Question about LG DLE2514 Electric Dryer
Drum Won't Spin
Dryer powers up, buzzes from within, drum doesn't spin.
    Problem Solver:
  • 5 Answers
Sounds like either the drum belt is either loose or is broken, otherwise the motor may need replacing.
Posted on Aug 13, 2008
Dryer drum doesn't spin
If the motor runs and the drum doesn't turn then most likely the belt is broken.
Oct 23, 2012 | GE DBVH512EFWW Dryer
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Dec 06, 2011 | Frigidaire Dryers
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
When i tried to turn on the dryer, i get a humming / buzzing sound and the drum / motor doesn't spin anymore
Those symptons (humming/buzzing ¬ starting) are 99 out of a 100 times a sign of a motor that has locked up.
Gene
Aug 07, 2011 | GE Dryers
When you push the button to start the dryer, all it does is buzz and nothing happens
next time send the model number and brand name,all dryers are not the same!it sounds like a bad motor.open the door,push the door switch in with one hand and with the other spin the drum,while you're spinning the drum have someone push the start button,if the motor starts you'll know the motor is bad but it might run for a while before it does this again or it will do it every time but either way the motor should be changed,also on some dryers if the belt broke it will buzz like when the dryer is down but if yours is more like a humming sound like power is going to the motor but it won't run then it's the motor.
Apr 24, 2011 | Dryers
Dryer drum tries to start but won't
the start switch is probably bad on the motor but most dryers you have to buy the whole motor
Apr 24, 2009 | Dryers
Gas dryer drum does not spin
defective motor,,replace,,,onthejob
Jan 11, 2009 | Dryers
Fisher and Paykel Dryer will not spin, motor buzzing
take top off. set it going and give the drum a push by hand. if it starts and keeps going then the fault is the motor capacitor - cheap part
Nov 14, 2008 | Fisher DEIX2 Dryer
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
LG DLE2514 Electric Dryer Logo
116 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
