Question about Samsung DVD Camcorder
I have'nt had this problem until just lately, if I change dvd's when I put it back in it tells me some error problem and they will not play in a computer how do I finalize?
  • 668 Answers
Follow the procedure given below:
Take out the battery and the AC cord.
Turn the camera on (tape, memory, edit settings) for 15 seconds.
Turn the camera to off setting.
Plug battery or AC cord back in.
It will work.
If you still face the problem then hold the camcorder firmly with one hand and hit the bottom of the camcorder hardly. This will kick the mechanism inside camcorder will accept the dvd.
Hope this helps.
Shane
Posted on Feb 26, 2011
SOURCE:
Please help, my ''Slimtype DVD A DS8A3S ATA Device '' won't work.
Click Start/My Computer then Right Click on the DvD Drive and select Properties. Click the Hardware Tab and double Click the Dvd drive or highlight it and click Properties. Click the DvD Region Tab and go down towards the bottom to change it by putting in a New Region.
May 01, 2012 | Computers & Internet
Sony handycam DCR-DVD608 Error E:61:00
I have sony handycam dcr dvd 608,when I open my handy cam,the message is showing, movie record disable
May 23, 2010 | Sony DCR-DVD608E DVD Camcorder
Can not play dvds lately. its telling me I need a compatable decoder. It was playing dvds until lately
Try the X-VID decoder you can download it here :
http://www.xvidmovies.com/codec/
Copy and paste link to the search bar at the top of your browser.
Jan 28, 2010 | Acer Aspire™ T180 PC Desktop
Dmr ez25eb
clean the lense and try otherwise you have to replace the lense..
Aug 03, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
H07 on panasonic
hey I just messed around with mine it was showing that code H07 like the others its kinds the same except it holds 4 more disc, I took the top off then I took the thing that holds cd still off!, there should be a brass thing I think thats for the ground, so I ended up putting some synthetic oil on the rails silver poles that the laser slides on, and where the disc sits on that black circle under it, you can see the motor it has a white thing on the motores pole so I just put a few drops on there then spinds it put some more on hoping it works its way DOWN INTO THE MOTOR thats the H07 not spining fast enough!! I put a disk in while everything was apart and its playing right now, the oil I desided to use was the stuff I use for my paintball gun lol! its really thin and slippory and im sure it will last for awhile!.... going to add more after 15 minutes of playing just to make sure its really lubed! hope this helps!!!!
Jan 10, 2008 | Panasonic DVD-CP67 Multi-disc DVD Player
Normal 0 This solution is most likely being submitted way too late tohelp "dingo 1295", but perhaps it will help others who run into thesame problem.
Just this past week, in January of 2009, I ran into the very same problem witha Panasonic DVD-CP67 DVD Player. The player would no longer play disks anddisplayed the H07 error. Now, I can't answer the question about what exactlythe H07 code is suppose to mean, but I can offer one possible solution for theDVD Player's inability to play disks and the subsequent display of the H07error. What happened in my case is that a film of dirt had built up between theelectrical contacts that are suppose to form a closed circuit when the player'sdisc drawer is closed. The two metal plates that make contact rub againsteach other and the abrasion eventually both creates and traps dirt where theplates touch. Therefore the player could no longer tell that the disk drawerwas closed because the dirt blocked the fragile electrical circuit from beingclosed. Since the player could not tell the drawer was closed it would not spinup and play any inserted disks. I'd also like to note that before the playerquite playing disks and started displaying the H07 error I was watching a DVDand did see the picture quality degrade until the video finally cut out and thedisk stopped.
The Solution in this instance was to carefully remove the cover from theplayer, after removing seven screws found on the back and sides of the player's case,and to clean the metal contacts with a non-abrasive eraser. The pink eraser ona NO. 2 pencil works perfectly.
On the back of the disk drawer, on the right side is a silver metal plate andat the back of the player, mounted on the plastic frame work around the platterthat picks up any disk placed in the player, is a folded copper plate held down with ascrew. Simply unscrew the copper plate and clean it with the eraser were itnormally touches the silver plate on the drawer when the drawer is closed,being sure you do not get any eraser dust inside the DVD player. Although thecopper plate will most likely be the plate with the most dirt on it you canalso clean the silver plate without removing it. Once cleaned, you can reattachthe copper plate with its screw.
Testing... You must place the cover back on the player before it will playdisks. The cover must be fully seated, but does not necessarily have to bescrewed on. You may have noticed when cleaning it that the copper plate has anupward folded tab that presses against the player's metal cover when the coveris closed. Without the copper plate touching the player's metal case throughits cover the previously mentioned electrical circuit won't be closed and theplayer won't play disks. With the cover properly back on the player go aheadand try and play a disk. If it works then the problem is solved and you canfinish screwing the cover back on. If the player still doesn't work thensomething more serious may be wrong and I would suggest contacting a servicecenter.
I hope this helps.
Oct 18, 2007 | Panasonic DVD-CP67 Multi-disc DVD Player
Cyberhome CH-DVD 300 DVD Player
Go out and buy you another brand DVD player.
Jun 12, 2007 | Cyberhome CH-DVD 300 DVD Player
DVR-111D dvd/cd writers
hmmm, this is unusual, it appears to be an incompatibility with the DVD software, as everything else seems to work may I suggest that you upgrade your DVD software for a later version.
May 23, 2007 | Pioneer 16X DVD Drive Burner (Model...
System Error
FYI...the best suggestion I've seen is to hold the channel up and play buttons simutaneously....thereby causing the machine to return to the "factory initialized" state. So far so good for me. We'll see. photog1
Apr 22, 2007 | Toshiba D-VR4 DVD Recorder/VCR
Samsung DVD Camcorder Logo
42 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
