Question about Oritron DVD4119
Region code i need to change the region code from 1 to 2. pls. help
Unfortunately, no "magic" menu appears...i tried different "types" of slowly, but didn't work...
probably the best solution is to aquire a new one...lol
Posted on Aug 08, 2008
  • 376 Answers
When "no disc" screen is showing,
press 16719 (slowly) to get secret menu.
then change to region 0 to include all regions or 2 for region 2.
Posted on Aug 07, 2008
Region Free Code
8888 it's the code to change regions on the portable dvd\cd\mp3 player Airis LW258!
I'm just a friend!
Nov 23, 2008 | Car Audio & Video
I have an LG FB126 DVD system that only plays region 4. What are the unlock codes to play region 1 and how do I do it??
I was made to understand that there are several versions of this model. Pls try:
  • Turn on your DVD player - with no disc inside;
  • Press pause followed by 3 1 4 1 5 9;
  • screen will display current region
  • Press 0
  • enter
or
  • Press On
  • "No disc" will appear
  • Eject Tray
  • Press '0' more than five times.
  • Press Pause
  • Press Off
or
  • Press "pause"
  • Press "1 4 7 2"
  • edit the 5th number group in the code
  • the first number is the region code
  • example; if the number is "12" then the region is set to 1
  • another example, if the number is "42" then the region is set to 4
  • so if you want all regions set it to "02"
  • when finished press "pause" again to exit from the menu
  • power off the unit and turn back on again.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 17, 2008 | Televison & Video
Apex ad-1201 multiregion reprogramming question
Open tray
press 8 4 2 1 (you will see -'s appear top left of screen)
Menu appears for region and Macrovision
Use up/down keys to select Region/Macrovision
Use Enter to change region/Macrovision on/off
A PAL region 2 disk played fine when switched to region 9 (Really region 0 , ie region-free)
Have not yet tested Macrovision
Aug 31, 2008 | Apex Digital AD-1200 DVD Player
Changing the region code to multizone
Initially, pls reference this site. Among the the tested method is as extracted below:
  • Press the Menu button on your remote control
  • Press the 5 button on your remote control
  • Press the 7 button on your remote control
  • Press the 3 button on your remote control
  • Press the 8 button on your remote control
  • The currently selected region will be indicated on the onscreen display
  • Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 14, 2008 | Samsung DVD-R155
Help!
you will have to go into the setup screen and find the region setting and change it to region 1. Note that you can only change the region about 5 times, and once you have changed it that many times you can't change it again. I usually recommend that people buy 2 DVD players if they need 2 regions, etc.
Sep 06, 2008 | LG DK 9411P DVD Player
Crack code
here u go rate me Fix ya
1/press setup
2/go to the prefernces page.
3/type 9 6 5 3
4/select region
solved 100% by Fix_You
Aug 18, 2008 | Philips DCP855/37 Portable DVD Player
Unlocking procedure for the samsung dvd-p181
Pls try:
1. Make sure that there is no disc in the tray and switch on the player.
2. Cold start the player, by holding down the PLAY and STOP buttons on the player.
3. You should see a set of language options. Release the PLAY and STOP buttons.
4. Select your language.
5. Press REPEAT (do not confuse this with the A-B button) then the following codes for the required region the player is already set to (region you bought the player in) :
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
("E series M105", M205 and M305 users try: 57538)
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
6. A code will appear, indicating the region setting of your player.
7. Press 0 for region-free, or 1 for region 1, 2 for region 2, etc.
8. Press OPEN/CLOSE on the Player to open the disc tray. You may need to push the tray shut rather than use the player button, in order for the region not to be changed to 4 (M203).
9. Press STANDBY (POWER) on the remote control to close the tray. Next time the player is turned on it will set to the region specified. If the player halts on the FBI Warnings, press Forward Search x2 or faster.
This was originally posted here.
Aug 13, 2008 | Televison & Video
Need to play region 1 DVD in region 2
hi
try a search on your dvd here check for region codes dvd
riz.
May 31, 2008 | LG RH177 DVD Recorder/HDD Recorder
Can't access the preferences tab
Pls try a full master reset which if done correctly would revert the unit back to factory default:
1. Power on the unit;
2. open the front panel lid to have access to the controls;
3. simultaneously press and hold the channel up and down buttons;
4. wait till "BYE" is displayed;
5. wait till clock switches off;
6. power on again and re-configure.
You may need to restore "Region Free"
1. Power on the DVP 3005.
2. Bring up the System Menu.
3. Navigate to the Preferences page.
4. Press the following combination of keys on your remote in this order to bring up the secret menu showing the Region Code.
1 3 5 5 6 6.
5. Use the arrow keys on the remote control to change the Region. To make it region free, set the Region code to “0′ (zero).
6. Exit the System Menu.
May 23, 2008 | Philips DVP-3005 DVD Player
Philips dvp 3020 dvd player
1 3 5 5 6 6.
May 22, 2008 | Philips DVP-3005 DVD Player
Televison & Video Logo
141 people viewed this question
Top Oritron Televison & Video Experts
jairo sanchez
 Grubhead
Grubhead
Are you an Oritron Televison and Video Expert? Answer questions, earn points and help others
