAVCR.To control devices other than the default brands,performthe following steps; otherwise skip this section: 1. Turn on a desired device (e.g.,VCR or DVD player) and, if applicable, insertmedia (e.g., cassette or disc). NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step 2. 2. On the remote control,press a device key once (i.e., VCR/PVR, DVD,CBL/SAT,or TV). NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press VCR/PVR once.After programming a VCR Combo device, you will be able to control channel selection, volume,andVCR functions. NOTE: To program control of a DVD Player,DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions. NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SAT once. 3. Press and hold SET until the LED (red light) blinks twice, then release SET. 4. Use the Manufacturer's Codes (starting on page 36) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly, the LED will blink twice. NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again. 5. Aimthe remote control at the device and press POWER once.The device should turn off. If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works. If it still doesn't work, try Searching For Your Code on next page. NOTE: If the device does not have a POWER key, press PLAY. 6. Repeat steps 1 through 5 for each device you want to control. For future reference,write down each working device
Codes for Mitsubishi with one for all URC 4220 are:
0093, 0150, 0178, 1250
code in the following boxes:
OK.
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or aVCR, turn on the device and
insert the requiredmedia.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aimthe remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns
off (after pressing POWER). If the device does not have a
Power key, you can substitute another function, such as
digits 0 ~ 9 , CH , or PLAY).
NOTE: In the searchmode, the remote control will send IR codes from
its library to the selected device, starting with themost popular code
first.
5. To lock in the code,press and release SET.The LED will blink
twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
