Question about U-Line Refrigerator Ice Maker
Fill doesn't shut off on Model WCM48
The fill on our U-Line Ice Maker Model WCM48 does not shut off. It dribbles and causes the water to accumulate in the ice container and freeze at the bottom. How do I fix this?
  • jlore Jul 30, 2008
    Thank you for the input.
    Does anyone have a step-by-step procedure for removal of the fill valve on the Model WCM48?
    Since it is an old model, does U-Line, or another company, carry parts for this ice maker?
    Any information would be appreciated.
  • Anonymous Mar 30, 2014
    ice maker is filling water into the bucket and freezing all the ice solid
    Novelist:
  • 116 Answers
If it is just dribbling then chances are that there is debris in the fill vale preventing it from closing fully. Since it does not seem to flush out on its own then a new valve will likely solve your problem.
Posted on Jul 28, 2008
Every time ice maker runs, water accumulates at the bottom of the fridge. It is a bottom freezer model made 9-2013. What could be plugged?
Check the ice maker fill cup, it could be full of water or ice and all the water misses the ice maker. Check the fill line in the freezer to make sure its in the full cup to the ice maker. CHeck the drain under the evaporator in the freezer to see if it is open and obstructed. Thats what I would look for. Good Luck
Apr 20, 2016 | Refrigerators
Water flow tube on ice maker leaking by causing ice blockage
When the ice maker calls for water, the valve sends water to the ice maker in the appropriate amount and then shuts off, sending no more water until the ice maker calls for it again. If the water fill line is freezing up, this will cause a leak the next time the ice maker calls for water. The water has to go somewhere. The problem is more than likely the the water valve. It is not shutting off completely and it is allowing a small trickle of water to be constantly sent to the ice maker. This causes the fill line to freeze up and clog. Replace the water valve and defrost the water fill line and solve the problem.
Apr 06, 2014 | GE Refrigerators
Subzero freezer with ice maker. Ice melts and refreezes, into blocks of ice. What could be causing this?
Good day,
In most cases it is the water valve that feeds water to the ice maker well. The valve is energized by the ice maker to fill for 7 seconds and then shut off promptly.
The valve will many times dribble water into the well after shut off, causing an overflow problem.
The fix is a new water valve kit.
The only other possibility is the freezer temperature going above freezing from time to time, but is a rare problem.
Mar 27, 2010 | Sub-Zero Bottom Freezer Refrigerator
Our model 532 keeps over filling the ice maker causing a build up on the back and down all of the drawer. We can turn it off and thaw the entire box and the water keeps filling the tray even though the ice...
The fill valve for the ice maker could be stuck partially open and dripping into the ice maker. If this is the case shut off the water line to the ice maker and if the water stops you will need to replace the ice maker fill vavle
Aug 10, 2009 | Sub-Zero Freezers
Maytag msd2356ae ice maker will only give me hollow ice any ideas.
Hollow ice cubes are most often cause by insufficient water supply. Icemakers fill for about 7.5 seconds, resulting in about 4.75 oz. (140 cc) of water into the ice cube mold. If there s not enough water pressure available at the fridge, cubes may end up hollow and/or the fill could continue to dribble, eventually causing the fill tube to freeze closed.
pls rate my suggestion.........
Jul 25, 2009 | Maytag MSD2454G Side by Side Refrigerator
GE side by side; model # TFX25JRYD Serial #
So the dispenser is getting water. Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If the valves clicks but water doesn't get to ice maker the fill tube can be stopped up with ice.The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Jul 12, 2009 | GE GSS25JEM Side by Side Refrigerator
WE have replaced our ice maker in our Whirlpool refrigerator 4 times in the last 4 years. Our refrigerator obviously is a Whirlpool and the ice maker was ordered with the ice maker installed. WE are...
If the fill tube gets choked up with ice, (Figure S-4) it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut.
Apr 04, 2009 | Refrigerators
My ice maker overflows
If the fill tube gets choked up with ice, it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut. or it could be that the ice maker is not level.
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Water line in freezer for ice maker keeps freezing
I have had this happen to me before. What happens is the water fill valve
does not completely close and the tube will freeze shut as a small ammount of water will continuosly dribble into the tube when the valve shuts off causing the tube to freeze solid. I tried to clean the valve but that did not work so I replaced it and that ended the problem. A new valve is not expensive.
Oct 08, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
not familuar with the brand but sounds like one of 2 issues
if it is overfilling making ice cubes larger than normal, adjust the ice maker fill time if it is possible
icemaker fills and cuts off but water valve seeps water after the fill causing the water overfill
one of the 2
Jun 23, 2008 | U-Line Icemaker
U-Line Refrigerator Ice Maker Logo
88 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
