Question about Microwave Ovens
Model number is NNV629MBBPQ.
Hello,  I have a Panasonic Microwave - Model number is NNV629MBBPQ.  We had a power cut and when the power was switched back on the display read "lock".  We now cannot find the instructions to sort out this locking problem, and so the microwave doesn't work.
Please can you help?
Thanks
David from London
  • Beechmont Jul 29, 2008
    What a great service! Within 24 hours I had the exact solution to my problem.  Thank you very much!
    From Beechmont - New Barnet
  • Microwave Ovens Master
  • 9,098 Answers
To lock, press Start three times.
To unlock, press Stop/Cancel three times.
You can download your owner's manual here. You will need the free Adobe Reader to view or print it.
Other UK models can be found by searching for your model number (without the suffix letters) here.
I'm confident this will be a FixYa! We're happy to help you and we'd appreciate yourthoughtful rating of our answer.
Posted on Jul 28, 2008
Microwave genius sensor 1300w
I don't believe it is possible to change the display angle/tilt on this microwave. The unit ships with a protective film over the display that should be removed to make the display easier to read. However, this model is known to be difficult to read unless looking at straight-on. That and needing a flashlight to look at your food with the door open since the internal light does not stay on when door is opened. Good luck!.
Jun 13, 2014 | Panasonic NN-SN657SMicrowave Oven
Panasonic microwave oven cuts on for two seconds then shuts off
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt http://031d26d.namesecurehost.com/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If yours is not a Panasonic, please reply back with your brand and model number so we can help you.
Nov 03, 2011 | Panasonic NN-T994SF Microwave Oven
The display window is stating the oven is in "demo mode". We did have a power failure prior to this function happening. What can we do?
I had the same problem after a power cut and eventually thought of switching it off at the mains and turning back on after a couple of seconds... it worked. Just needed to reset the clock and off I went!!! ;-)
Feb 05, 2011 | Panasonic NN-T888S Convection/Microwave...
How do I change the power setting
you have to enter your cooking time and THEN hit the "power level" button. Most likely, the display will read "the current power level is set to 10" or something like that. just go ahead and put in the number for the percent you want.
For example, hit 5 for 50% power. Then, hit "start."
eat
Aug 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Spare parts for panasonic NNT994SF (front display)
Check with any of the Fixya.com advertisers (they pay the bills here), you will get a list of them when you read the post, Your local appliance parts place, www.panasonic.com or www.repairclinic.com
I hope this helps you..
a
Oct 20, 2009 | Microwave Ovens
Microwave cuts out after 23 secs
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Dec 15, 2007 | Panasonic NN-S550WF Microwave Oven
NO power display dimesnion 4 range national microwave NNC 2000P MODEL
on front panel there is alow voltage transformmer the primary side isopen circuit replace
Mar 20, 2007 | Panasonic NN-C994S Convection/Microwave...
Microwave Ovens Logo
168 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
