Question about Pioneer PRO-700HD 64" Rear Projection Television
Continuing questions from Tony Fidaleo
Comment by TEFidaleo, posted on Jul 26, 2008 After our conversation I began to pull the power supply assembly. I then noticed another bank of fuses and found a 5A/125V (Pioneer part number FU206 per the circuit board) fast burning fuse was burned out. I went to Radio Shack and purchased a bag of the 5A fuses and had the fuse (FU101 10A/250V) tested that I could not see through yesterday and it checked out as good.
I replaced the burned fused and reconnected the power cord but the fuse quickly turned red and burned out (I did this twice and then unplugged everything).
Per the partial service manual I purchased yesterday (did not realize there were 2 parts to the manual) I noted this fuse is part of the Power Supply Assembly (Pioneer part number AWV1710).
Per the pioneer site the power assembly is in stock. At this juncture I prefer to just buy a new board and insert. However, before I order a $352 part I want to make sure that is the appropriate course of action, i.e. I don't know if that fuse could blow from a problem in another area/board. Also if I replace with a new board does that impact the TV's adjustments in any way?
Your recommendations are appreciated. I would be glad to email the Service Manual I have if that helps, it is in a PDF file.
  • BTDJS Mar 15, 2009
    I am having the same problem. Did you ever it it resovled & if so, how much out of pocket was it to get fixed?
  • 2,335 Answers
I've sent you an email to request the copy of your PDF file to see what part in the circuit is making the fuse blow.
Posted on Jul 28, 2008
When I put batteries in and turned it on, it started smoking and a wire heated up very quickly. Is there anyway this one candle can be replaced because it is a manufacturing flaw?
Search Results
    Smoking battery and wires HELP - Moderated Discussion Areas ...
    continuouswave.com/ubb/Forum6/HTML/001938.html
    Jun 13, 2008 - 10 posts - ‎5 authors
    The motor started to turn BUT the battery began to smoke , the wires ... Set the dial on the continuity function and put the leads on each of your battery cables. ... Thebatteries and cables are not reported to heat up when first connected. ... button verybriefly and get ready to pull the pos cable quickly in case ...
    Smoking Battery Cables - Moderated Discussion Areas - Continuous Wave
    continuouswave.com/ubb/Forum6/HTML/001003.html
    Jul 19, 2006 - 24 posts - ‎9 authors
    Are the terminals on battery cables supposed to be hot? ... amounts of resistance cause significant heating, which is why battery cables need .... Yesterday I went out and hooked up the new battery, turned the key and got absolutely nothing. ... Good thing I had the cowling off because a wire started smoking.
    Why did my Jumper Cables burn in half after attempting a jump
Jan 18, 2016 | Cars & Trucks
Lose of powe up hill no warning lights and idle is good
Fuel filter air cleaner filter plugged or need a tune up or air sensor in intake line put on computer will tell you right away if you want
Jan 12, 2016 | 2004 Nissan Altima
I see no answeres to know questions
Hi Tony:
If it is a stock radio, the fuse should be in the fuse panel. Check the user manual or google an enquiry with make, model, and year, with the key words -radio fuse location.
If it is an aftermarket radio it may have an in-line fuse on the electrical supply. Finding that may involve some searching and wire tracing.
Cheers.
If you want more info from me, reply as a comment to this post.
Nov 19, 2015 | Cars & Trucks
Why does my fan stay running for more then 90 minutes until the battery goes dead
Radiator fan runs continuously - volvoXC.com
www.volvoxc.com > Forum > The Vehicles > 2001-2007 XC70 (V70XC)
Jul 12, 2011 - 10 posts - ‎6 authors Hi, I have a problem with the radiator fan running continuously. ... According to Volvomechanic, when the pressure in the aircon gas goes ... 2002 xc70 cooling fan stays on
Jul 15, 2012
Blower Motor stays on.
Jan 15, 2011
fan after cutting off ignition?
Jul 25, 2004
More results from www.volvoxc.com
Oct 20, 2015 | Volvo S80 02 2002
86 Dodge W150 5.9L problems(2)
i have a '86 dodge ram w/318 - got it for free , only running on 4 out of 8. rebuilt carb (holley 2280 2 barrel ) still has no power but sounds like it's hitting on all 8. found on web a "power heat valve"between the passenger side exhaust manifold and the down pipe. it's in the haynes manual page 4a-22 illustration16.1 - i can't imagine what it should do when it's working (why choke off half your exhaust-ever) but i am going to check that out.have to get by a lot of rust first. good luck!
Jul 30, 2008 | 1986 Dodge W150
Tony Fidaleo's Pioneer PRO-700HD
Once I look at the schematic diagram, I might be able to know the part that is blowing that fuse.
Jul 28, 2008 | Pioneer PRO-700HD 64" Rear Projection...
Quark for mac
Just downsave the document and it would take care of the issue as well
Jul 13, 2008 | QuarkXPress 4.1 for mac
Sony Ericsson V580i
okay so you continued the wotan, did you get pass the update after installing the client?
Jul 08, 2008 | Cell Phones
Trouble playing the songs
Convert the songs to mp3 format, and you will never have this problem again.
Jun 03, 2008 | iLO (2 GB) MP3 Player
TV's on. No Picture...No Sound
Have a problem with Zenith 37 HDTV. Medel number: Z37LZ5D As wathcing TV, along with 'pop' sound, TV went dead. LG service center gave an advice to unplug the power cord and press ON/OFF power switch about 1 min. Then plug power back and turn on the TV. Well, the green light blink for a while and solid green, but still no screen, no audio. Search the Web and someone suggested to replace Power Supply Board which will fix the problem. Again, search the Web and came out with Power Supply Board. LG Electronics/Zenith 'Power Supply Assembl' with $124.95 from PartStore.com. Is it the right solution? Do I have to replace entire Assembly Board? not just replacing some fuse? Any cheaper way to do? If I have to replce PSA board, any suggestion to how? Comment posted on Apr 22, 2009 I have a basic knowledge of electric and electronics, such as rewiring entire house for renovation and assemble entire computer from scratch.
Actually, the TV belongs to my father and the problem that I stated was based on what he told me.
So the question is based on the symptom that I posted, how sure are you that the problem is the Power Supply Board?
Is it good to order PSB? Comment posted on Apr 23, 2009 Purchased 2 and half years ago. Expired one year warranty. Comment posted on Apr 23, 2009 Zohail,
This is LCD TV.
There is no problem with the wall socket nor current.
I put other appliances on same wall socket and worked.
It has to be internal problem.
As I mentioned on the main post, there was a 'pop' sound while watching and TV went dead.
Turn on remote control, there is blink green light and then green stays on, but no sound, no screen.
Turn off remote control, light turns red. Comment posted on May 14, 2009 I fixed the TV.
Orderd power supply board which cost me $136.51 total.
Replacing was simple.
Just removed the rear panel cover then electronic board housing cover.
Took power supply board with all the connector cables and replaced with new one.
Problem was a transformer connector which got burned and blow up the plastic cover.
But no problem with fuse and capacitors.
Thanks all for advises.
Jan 01, 2008 | Zenith Z37LZ5D 37 in. LCD TV
Pioneer PRO-700HD 64" Rear Projection Television Logo
115 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
