Question about Whirlpool Refrigerators
Broken copper pipe that suplpy water to the ice maker machine
  • 116 Answers
Assuming that this is the external connection from the house plumbing to the machine...
The pipe will have to be cut cleanly with a tubing cutter and the ferrule and nut will have to be replaced with new ones. There should be a brass nut attached to the water valve where the water line normally connects. Unscrew this nut and take it to Home Depot (or local plumber) , they will have all the necessary parts for you, including the tubing cutter.
Posted on Jul 28, 2008
What has caused my water inlet pipe feeding the ice making machine to freeze?
It seems there is some blockage in copper tubes ( capillary)
Need to flush internally and then refill refrigerant
Jul 20, 2016 | LG Refrigerators
LG LFX21976ST refrigerator. Started the day with a full reservoir of ice, was using it heavily to keep some workers hydrated. The last time I tried to get ice, none came. Per the label inside the doo
The ice maker's water supply line may be frozen solid. Do not worry... take out your frozen groceries and dairy products, and let your friends store them for two days while your completely defrost your refrigerator. If you don't want to wait, try to locate a schematic (parts diagram) for your fridge and take a panel access cover off to get access to the copper tube of the water supply line inside. (Warning: this can be terminal to your fridge so don't attempt this without the exact parts diagram for your make and model.) Ensure you are heating the water pipe and NOT the refrigerant line; i.e., freon, ammonia, etc... Unplug your fridge and heat up the (water supply) copper pipe with a high wattage blow dryer... if you were a pro, I would recommend a heat gun. DO NOT USE A HAND TORCH as the soldered joint connections may come loose and it will leak afterwards. (The demand you placed on the ice maker caused the compressor to run almost continually for the ice maker assembly causing the copper pipe water supply pipe to freeze... it will take time to thaw it out by just unplugging it. In the future, when you know you need volumes of ice... make a little at a time each day and store it inside a separate ice cube container.) You may also want to check the activation lever above the ice cube container (bin) to make sure it moves freely against the switch contact. If the switch contact is jammed, it won't work. Good Luck
Oct 02, 2012 | Refrigerators
How to reassemble ice dispenser parts od kenmore model 106.5706*602
Clean out the new ice maker with warm soapy water.
Ensure that the floor surface under your refrigerator is level. If the floor surface under your refrigerator isn't level, you can place shims under the legs of the refrigerator to fix the uneven surface.
Turn off the main water supply to your house.
Clear the water line by running the faucets until the pipe clears.
Screw the copper supply line's connector to the house's cold water connector valve. Use an adjustable wrench to tighten the connection.
Slide the compression sleeve and nut onto the other end of the copper supply line. The compression sleeve and nut will wrap around the outside of the copper supply line.
Bend the copper supply line to fit into the water line inlet casing located on the back of the refrigerator. Leave slack in the line so that the refrigerator can be pulled away from the wall or cabinets. The water line inlet casing is a plastic bracket used to hold the copper supply line in place so that there is no pull on the tubing's connection. It is the larger of the two plastic brackets located on the back of the refrigerator.
Insert the compression sleeve located around the end of the copper supply line into the ice maker connector. The ice maker connector is already installed on the back of the Maytag refrigerator.
Tighten the nut over the connection between the compression sleeve on the copper supply line and the ice maker connector with an adjustable wrench.
Attach the water supply tube clamp to the water supply line by clipping it into place. The water supply tube clamp is a plastic bracket located on the back of the refrigerator that holds the supply tube so that it doesn't rattle and become disconnected. It is the smaller of the two brackets located on the back of the refrigerator.
Turn on the main water supply.
Check all connections for leaks.
Position the drain hose located on the back of the ice maker over your floor drain. Use a PVC pipe if you need to redirect the drain hose flow so that it falls over the floor drain. The PVC pipe should not touch the drain hose and should have no low point where the water can settle.
Plug the ice maker into a 3-prong grounded outlet.
Feb 05, 2011 | Kenmore Refrigerators
3 yr. old Hoshizaki km630 mah, Had a hard freeze(24 degrees) at the shop and checked the ice maker that sits outside main bldg. Main water supply line inside that joins the copper pipe to the plastic...
There should be a reset button on your control board inside the electrical compartment.
Turn the system on to ice mode and depress the reset button. This should clear out any and all faults stored in the board and the machine should at least attempt to come back to life.
Look on the outside of the electrical compartment cover. There should be an explanation of what your error code means. I can't remember it off the top of my head. But the list there will tell you what 1 beep every 305 seconds means and the procedures to take from there.
Jan 13, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker is leaking water into the freezer
There should be a shut off on the copper line .cresent wrench
Nov 24, 2017 | Refrigerators
Too much water coming out of the pan (in the front of the ice maker) and copper pipes on top left side are covered with ice.
Not real sure just what you are saying as to what pan? The copper pipes that go to the evap plates where the ice is made are supposed to frost over. They get colder than dew point of the air so this is normal. But all the pipes should frost. Does the unit shut down and give any type of beeping noises? This would be the control giving you a trouble code. You may have a water valve leaking. Turn unit off and see if water continues to run. All water should stop within a few seconds. Let me know what you find. Please verify model and serial numbers.
Aug 13, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Ice Maker Stopped Working
On my three MC refrigerators over the last 30 years, this almost always meant the pipe that lets water into the icemaker is frozen. Sometimes it gets blocked (especially peas or corn). If it's frozen, use hot water and a turkey-baster type "sprayer". Do not use boiling water. If the freezer has been really active, you could have the plastic pipe in the back partly frozen, too. Be sure to shut off the water and be very very careful when moving the fridge. Some installers don't leave enough copper tubing to allow the fridge to be pulled all the way out. If the tubing gets crimped or broken, it's time to call a plumber.
The freeze-up pretty much always happened when the freezer was set too cold for the amount of food in it. When my kids were teenagers I had to unfreeze the line 2 or three times a year.
Apr 21, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
LG Fridge-Tube where water dispenses in ice tray is frozen solid
I think that the solenoid valve that supplies water to the ice maker is leaking ,it is located in the back of the refrigerator where you see a copper pipe or plasticpipe thatfeeds water to the refrigerator. Shut the water off and the power and take it out and replace it .
Apr 10, 2009 | LG Refrigerators
Ice maker water tube keeps freezing
u can replace the plAstic one with a copper one
Oct 27, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
62 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
