3 flash drives have gone belly up today and are not recognised by the usb ports on any of my machines, all using xp as the operating system could it be a virus or just bad luck
    Novelist:
    Scholar:
  • 160 Answers
Weird that all three go on the same day...
The obvious question is are you using safe remove before unplugging the drives. If not, it's possible that you're corrupting the file system.
A virus could cause this - make sure your software is up to date, and run a special scan to make sure.
If the drives fail when copying the same file to them, the file could be the culprit. After you get a drive working, try copying some other files to see if it happens again.
Lastly, there could be problems with the USB port itself. Did they all die in the same port? Can you try with another port? If you use the drives in another computer do they work ok?
Put on your Sherlock Holmes hat, and try to narrow down the possibilities. I'll be Dr Watson....
Let me know how it goes - if you can give me the results of some of these ideas, I help you get to the bottom.
"When you've eliminated the impossible, all that remains is the truth" - S. Holmes
Good Luck
airoff
Posted on Jul 28, 2008
Will not boot, blue light flashes, makes beeping sound
Try a different usb port. Try using it on another computer. If both fail, then the drive has gone belly up.
Jun 07, 2012 | SimpleTech SimpleDrive Hard Drive
Find driver for pny 64g flash
Maybe the flash drive has gone bad (belly up). Try a different usb port on the computer.
Try the Flash Drive on another computer and see if it recognizes it. If not, the drive is gone bad.
You don't need drivers for it. Think about it, did you install a driver for it when you purchased it and first plugged it in? The operating system picks it up automatically and installs the drivers through windows.
But, if you want to see if there are some drivers for it, try PNY's website.
Get online and got to www.google.com In the google search box type: "PNY Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the drivers.
Jun 03, 2012 | PNY 64GB Drive
How to formet transcend usb flash drive.
Insert the flash drive into the usb port of the computer .Once you plugged the device it will be automatically recognised by the operating system .In case of windows operating system you find a new icon in My computer.On the icon of the usb device right click it and there will a option to format it.
Jun 17, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
The emachine model KAWE0 is with operating system windows xp sp1 doesnot recognise any usb device.
Good day sir, hi, usually its one or two ports that does not recorgnise a usb device, but if all ports does not recognise the usb device, check the CMOS setup. check this out;
  • one or two ports does not recognise the usb device, this is a local fault, try to check the CMOS setup, this could also be the port itself is the faulty one having loose connection.
  • all ports does not recognise the usb device, this is a system fault, check again the CMOS setup if the USB port is enabled, check the USB device itself also. to make sure use another pc to test the usb device.
A computer virus can also cause the usb port to malfunction, run an anti virus software, if possible you can reinstall the XP and test the USB port afterward.
If all else fails, you can buy a USB card and plug it on the expansion slot on your PC.
Nov 04, 2009 | E-Machines eMachines Desktop PC
Xp computer wont recognise new 250gb elements ext hard drive
use it on a differnet usb port
these portable hard drives have some issues with 1.1 usb ports
Jul 12, 2009 | Computers & Internet
Usb not recognised
Hello ak1979 ...
1. You're plugging in your Transend USB flash drive to your computer's USB port (as you've done many times successfully before with this SAME flash drive)?
2. It says "windows not recognise usb drive due to malfunction"?
a. Is that EXECTLY what the error says?
b. Is "it" an error dialog (window that pops up), or an error message from your Windows Event error logs? If a dialog, are there any pertinent error message entries in your Windows Event (System) log [Start > Run > type "eventvwr.msc" (without quotes), then "OK"]?
Try a bit of deductive troubleshooting:
  1. Restart (Reboot) your system [for a fresh start, if you will].
  2. Try plugging in your USB flash drive again, but in a DIFFERENT USB port.
  3. Try plugging in ANY OTHER "known good" USB device into the same USB port(s) used thus far that failed.
NOTE: If you EVER get any indication Windows recognizes the flash drive (like no error msg, or it shows in "My Computer"), IMMEDIATELY perform a "Check Disk" on it:
  1. Start > Run... > type "cmd" (without quotes), then "OK".
  2. Type "chkdsk DRIVE_LTR: /f" (without quotes), then hit "Enter" [where DRIVE_LTR is the drive letter of your USB drive]. EXAMPLE: chkdsk E: /f
Good luck, and please post back:
  • to provide any corrections/updates/clarifications.
  • if you have any further questions.
  • to let me know how things work out.
"Today's the best day of my life...and NOW you're part of it!"
Dec 24, 2008 | Transcend (589307) Media
Umas Astra 5600 connection problem
what computer operating system are you?
Chances are this is a very old DOS scanners for Win 95/8- if your machine is XP/Vista it is not likely to work
Mar 18, 2008 | Office Equipment & Supplies
W300i or usb drivers ?
You can get the usb drivers from sony ericsson website, just follow the link below:
http://www.sonyericsson.com/cws/support/products/updateservice/w300i?cc=in&lc=en
Mar 14, 2008 | Computers & Internet
USB port problems
Try going into the BIOS and see if the USB Ports are enabled. I don't know what type of system you have. When you turn on the pc it will prompt 'F1 to enter setup' or it might be F10. Do you have a USB mouse or keyboard? Try those in different ports.
Jun 12, 2007 | ASUS EXTERNAL USB FLOPPY DRIVE (ASUUSBFDD)...
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
