Question about AOpen AK77-8X Max (91.8A710.101) Motherboard
Disk boot error mes
Replaced video card & hard drive work for few days then get same mes Can get into BIOS screen on startup but it won't boot up
ronkut
  • 2 more comments
  • ronkut Jul 28, 2008
    What do they mean by reinstalling system? How do I do that?
    I can't seem to get an ans. How do you reinstall operating system?
    George, thanks for info. I don't know if I can get old video card back it was at a shop. The disk I had won't be accepted by system. Somehow the repair man thinks I have a power or heat problem. Also he said I can't replace my motherboard.
    Ron
    I did all that everything was connected.
    Ron
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
Do a check disk.
Log in Safemode. Start>Run.. type cmd and hit enter.
type chkdsk /f and hit enter.
Your hdd might be failing, let checkdisk fix the bad sectors if it can. Or else u can try this...
Correct this pc problem first of all sounds like you need to formatyour hard drive is a definite cure but before you do this try systemrestore by hitting start then all programs accessories then systemtools then hit system restore and then pick a date that prob startedmight help. Or backup your system another thing but me personally ifyou know how to format your hard drive then that's the way but if youdon't take it to a repair shop and tell them that you need to formatyour hard drive. It is real easy but drivers if not installed correctlycan cause you serious problems.
Click this link for more information....
http://fix-errors.remove-junk.com/
http://www.pcaholic.com/
Thanks
Good luck
Don't forget to rate the solution
Posted on Jul 28, 2008
  • 2,071 Answers
Just click below;
    Genius:
  • 1,268 Answers
Disk boot error is just a physical connection problem from hard drive to the motherboard most of the time. Worst is a defective hard drive. Make sure the cables are connected and pushed properly. Try to unplug and re-plug the hard drive cable and be sure to plug the power to the hard drive.
    Novelist:
  • 183 Answers
Use the following steps, in sequence, until a solution is found.
Step 1: Begin troubleshooting by removing media and connected devices
v Turn on the computer and remove any CDs and DVDs from their drives using the CD/DVD eject button on the outside of the CD/DVD drive.
v If you are unable to turn on the computer and/or eject the discs, continue using these steps. Remember to remove the discs when the computer has power and you are able to open the drive door.
v Turn off the computer and unplug the power cable from the power outlet.
v With the computer turned off remove all other media and devices that are connected to the computer except for the mouse, monitor, and keyboard. Remove any floppies, printers, USB and FireWire devices, music players, cameras, and flash memory cards.
v With the media and devices removed, turn on the computer.
v If the computer has the same startup problem, leave the devices disconnected, turn off the computer and continue to Step 2. If the computer does not have the same problem, continue using these steps.
v If the computer is able to open Windows after the media and devices were removed, one of these items was preventing Windows from opening. Find which device or media item is causing the problem by reattaching or reinserting each to the computer one at a time. Restart the computer each time a device or media item is added until the startup problem reoccurs.
v Once the media or device that is causing the problem has been identified, do not continue to use it. You can troubleshoot the device or media further. Here are some helpful troubleshooting tips:
v Now that you know which device is contributing to the startup problem, you can search the Internet or visit the manufacturer Support Web site to find more help and information.
v CD, DVD, floppy, or camera cards that are damaged, dirty or scratched may interfere with the startup process. Do not start the computer with media in the drives.
v The computer may try to start an operating system from an external storage device, such as a USB or FireWire drive. You can immediately work around this problem by attaching external storage devices only after Windows has opened.
v Camera cards that are left in printers can cause startup problems. Do not leave camera cards in printers.
v Some printers that have media card readers might contribute to startup problems when used with computers that have older BIOS versions. Updating the BIOS on the computer may resolve the problem. For further information about how to find and download BIOS updates for your HP or Compaq computer, please refer to updating the BIOS.If the problem still exists, continue to the next step.
  • 2 more comments
  • Inderpal Singh
    Inderpal Singh Jul 28, 2008
    Step 2: Continue to identify the type of startup problem
    v Use the following process to identify the type of startup problem that is occurring and to find the information you need to troubleshoot the problem:
    v Turn off the computer and unplug the power cord from the power outlet.
    v Reset the power: with the power cord unplugged, press and hold the power button on the front of the computer for 5 seconds.
    v Plug the power cord into the power outlet.
    v Press the power button to turn on the computer and note what happens.
    v If the computer successfully opens to Windows, the problem may be related to a temporary firmware lockup and may never happen again. Continue using the computer normally. If the problem occurs again, test the computer hardware, such as the hard drives, memory, and processor,Using PC Doctor to help determine if a hardware component has failed.
    v If the computer makes no fan noise, has no lights on the front of the PC, and does not display anything on the monitor , the computer is not distributing power correctly. Turn the computer off, unplug the power cord and refer to the HP support document Troubleshooting Power Supply Issues to troubleshoot power supply problems.
    v If the computer powers on but makes beeping sounds, a keyboard key is stuck, a memory DIMM or hard drive cable is not properly seated, or a hardware failure has occurred. Disconnect the mouse and keyboard and try to start the computer again. If the beeping noise stops, repair or replace the mouse or keyboard that is causing the problem. If a beep code continues, use the HP support document BIOS Beep Codes and Error Message Descriptions to troubleshoot further.
    v If the computer starts but the monitor has a blank screen , the video hardware on the computer may be causing the problem or the monitor may be defective. Use the HP support document The Monitor is Blank after Starting the Computer .
    v If the computer starts to a black screen with only a mouse pointer arrow , a file named lsasse.exe may be damaged. This problem can be resolved by using the HP support document Computer Starts to Black Screen With Only a White Arrow.
    v If an error message displays on the screen , search HP Customer Care using the exact text in the error message and then troubleshoot the problem using any support documents that are found.
    v If you are not able to identify or resolve the problem, continue to the next step to apply further troubleshooting.
  • Inderpal Singh
    Step 3: Checking if the hard drive is detected
    v First, determine if the hard drive is being detected in the BIOS. Doing so, will help determine if the problem is related to hardware or software:
    v Before you begin, disconnect everything from the computer (such as USB devices, printers, floppy disks, and CD/DVD discs) and leave the mouse, monitor and keyboard connected.
    v Turn on the computer and press the F1 key repeatedly to enter the BIOS Setup Utility.
    v Find the hard drive name from the listing of channels or drives. Look for a name next to Primary Master or from the channel device listing (1st, 2nd, 3rd, and so on). To help you find the drive name, some common examples of hard drive names are:
    v [MAXTOR 6Y160M0]
    v [SAMSUNG SV8004H]
    v [ST3120026AS]
    v [WDC WD800AB-22CB]
    v Note: - It may be difficult to determine between a hard drive and a CD/DVD drive. In many cases, depending on the version of BIOS, you can select the name of the device next to a channel and press ENTER. Doing so may provide more helpful information that can help you determine if it is a hard drive.
  • Inderpal Singh
    Figure 1:Example of a hard drive listed in the BIOS
  • Inderpal Singh
    v Go the appropriate section of this document, depending on what was found:
    v If a hard drive name is listed, refer to the steps in the section Step 4: Hard drive detected .
    If you cannot find a hard drive name, that is, the text [Auto] , [NOT DETECTED] or [None] is listed next to Primary Master or First/Second/Third Channel Device 0, leave the BIOS Setup screen open and refer to the steps in the section Step 5: Hard Drive is not detected
  • 6,487 Answers
If you want to reinstall the operating system you just need to access the BIOS and set the first boot device as the CDrmo drive then before you reboot the computer put the installation CD for your Windows operating system then that way you can reinstall tha operating system......
Hope that helps.............
  • Mark Gil
    Mark Gil Jul 28, 2008
    If you have a overheating problem you just add some fan on your CPU tower to avoid any overheating problem...
  • 304 Answers
Will your computer boot from a rescue disk or the installation disk for the operating system? As the system was functioning for a few days and then stopped your operating system has somehow been corrupted and mist be reinstalled. You may have tried to install a new program or driver that most likely corrupted your operating system. Think back to what you may have installed that caused this problem. It may have been just a random process failure during the installation. Make sure when you are installing new programs or drivers that no programs are running in the back ground as this will cause problems like you are explaining.
If you can boot from the optical drive, re install your operating system. Make sure you do a fresh install and reformat the hard drive fully. Do not select the quick format option, this may leave troublesome artifacts behind.
If you can not access your optical drive at all, Remove your new video card and replace it with the old one. This should help you regain access to your optical drive. If you need more assistance feel free to ask me here or my email address is geokohler@gmail.com I will call you for free and walk you through any of the other possible solutions to remedy your problems. I hope you find this helpful.
George
  • George Kohler
    George Kohler Jul 28, 2008
    If you need a walk through of the entire solution to your problem I will call you for free and tell you exactly what you need to do to reinstall your operating system. Send me your phone number to my E-mail address.
  • George Kohler
    It sounds like the guy is trying to rip you off and sell you another motherboard. I cant type anymore right now but if you need more help send me your number and I will help you for free later. I do not know why people keep sending you long lists of things to do like you are a computer engineer. What you need is an engine to talk you through what your options are and how to get it working live.
    Anyway, Send me an E-mail with your number before someone tells you how to build a new mother board from spare refrigerator parts. LOL
    George
  • 83 Answers
A disk boot error means that there is an operating system load error 90% of the time I have seen.
Fix:
Make sure cables are connected from hard drive to motherboard.
Reinstall Operating System. This will reconfigure the boot.ini file that tells the computer what to load.
If this does not work let me know please.
Thanks, hope this helps ya!
    President:
  • 1,314 Answers
What is the message you are getting?
  • Kevin Shafer
    Kevin Shafer Jul 28, 2008
    Sorry, it's in the title. lol.
    When you are in BIOS, does your drive show up there?
  • Kevin Shafer
    He said it was already a new hard drive which means a new operating system.
    If the cable is connected tightly on your hard drive and to your motherboard, then swap out the cable from your hard drive to your motherboard.
Have black screen. Error PXE E53 help
Check the physical connection for your hard drive. Sometimes they get loose. With the computer off and the battery removed, remove he hard drive and then replace it. Try to boot again.
If this fails to help, you may have a hard drive failure and need to replace it.
Feb 17, 2015 | Dell Computers & Internet
Tip
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
Non system disk or disk error
Hi is the bios detecting the hard drive? Are you able to open the laptop and chek if the hard drive is correctly plugged into mother board
Feb 06, 2013 | HEWLETT-PACKARD 625 Notebook PC
Tell me aboout boot sequence in bios setup
The system BIOS is what starts the computer running when you turn it on. The following are the steps that a typical boot sequence involves. Of course this will vary by the manufacturer of your hardware, BIOS, etc., and especially by what peripherals you have in the PC. Here is what generally happens when you turn on your system power:
The internal power supply turns on and initializes. The power supply takes some time until it can generate reliable power for the rest of the computer, and having it turn on prematurely could potentially lead to damage. Therefore, the chipset will generate a reset signal to the processor (the same as if you held the reset button down for a while on your case) until it receives the Power Good signal from the power supply.
When the reset button is released, the processor will be ready to start executing. When the processor first starts up, it is suffering from amnesia; there is nothing at all in the memory to execute. Of course processor makers know this will happen, so they pre-program the processor to always look at the same place in the system BIOS ROM for the start of the BIOS boot program. This is normally location FFFF0h, right at the end of the system memory. They put it there so that the size of the ROM can be changed without creating compatibility problems. Since there are only 16 bytes left from there to the end of conventional memory, this location just contains a "jump" instruction telling the processor where to go to find the real BIOS startup program.
The BIOS performs the power-on self test (POST). If there are any fatal errors, the boot process stops. POST beep codes can be found in this area of the Troubleshooting Expert.
The BIOS looks for the video card. In particular, it looks for the video card's built in BIOS program and runs it. This BIOS is normally found at location C000h in memory. The system BIOS executes the video card BIOS, which initializes the video card. Most modern cards will display information on the screen about the video card. (This is why on a modern PC you usually see something on the screen about the video card before you see the messages from the system BIOS itself).
The BIOS then looks for other devices' ROMs to see if any of them have BIOSes. Normally, the IDE/ATA hard disk BIOS will be found at C8000h and executed. If any other device BIOSes are found, they are executed as well.
The BIOS displays its startup screen.
The BIOS does more tests on the system, including the memory count-up test which you see on the screen. The BIOS will generally display a text error message on the screen if it encounters an error at this point; these error messages and their explanations can be found in this part of the Troubleshooting Expert.
The BIOS performs a "system inventory" of sorts, doing more tests to determine what sort of hardware is in the system. Modern BIOSes have many automatic settings and will determine memory timing (for example) based on what kind of memory it finds. Many BIOSes can also dynamically set hard drive parameters and access modes, and will determine these at roughly this time. Some will display a message on the screen for each drive they detect and configure this way. The BIOS will also now search for and label logical devices (COM and LPT ports).
If the BIOS supports the Plug and Play standard, it will detect and configure Plug and Play devices at this time and display a message on the screen for each one it finds. See here for more details on how PnP detects devices and assigns resources.
The BIOS will display a summary screen about your system's configuration. Checking this page of data can be helpful in diagnosing setup problems, although it can be hard to see because sometimes it flashes on the screen very quickly before scrolling off the top.
The BIOS begins the search for a drive to boot from. Most modern BIOSes contain a setting that controls if the system should first try to boot from the floppy disk (A:) or first try the hard disk (C:). Some BIOSes will even let you boot from your CD-ROM drive or other devices, depending on the boot sequence BIOS setting.
Having identified its target boot drive, the BIOS looks for boot information to start the operating system boot process. If it is searching a hard disk, it looks for a master boot record at cylinder 0, head 0, sector 1 (the first sector on the disk); if it is searching a floppy disk, it looks at the same address on the floppy disk for a volume boot sector.
If it finds what it is looking for, the BIOS starts the process of booting the operating system, using the information in the boot sector. At this point, the code in the boot sector takes over from the BIOS. The DOS boot process is described in detail here. If the first device that the system tries (floppy, hard disk, etc.) is not found, the BIOS will then try the next device in the boot sequence, and continue until it finds a bootable device.
If no boot device at all can be found, the system will normally display an error message and then freeze up the system. What the error message is depends entirely on the BIOS, and can be anything from the rather clear "No boot device available" to the very cryptic "NO ROM BASIC - SYSTEM HALTED". This will also happen if you have a bootable hard disk partition but forget to set it active.
Dec 15, 2010 | HP Computers & Internet
What happens inside the PC between turning the power on and you see the desktop on the screen?
  1. The internal power supply turns on and initializes. The power supply takes some time until it can generate reliable power for the rest of the computer, and having it turn on prematurely could potentially lead to damage. Therefore, the chipset will generate a reset signal to the processor (the same as if you held the reset button down for a while on your case) until it receives the Power Good signal from the power supply.
  2. When the reset button is released, the processor will be ready to start executing. When the processor first starts up, it is suffering from amnesia; there is nothing at all in the memory to execute. Of course processor makers know this will happen, so they pre-program the processor to always look at the same place in the system BIOS ROM for the start of the BIOS boot program. This is normally location FFFF0h, right at the end of the system memory. They put it there so that the size of the ROM can be changed without creating compatibility problems. Since there are only 16 bytes left from there to the end of conventional memory, this location just contains a "jump" instruction telling the processor where to go to find the real BIOS startup program.
  3. The BIOS performs the power-on self test (POST). If there are any fatal errors, the boot process stops. POST beep codes can be found in this area of the Troubleshooting Expert.
  4. The BIOS looks for the video card. In particular, it looks for the video card's built in BIOS program and runs it. This BIOS is normally found at location C000h in memory. The system BIOS executes the video card BIOS, which initializes the video card. Most modern cards will display information on the screen about the video card. (This is why on a modern PC you usually see something on the screen about the video card before you see the messages from the system BIOS itself).
  5. The BIOS then looks for other devices' ROMs to see if any of them have BIOSes. Normally, the IDE/ATA hard disk BIOS will be found at C8000h and executed. If any other device BIOSes are found, they are executed as well.
  6. The BIOS displays its startup screen.
  7. The BIOS does more tests on the system, including the memory count-up test which you see on the screen. The BIOS will generally display a text error message on the screen if it encounters an error at this point; these error messages and their explanations can be found in this part of the Troubleshooting Expert.
  8. The BIOS performs a "system inventory" of sorts, doing more tests to determine what sort of hardware is in the system. Modern BIOSes have many automatic settings and will determine memory timing (for example) based on what kind of memory it finds. Many BIOSes can also dynamically set hard drive parameters and access modes, and will determine these at roughly this time. Some will display a message on the screen for each drive they detect and configure this way. The BIOS will also now search for and label logical devices (COM and LPT ports).
  9. If the BIOS supports the Plug and Play standard, it will detect and configure Plug and Play devices at this time and display a message on the screen for each one it finds. See here for more details on how PnP detects devices and assigns resources.
  10. The BIOS will display a summary screen about your system's configuration. Checking this page of data can be helpful in diagnosing setup problems, although it can be hard to see because sometimes it flashes on the screen very quickly before scrolling off the top.
  11. The BIOS begins the search for a drive to boot from. Most modern BIOSes contain a setting that controls if the system should first try to boot from the floppy disk (A:) or first try the hard disk (C:). Some BIOSes will even let you boot from your CD-ROM drive or other devices, depending on the boot sequence BIOS setting.
  12. Having identified its target boot drive, the BIOS looks for boot information to start the operating system boot process. If it is searching a hard disk, it looks for a master boot record at cylinder 0, head 0, sector 1 (the first sector on the disk); if it is searching a floppy disk, it looks at the same address on the floppy disk for a volume boot sector.
  13. If it finds what it is looking for, the BIOS starts the process of booting the operating system, using the information in the boot sector. At this point, the code in the boot sector takes over from the BIOS. The DOS boot process is described in detail here. If the first device that the system tries (floppy, hard disk, etc.) is not found, the BIOS will then try the next device in the boot sequence, and continue until it finds a bootable device.
  14. If no boot device at all can be found, the system will normally display an error message and then freeze up the system. What the error message is depends entirely on the BIOS, and can be anything from the rather clear "No boot device available" to the very cryptic "NO ROM BASIC - SYSTEM HALTED". This will also happen if you have a bootable hard disk partition but forget to set it active.
Nov 02, 2010 | Computers & Internet
My laptop wont start up, It says "system disc or non system disc error, replace and press any key.." why? :(
you have it set to boot from cd so when you startup the computer it attempts to read the cd and than boot an operating system for you either remove the disk or enter your bios menu and set your boot order to negate the cd drive
Oct 25, 2010 | Computers & Internet
17 inch monitor goes blank
  • Prepare to diagnose the computer .
    1. Disconnect all peripheral devices.
    2. Perform a Hard Reset.
    3. Disable the Automatic restart on system failure option.
  • Remove any non-system disc from the computer . During startup, the BIOS checks different devices to locate the Windows operating system. If the boot order is set to check the optical disc drive or the card reader (if the notebook is equipped with a card reader) before it checks the hard drive, and there is a non-system disc in the CD/DVD drive or there is a memory card in the card reader, the boot will fail. This problem can be resolved by setting the BIOS to check the hard drive first.
  • Reseat the memory modules . If you are getting memory errors, most BIOS versions have additional tests that can be run to test the memory. There could be a problem if one of the sticks is defective or loose in the memory slots. To determine what is causing the memory failure, disconnect all electrical power, and then remove and re-insert the memory modules firmly into the slots. Some HP Notebook PCs come with two sticks of memory and have two memory slots. On most notebooks, the memory module compartment is located on the bottom of the case, but the exact position varies by model. On some models, the memory compartment is under the keyboard. See your User Guide for the exact location of memory modules on your notebook.
  • Reset the BIOS to default condition . If you have made changes in the BIOS setting, such as disabling a device or changing the boot order, it could prevent the computer form starting properly. To restore the BIOS to its factory-recommended settings, turn on the computer and press f10 to access BIOS setup, and then press f9 to load the default BIOS configuration.
  • Perform a memory self test . There are different reasons that you may see a memory error. There could be a physical problem or it could be a program error. If the error is a program error, you will most likely see a Windows error message. If there is a physical problem with a memory module, the computer may fail part way through the boot process. Most computers have a built-in memory test to help identify if the memory modules are seated properly and are free of errors. To run the memory test, turn on the computer and press f2 .
    • If the System Diagnostics screen displays, select the Start-up Test to run the system memory test. Press the Esc key once the memory test is complete.
    • If the BIOS Diagnostics screen displays, select Memory Test .
  • Reseat the hard drive . If you get a specific hard drive error message on a black screen indicating the hard drive error, reseat the hard drive. If the computer has been dropped or jarred, or the hard drive has been replaced recently, the drive may not be seated tightly. The hard drive LED should blink if the hard drive has a solid connection in the notebook. Refer to the on-line User's Guide for specifics on locating and removing / replacing a hard drive. HP provides video directions for performing this task for many computer models. Remove and reseat the hard drive firmly into the mounting bracket.
  • Test the hard drive . If you get a hard drive error message, you can test the hard drive. Many computer problems are related to soft failures (or degraded performance) on the hard drive. The HP Hard Drive Self Test will repair soft errors on the hard drive, but it will not report the errors. After the test is complete, restart the computer to see if test repaired the problem you may been experiencing. To run the hard drive test, turn on the computer and press f2 .
    • If the System Diagnostics screen displays, select the Hard Disk Test to run the hard drive test. Allow the Quick and Long Hard Disk Self Tests to run.
    • If the BIOS Diagnostics screen displays, select Primary Hard Disk Self Test . Allow the Quick and Long Hard Disk Self Tests to run.
  • Feb 04, 2010 | X2Gen MG19MY 19" LCD Monitor
    Boot Manager
    You will want to do a Windows Recovery Environment Startup Repair, follow the instructions below to fix this issue:
    To access the WinRE using the Vista install disk:
    1. Boot from the Vista install disk
    2. Choose your language settings and click "Next"
    3. On the bottom of the screen click the link "Repair Your Computer"
    4. Select the Vista installation to repair and click "Next" and it will launch WinRE
    The following options are available in WinRE:
    • Startup Repair - It will repair the boot manager files and restore critical files required for booting Windows Vista.
      After attempting to repair the system it will display a Startup Repair diagnosis and repair log with the different Test Performed and the probably root cause.
    Dec 16, 2008 | HP Pavilion dv9000z Notebook
    Thinkpad 390x 2626, won't boot from cd drive
    Try pressing F12 at startup, you should get a boot option.
    Nov 19, 2008 | Computers & Internet
    I have a HP 8595c computer. I put a DVD in and it froze. I restarted the computer and now it won't boot up proberly. I get this message. "Non-System disk or disk error Replace and strike any key...
    Non-System Disk or Disk Error results when the Basic Input/Output System (BIOS) cannot find the boot sector or the master boot record is missing or damaged; i.e. the device does not have bootable media. The BIOS searches drives in the order usually specified in the CMOS Setup. This order is often, but not always, A: (floppy drive), C: (first partition on the hard disk)… The error will occur during startup if the CMOS is set so the BIOS seeks the floppy drive first and a non-bootable (or blank) floppy is in (was left in) the floppy drive. Other causes include:
    No bootable partition on a hard disk drive
  • A defective hard disk drive
  • The CMOS drive settings (parameters) are not correct for the boot device
  • Defective floppy
  • Defective floppy drive
  • A virus
  • Jul 21, 2008 | Computers & Internet
    AOpen AK77-8X Max (91.8A710.101) Motherboard Logo
    134 people viewed this question
    Top AOpen Computers & Internet Experts
    Brian Sullivan
    Brian Sullivan
    Matthew Spark
    Matthew Spark
    David
    David
    Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
