HP Printer 4280
Jammed paper, no manual or literature with me now.
  • Anonymous Oct 18, 2008
    the machine keeps telling me paper jam, but it's not.
  • NYCGadget Nov 25, 2008
    every third page or so gets jammed.  the pages still print and come all the way through the printer but the paper is so messed up that the page become unuseable.  I litterally just installed this printer and have printed maybe ten pages and am getting very frusterated.  I tried to look inside the printer to see if there was something in the way but i didnt see anything.
I pulled jamed paper out of my hp81oc from front. now it want pull papet through? can it be fixed?
Posted on Feb 01, 2010
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Paper jam
you need to remove the jammed paper, you may need to take the printer apart as much as possible to get it all out, the manual generally has instructions on clearing a jam do you have the manual do you need it?
Oct 20, 2008 | HP Photosmart 3310 Printer
HP 3035 MFP keeps coming up with a "Jam in document feeder " error message. The offending material has been removed from the ADF and yet the error message will not go away. The device has...
The most common cause for this is a jammed paper sensor flag under the top cover of the ADF where the paper is fed. ( small black plastic protrusion )that should should be positioned at the front of its little slot. I think there are 2 sensors so check that they are functioning properly ( that they move from right to left & then spring back )
May 11, 2011 | HP LaserJet M3035 MFP Printer
My hp printer 4280 all-in-one keeps saying resume error and paper jam.
could be the same one I had with my printer. Try to turn off the printer, disconnect the power cord, disconnect it from the computer, hold down the power button for about 5 to 10 seconds. Then remove the panel at the back and make sure no traces or pieces of paper stuck in any of the rollers. After that about a minute, place the panel back, reconnect the power cord and the USB cable, turn it on, then open the ink cartridge panel/window, then after the cartridges were aligned, close the panel again, then try to print. feel free to rate how it how it goes for you.
Oct 23, 2010 | HP DeskJet F4280 All In One Printer InkJet
Instructions on printing a 4 x 6 card or photo on my HP 4280 All in One printer. How to I set up the printer?
At the printer:
1. Remove any paper from the input tray
2. Put a few sheets of 4x6 (10 or so) in the same tray
3. Adjust the paper holder bar so that the 4x6 paper stays straight in place. The holder bar was holding the 8x11 paper in place.
On the computer:
Open a picture
Seect [File] [Print]
Select the photo printer from the list
Cick on [Preferences]
See the paper type? select photo paper
See the paper size? Select 4x6
Quality (Best)
[OK]
[PRINT]
Sep 28, 2009 | HP Office Equipment & Supplies
Constant paper jam
It appears to be the printer it self is malfunctioning and may require service. Please call your printer manufacturer and ask for warranty.
Aug 14, 2009 | HP PhotoSmart C4280 Laser Printer
Paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavypaper) and place it in the feed way. Then press the printbutton applying a slight amount of pressure on the Card Stock so itwill feed through the printer. The reason for this, is in some cases Ihave been able to clear the paper track of debris that was deposited thereover time.
Worth a try, as I have fixed a number of printers thisway, saving costly repairs.
Hope this helps. Bud
Jan 09, 2009 | HP Photosmart C7280 Laser Printer
Paper is jammed in the printer HP Deskjet 4280
go to HP solution Center - Help - Open library - Clear paper jam
Jan 07, 2009 | HP DeskJet F4280 All In One Printer InkJet
190 people viewed this question
jasbo
jasbo
