Question about Motorola Mobility V360 Cellular Phone
Bluetooth When trying to connect to bluetooth a "power cycle phone" error comes up. How do you fix this?
Down load from computer to phone
how do i do it
Posted on Aug 15, 2008
I wish to connect my phone to the computer and down load pic but do i save it to the chip or how
Why is it error-10 on my pioneer?
The manual is clear about this. There is a power failure to the bluetooth. If switching off and on (ignition switch) does not help, you should contact a dealer or a repair centre.
May 14, 2014 | Pioneer AVH-X2500BT
Noisehush n500 bluetooth
you can check the battery life of the bluetooth,if ok then you need to back up your files and have a reset your phone into factory default and paired it again....
May 14, 2014 | Cell Phones
2010 ford fiesta the radio displays bluetooth error when i connect my phone i
Try delete the present connection. then get your phone to rescan for bluetooth from the radio. re-pair with the radio. codes are usually simple like 0000 or 1234 etc
Feb 02, 2014 | Radio Communications
My nokia 7610 says unable to perform bluetooth operation
When you get an error "unable to perform Bluetooth operation", it means that one of the Bluetooth devices is not communicating correctly. It could be your phone, or it could be the Bluetooth device that you are trying to connect to. And that will depend on the device that you're connecting.
There's a possibility that the Bluetooth requirement of your device is not supported by your Nokia phone. Example, you are trying to pair up a Bluetooth handsfree car kit. "IF" the phone does not support the handsfree profile, then you will get this error message.
So, you need to make sure that your device and your phone is compatible with each other. Second, try to pair up the phone into different Bluetooth devices, like phones, headset, etc. Doing this will let you know if the Bluetooth on your phone is working or not. If it works with another Bluetooth devices, then the problem has something to do with the device that you are trying to connect to.
Thank you and good luck!
Jul 31, 2010 | Nokia 7610
Problems pairing up a Nokia 6301 with my Motorola H500
Try power cycling the phone. Turn the Nokia off, wait 10 seconds, then turn back on and try again. It really does help sometimes. Let us know if this doesn't help.
Apr 01, 2009 | Motorola Mobility H500 Wireless Headset
Motorola h700 pass key
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Jan 22, 2009 | Motorola Mobility H700 Wireless Headset
Bluetooth not powering up
Try this ::
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life. 2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is sually provided by the Bluetooth device manufacturer, not the RAZR. Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
PLEASE DONT FORGET TO RATE THIS RESOLUTION.
Nov 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Trying to bluetooth ring tones from motokrzr to lg rumor?
Bluetooth technology is still fairly new and it make take a few attempts to connect. Keep in mind some phones, like most Samsungs still use an older version of bluetooth software which only pairs with audio devices. So, best I can suggest is do a power cycle (remove the battery and let it sit for a few seconds and try again) to make sure there is no software loop errors that occur time to time and keep trying. If you still don't have much luck, go ahead and repost and I'll test it with some phones at the other shop and see what I can get.
Nov 16, 2008 | LG RUMOR Cellular Phone
Bluetooth "device out of range or powered off"
I had lots of trouble too. I thought it was my phone. Well here's what you do. First off remove the device completely from your phone. Turn off the phone and take the battery off so it can re-boot. When the phone is powered back up put your bluetooth in pairing mode and get it back on your phone. It should connect without any problems. Now....here is the trick. When you want to disconnect the device(bluetooth) from your phone don't turn it off on your phone. Shut the actual power off on your bluetooth. The phone will recognize this and disconnect the device. The only thing left on your phone will be the bluetooth icon. Being the icon still on your phone it is still in discovery mode and can overtime use up your battery life searching for a device. This is when you can go to your phone and turn off the bluetooth. On your NV 2 go to your bluetooth menu and just use your left softkeyto turn it off. Now there is no connection whatsoever. And to turn it back on do the opposite. Go to your bluetooth menu and turn on your bluetooth. You will see the bluetooth icon. Now you power up the bluetooth and it will connect as soon as it get the signal. This took me 2 weeks of trial and error and other stuff but I am happy now and I hope this solves any bluetooth problems...
Sep 16, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Ferrari 1000 laptop voip phone bluetooth code
try to connect from your lap, then you will get an option for code, type any code (suppose 123) and select ok/next. Then your mobile will ask the code put the same code (as 123) which you have typed in in your lap. Then it will be connected.
Please post your feed back, if any question just Ask me.
Thanks
Iqbal
May 18, 2008 | Acer Ferrari 1000-5123 Laptop
Motorola Mobility V360 Cellular Phone Logo
51 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
