Question about Sanyo DVW-7200 DVD/VCR
Progressive scan how do I turn the progressive scan button off?
  • 1 more comment
  • mimirsf Aug 26, 2008
    can not turn progressive off
  • jdnsandy Sep 27, 2008
    I too can not turn off the progressive scan feature. I called the 800 number but it has been turned off??
  • jsroyce Dec 16, 2008
    My 2 year old button pusher turned on Progressive Scan and I cannot turn it off, now the screen is black. I know that there is a button on the remote but I cannot remember which combination turned it off.
To turn off Progressive Scan, press and hold the DVD Play button for 5 secs until the Progressive Scan indicator light goes off.
Posted on Nov 05, 2008
  • Nancy Moore Jan 12, 2012
    Thanks soooo much! I thought I had major problems-had sound but NO picture! Thanks again-up and working!!!! Nancy-state of Virginia
2 Suggested Answers
bbtoast
  • 319 Answers
SOURCE: Not able to turn off Progressive scan feature-sony dvp nc85h
Are you pressing the Progressive Scan button on the front of the Player? You need to look at the BACK of the Player. There is a manual switch just below the words "LINE OUT". This needs to be moved to the left where it says "Normal"
Try this please!
Brian
Posted on Jan 08, 2008
I pushed the pscaan button by mistake n now I can hear the movie but no picture
This is probably the 'progressive scan' feature for your DVD player.
If you haven't had any other problems with the player, try pushing the button again (a second time). This feature is likely a 'toggle-on, toggle-off, so a second 'push' should turn-off the progressive scan.
If this doesn't correct it, power the unit off, then power-on again. It it doesn't automatically power-up without the progressive scan, try pushing the pscan button again. Hopefully this will turn-off your undesired progressive scan. Good luck!
Feb 05, 2011 | Oritron DVD600 DVD Player
Pressing stop for more than 5 sec doesn't change 'progressive scan mode'
Please press and hold STOP button for more then 5 seconds to cancel Progressive Scan mode.
Oct 22, 2008 | Philips MDV560VR DVD Player/VCR
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
I accidently hit the progressive scan button and now I can't get a picture when I try to watch a dvd.
just talked to LG Customer support and got them to send me a manual.
to turn off the progressive scan insert a disk and once it starts playing press stop, then press stop again and hold for 5 seconds this will turn off the progressive scan mode.
Dec 09, 2008 | Zenith DVT412 System
Cannot remove progressive scan mode
I turned on the dvd player and pressed down on the play button and counted to 10, but before I got to 10 the progressive light went of and the image on my tv set came back on.
Mar 29, 2008 | Sanyo DVW-7100A DVD Player/VCR
If it works like my sony RDR-GX315 just press the pause button on the player itself and hold for 5 seconds.
Jan 08, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Showing red image
Make sure red is matched up to red, green to green, and blue to blue first. Then, try a different set of YPbPr (component) cables if you have a set available. If it still shows up red, then read this:
If you are using a Progressive Scan TV
(TV must indicate Progressive Scan or
ProScan capability), to activate TV
Progressive Scan, please refer to your TV
user manual. For DVD system Progressive
Scan function, see page 28.
Helpful Hint:
– If your TV does not support Progressive
Scan, you will not be ab le to view the picture.
Press and hold OPEN/CLOSE button and
press ‘1’ to deactivate progressive scan.
Progressive Scan - turning on/off
To select this item, you must set “Video
Output” to Y PR PB and ensure that your
TV has progressive scan (See page 11.)
Follow the steps of “Using the Setup
Menu” and select :
> PROGRESSIVE
OFF
ON
PROGRESSIVE SCAN OFF
TV SHAPE
TV SYSTEM
VIDEO OUT
PROGRESSIVE
SCR SAVER
SMART POWER
OFF
Select this to disable Progressive scan
function.
ON
These are pp. 11 and 28 of your owner's manual for the HTS
If these methods still fail, try turning your TV's progressive scan off or on.
-Tha Mp3 Doctor
Jan 08, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Nov 06, 2007 | Insignia NS-DVDR1 DVD Recorder
How do I turn off Progressive scan?
Hi, follow the steps it may help !! Press STOP button. ? If playing a disc, press the STOP button twice so that ?STOP?, appears on the display. Press and hold P.SCAN button on the remote control for over 5 seconds. ? Pressing and holding the button for over 5 seconds will select "Progressive Scan" and "Interlace Scan" alternately. ? When you select P.SCAN, "P.SCAN" will appear on the display. ? To set P.Scan mode for DivX discs, press the P.SCAN button on the remote control for more than 5 seconds with no disc in the unit (?'NO DISC" on the display), then load the DivX disc and play. regards sreejith
Jul 17, 2007 | Progressive DVHE210 210 DVD Player
PROGRESSIVE SCAN STILL ON- BLUE SCREEN ONLY
Cause: DVD+VCR was turned off while setting the Progressive scan mode. Correction: Keep pressing the STOP button for more than 5 seconds.
Oct 17, 2005 | Zenith XBV443 DVD Player/VCR
Televison & Video Logo
1,043 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
